Aug 8, 2009, 11:21 AM
#91
Silver Sponsor
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: 08 GG Evo X
Quote:
Originally Posted by nj1266
You really do not want to start down that road with me, so please back off and keep our relationship civil.
OK naj ill see you @ long beach meet we can talk then, face to face instead of hiding behind a keyboard.
you WILL be there right?
Offline
Aug 8, 2009, 11:31 AM
#92
Personal Sales Rating: ( 6)
Drives: 2006 EVO IX
I do not hide behind my keyboard. I am almost always at the meet. If you want to talk, I am more than willing.
__________________
2006 EVO IX, Stock
2002 Toyota Tundra, 207 hp, 271 ft-lbs torque
1998 SE-R Race Car, 2008 SCCA ITA SoPac Champion
Offline
Aug 8, 2009, 11:34 AM
#93
Silver Sponsor
Drives: 08 GG Evo X
I wasn't necessarily referring to you.
Cool id like to have a conversation with you about some stuff, see ya then!
Offline
Aug 8, 2009, 11:40 AM
#94
Drives: 2008 Evolution X & 1996 Eclipse GSX
Sounds like you guys should hash things out face to face.
Gunzo, he does bring up a good point about your base maps, it probably would be a good idea to practice what you preach and put in slightly milder warmup MIVEC maps in there! I appreciate all the info that you contribute to the Evo X tuning community and I think the end goal should be that we all make more power safely.
Those base maps were excellent for my friend's stock Evo X and the only major change was adding in my own Mivec maps. His car went from a "drowning in fuel sloth that sometimes didn't hesitate" to consistantly smooth and torquey power delivery.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Aug 8, 2009, 02:26 PM
#95
Drives: 2006 EVO IX
For the record, I have no problem at all with Gunzo and HB Speed. They are both assets to the Evo X community.
I just do not like it when we are told that we do not know what we are doing because we set the Mivec 1 and 2 maps the same only to find out that the person berating us is doing the same thing himself. People who live in glass houses should not cast the first stone...
As I said before Gunzo knows a whole lost more than I do about ECU disassembly and I respect that greatly.
__________________
2006 EVO IX, Stock
Offline
Aug 8, 2009, 06:38 PM
#96
Personal Sales Rating: ( 2)
Drives: Lancer Evolution SST
Quote:
Originally Posted by gunzo
Guess alot of people still doesn't know what is aggressive and what is not
Guess no one reads much nowadays .. (except HB Speed  )
Hiboost - Manage to compare the USDM exhaust yet ?
Offline
Aug 8, 2009, 07:59 PM
#97
On the Exhaust Mivec I was only able to compare from different days and slightly different tunes, so there was more than one factor involved. Still for the same boost levels the more recent VDR's seem to outpace my old ones by 10-15 whp down low and 5-10 whp up top at the same boost levels. There was definitely a solid gain on the dyno so if anything I didn't lose any power by retarding exhaust on the top end with my GT30 turbo. The stock turbo probably doesn't like the exhaust retard. I think gaining over 28 mph from the 1/8 to the 1/4 is pretty strong as well and can't imagine it being much better than that for the 6500-8000 rpm range.
I ran some tests with advancing the intake Mivec today from 2500-7000 and overall it seemed to lose a little power from 5500 onwards. There may be some gains before that but it was less than 5 whp and I'll need to do more testing to verify. Spoolup was still 20 psi by 3600 in 4th so getting more aggressive with the intake Mivec doesn't seem to be worth much and likely I'll keep at 30 advance peak. I'll run some more tests back to back when I switch to the original maps again and see if I get the same results.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 9, 2009, 11:31 PM
#98
Personal Sales Rating: ( 3)
Drives: Evo X MR
As promised, here are my dynos with Mivec tuning. Thank again for the valuable tuning info Hiboost and Gunzo, cheers!
LVSBB6's MR dyno
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Online
Aug 11, 2009, 08:56 PM
#99
Personal Sales Rating: ( 27)
Drives: 06 SSL and now WW X
can somebody send me map with stock jdm mivec maps?
Offline
Aug 12, 2009, 05:27 AM
#100
Drives: 08 EVO X RR GSR
I believe Gunzo 93 oct uses jdm mivec.
Offline
Aug 12, 2009, 01:00 PM
#101
Personal Sales Rating: ( 0)
Drives: 2 ****su's
Gunzo uses the JDM bottom end with the US topend I believe.
Online
Aug 12, 2009, 01:08 PM
#102
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
I posted this awhile back, I would imagine some people forgot about it:
Mivec advantage?
Offline
Aug 13, 2009, 08:54 AM
#103
Drives: 2005 EVO RS
care to post up this map in rom like you did the other to make trying just that much easier  ?
If anyone wants to test this last map out on a FP Red/Dom2/GT30 turbo I would be interested in your results as well.
Offline
Aug 13, 2009, 04:49 PM
#104
Sure I'll post something up later tonight when I get home.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Tags
advance, cells, compression, eclipse, evo, evoscan, exhaust, gsx, ideal, import, intake, load, log, logworks, mivec, psi, retard, software, spreadsheet  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
