Hi Guys,
Graphical HOWTO here
UPDATE: Evoscan 2.6b14 (and now b15) have Mode23 support integrated - You only need this thread for the XML modifications you must do for Mode23 to work
I have spent a fair bit of time looking at the ECU code and I have found a very nice function that we didn't have access to in CT9A-land.
OBD-Mode23 allows you to request ANY memory address and the ECU will fetch the current stored value.
I have tested this on my car - and it *sorta works*.
Hamish is currently integrating this into EvoScan so we should have support very soon.
Now when I say it *sorta works* the ROM needs a slight modification before you can access Mode23.
My preference for logging is that the ROM should be stock and everything should just work - but given our woeful logging experience thus far we are running out of options.
One downside with Mode23 is that every RAM address is unique to a ROMID, so the RAM addresses for 53040010 will be different to 52680018 - This isn't too bad, it will just mean someone needs to post up the relevant addresses for the ROMID in question.
HOWTO:
1) Apply the XML changes to your EcuFlash definition file, if you don't know what ROMID you are dealing with just ask. Modifications to ROM's can cause catastrophic results if you don't know what your doing
2) Download the application zip - in it will be an .exe and a config.txt
3) Edit the config.txt to suit your ROMID - We will be posting up config.txt's for common ROMID's so you can probably just download that.
4) Run the application.
Notes:
1) It's only a console application - so there is no fancy GUI.
2) It records every 5th row to screen, but EVERY row to the log.csv file
3) There isn't much error checking, so don't put anything stupid into the config.txt
4) In the config.txt file the evaluation expression is in RPN notation.
Application:
V1.1 - Is an attachment down here....
you also need a config.txt - I have included the one from my car 53040010 ... ENSURE YOU CALL IT config.txt and put it in the same directory as the .exe.
XML's:
NOTE: The name in EcuFlash describes what changes you need to make (ie 0x05 -> 0x23). IF the CURRENT value doesn't match here STOP AND ASK!!!
52690019
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aafd" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab02" scaling="Hex16"/>
53040007 -> 53040010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f145" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aa59" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8aa5e" scaling="Hex16"/>
52680015 -> 52680020
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
52360018
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f58d" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ada5" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8adaa" scaling="Hex16"/>
53600010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7efbd" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aa61" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8aa66" scaling="Hex16"/>
53050006 -> 53050009
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f145" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8a9f1" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8a9f6" type="1D" scaling="Hex16"/>
54060007
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7efc1" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8aa7d" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8aa82" type="1D" scaling="Hex16"/>
54070007
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8aa69" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8aa6e" type="1D" scaling="Hex16"/>
55570005
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f10b" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad5f" type="1D" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad66" type="1D" scaling="Hex16"/>
53610010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7efb1" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8a919" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8a91e" type="1D" scaling="Hex16"/>
55590006
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f107" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad43" type="1D" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad4a" type="1D" scaling="Hex16"/>
Cheers
Dave
