Aug 20, 2009, 01:17 PM
Personal Sales Rating: ( 0)
What would u recommend for a wideband 02 or a/f reader?
Offline
Aug 20, 2009, 01:25 PM
Personal Sales Rating: ( 2)
2008 Mitsubishi Lancer Evolution
Drives: GG X GSR
there are a ton of posts about it, here is the most recent one: Good widebands?
i personally have the digital AEM and have had 0 issues and it was an easy install/setup. i can't speak to the other options since i have never used them before.
__________________
FP Red - UICP - TBE - Drop-in Air Filter - Test Pipe - Motionlab tuning 800cc injectors - Coilovers - 3 port ebc
Tuned by Motion Lab Tuning
Offline
Sep 9, 2009, 07:08 PM
Drives: 08 EVO X WW GSR SSS Aero Navi
My ECU internal id is SM5268 and ecu id is 00006852. Doesn't jive with any of the numbers above. Anyone know why?
Offline
Sep 9, 2009, 07:14 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
grab the 4 hex bytes at 0x5002a and report back
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Sep 9, 2009, 10:49 PM
Personal Sales Rating: ( 6)
Drives: Evo X
ill need this for:
54060007 (2009gsr)
54070007 (2009mr)
__________________
I look at it this way For centuries now man has done everything he can to destroy defile and interfere with nature poisoning the atmosphere over-fishing polluting the rivers and lakes, destroying wetlands and aquifers so when nature strikes back, and smacks him on the head and kicks him in the nuts, I enjoy that. I have absolutely no sympathy for human beings whatsoever. None. And no matter what kind of problem humans are facing, whether it's natural or man-made, I always hope it gets worse.
Offline
Sep 15, 2009, 01:10 AM
Drives: Evo X GSR
this is a great thread for morons like me!  thanks!
__________________
Evo
X
Forums
Offline
Sep 19, 2009, 06:25 PM
Quote:
Looked around for these and couldn't find them. Where do I look for them?
Offline
Sep 19, 2009, 06:40 PM
Drives: WW EvoX GSR
In the ROM.
use a hex edittor (i use ultraedit) and jump to 0x5002a and the next 4 bytes will be romid
__________________
Offline
Sep 20, 2009, 07:32 AM
0018 got it! Thanks! Doing this today! Does Calculated Load log correctly in mode 23?
Offline
Sep 20, 2009, 08:02 AM
Drives: WW EvoX GSR
use the real load not calc
__________________
Offline
Sep 22, 2009, 12:24 AM
Tephra getting cheksum error when I pull my modded map with 1.42 ECUflash. Is it okay to correct it and use that to reflash the car? Makes me nervous to get errors like this.
Offline
Sep 22, 2009, 12:35 AM
Drives: WW EvoX GSR
yeh you should be ok
should only happen once thou...
__________________
Offline
Oct 6, 2009, 10:30 PM
Drives: OB Evo X GSR, 72 c-10
The rom id was 5260018, which is inherited from 52680015 just like this instructional. I put the following code in the misc line right where the pic in this thread showed it and the 3 extra tables under misc never showed up. It's for 52680015. What gives?
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
Offline
Oct 6, 2009, 10:40 PM
Drives: GG X GSR
Quote:
Originally Posted by boostin20
The rom id was 5260018, which is inherited from 5260015 just like this instructional. I put the following code in the misc line right where the pic in this thread showed it and the 3 extra tables under misc never showed up. It's for 52680015. What gives?
make sure you fully close ecuflash and reopen it, not just the rom but the whole program.
if that does not fix it, try putting the lines in the the rom map that you didn't already have them in. i had success just placing them in 15. noize however had to place them in 18 to get them to show.
__________________
Offline
Oct 7, 2009, 07:09 AM
I just got done spending some time trying to put those tables in different places. I tried putting them in 15, then 15mod, then 18; I also tried putting them in 15, 15mod, and 18 at the same time with no luck. I also tried modifying the address from 0x7f121, etc by taking out the x first, then tried taking out the 0x so the address read7f121, 8ab11,etc. Nothing made those tables show up. I did completely exit out of xml editor and ecuflash each time I made a change to a definition. Any ideas?
Am I correct that I'm changing the 52680015 definition in the rommet>mitsu>evo>52680015 file, and that is supposed to add those tables for whatever saved rom image (.hex) for rom id 52680018 when I open them in ecuflash?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
