Nov 6, 2009, 09:36 AM
#841
Personal Sales Rating: ( 10)
Drives: 2010 Ralliart Sportback.
Quote:
Originally Posted by SiC
Sorry, I don't know why it does that on some PCs, it works fine on my PC and my PC from work.
Just copy & paste the following into your Evoscan data.xml:
Just a few notes for USDM users of the code provided by SiC:
In the "Mode23 USA EVOX" and "Mode23 USA RA EVOX" area of EvoScan the formula for throttle positions is "(x-32)*129/255" instead of "x*100/255" Not sure why it is different, and not (yet) sure which one is correct for us to use.
All temperatures provided by SiC are in metric units. For US units use "1.8*x-40" instead of "x-40"
Speed provided by SiC is in kph. For MPH use "1.26*x" instead of "x*2"
Thanks,
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Online
Nov 7, 2009, 12:33 PM
#842
UPDATE:
The Manifold air temperaturelogging doesn't work on my 2010 Ralliart, but everything else provided by SiC works great!
Keith
__________________
Online
Nov 8, 2009, 08:29 PM
#843
Personal Sales Rating: ( 0)
Drives: evo
awesome thanks man i will test out on the 2010 GSR tomorrow and i will get the 2010 MR rom up ASAP
__________________
FLAT RATE TUNING
$200!!!!!!!
Includes:
ECU Boost
MBC
EBC
91
93
100 oct/Race Gas
E85
Located in SoCal
Anahiem Mitsubishi will beat any price by any dealer anywhere! PM me about FREE shipping in the continental US!!! Ask me about FREE Kenwood Double Din Navi with purchase!!
Give me a call (818) 486-1395
Offline
Nov 9, 2009, 02:13 PM
#844
Personal Sales Rating: ( 6)
Drives: 2006 EVO IX
Thanks,
Keith
The TPS code in the 2010 Mode23 is different than the ones in Evoscan Mode23 2008. Should we change the code from "x*100/255" to "(x-32)*129/255"?
__________________
2006 EVO IX, Stock
2002 Toyota Tundra, 207 hp, 271 ft-lbs torque
1998 SE-R Race Car, 2008 SCCA ITA SoPac Champion
Offline
Nov 10, 2009, 05:07 PM
#845
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Is there a way to LOG MAF Volts and MAF AIRFLOW in G/S in MODE 23 USA EVO X (for a 2008)?
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
SteepSpeed Exhaust Manifold
Offline
Nov 10, 2009, 05:43 PM
#846
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
yes...
53040010:
MAFV:0x808f48:2:x,1023,/,5,*:1
AirFlow:0x8087d8:2:x,2,*,100,/:3
526800XX:
MAFV:0x808f50:2:x,1024,/,5,*:1
AirFlow:0x8087e0:2:x,2,*,100,/:3
Airflow for 526800xx is untested, let me know
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Nov 10, 2009, 09:33 PM
#847
Quote:
Originally Posted by tephra
yes...
53040010:
526800XX:
Thanks!!!
However here comes in my moment of slight knowledge deficit.
Where do I enter this information. Data edit in EVOSCAN?
Thanks!
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Nov 10, 2009, 09:39 PM
#848
Drives: WW EvoX GSR
thats the format for my logger.
for evoscan just use notepad to edit the data.xml file
just copy one of the current entries (Load is a good one) and modify the address/name and Eval appropriately
__________________
Offline
Nov 10, 2009, 10:57 PM
#849
Thanks, I didn't check out this logger yet. I hope I will have a chance to try it out tomorrow and tell if these work.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Tags
26, 52360018, beta14, evo, evolution, evoscan, logging, manifold, mode23, mut, romid, sm5237, table, temperatures, xml  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
