Jun 2, 2009, 06:26 PM
#31
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: Lancer Evo X GSR
The 53040007 addresses didn't match up on the JDM
Offline
Jun 2, 2009, 06:34 PM
#32
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
send me the rom dude - ill work them out for you.
myforumname @ gmail.com
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Jun 2, 2009, 06:42 PM
#33
Sent from hotmail!
Thanks
Offline
Jun 2, 2009, 07:03 PM
#34
Drives: WW EvoX GSR
first post updated with XML's for some ROMID's.
You can use the zip in the 2nd page - but you will have to update the Hex Address's...
__________________
Offline
Jun 2, 2009, 07:04 PM
#35
You ROCK!!
Offline
Jun 2, 2009, 07:07 PM
#36
Drives: WW EvoX GSR
that 52360018 rom is a bit screwy SiC - the XML should work - but just be a bit cautious when you after you flash...
__________________
Offline
Jun 2, 2009, 07:12 PM
#37
Yeah, I noticed I sent you an old ROM that we used in the old ECUFlash beta before it supported the correct checksum on the EvoX. I tested the address out with another ROM and it seems to work fine.
BTW, can I send you one more: JDM 52370024 (SST), this one didn't seem to all line up either.
Thanks again!
Offline
Jun 2, 2009, 07:14 PM
#38
Drives: 2008 EVO X GSR
This is great news! When will I be able to use EVOscan with no problems? Or a "how to" log an evo X thread?
Offline
Jun 2, 2009, 07:49 PM
#39
Personal Sales Rating: ( 0)
Drives: Evo X GSR
Tephra, this worked great on a stock USDM GSR with 52680018. Looks like it's pulling a degree or two of timing up top above 6500 rpm's. How do I interpret the knock sum value - I see a few 1's and 2's up top. Is this a count like the evo 8/9 where 3 counts equals 1 degree, or does 1 count equal 1 degree roughly?
I've attached my log. Any chance of getting TPS and wastegate duty cycle? Thanks again
Offline
Jun 2, 2009, 08:13 PM
#40
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
I'm pretty sure it's normally 3 counts = 1 degree but I think even 1 or 2 counts can pull 1 degree of timing. I'll let Tephra confirm that of course!
1-3 counts = 1 degree (minor knock, may not always occur in the same spot)
4-6 counts = 2 degrees
7-9 counts = 3 degrees
10+ counts = correct the knock ASAP!
I think usually 1-2 counts occasionally is livable, especially if pulling 1 degree of timing doesn't seem to clear it up at all. I have a TurboXS Knocklite and on it's most sensitive setting it won't trigger unless I hit 7+ counts. I can make it more sensitive by not revving it as high when I calibrate it for my base engine noise but I would rather only see it when it is definite knock.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Jun 2, 2009, 08:39 PM
#41
Drives: WW EvoX GSR
yeah same is IX, so 3 KS = -1*
So 1KS = 0.35 timing retard.
You might see -1* with 2KS because of rounding etc..
__________________
Offline
Jun 2, 2009, 08:56 PM
#42
Drives: EvoX, Cooper S
I will test log on 53040007 in two days.
Offline
Jun 2, 2009, 10:09 PM
#43
Tephra, is the program you uploaded strictly for the 52680015 or can it be used with other ROM IDs too?
Offline
Jun 2, 2009, 10:40 PM
#44
Drives: WW EvoX GSR
Any ROMID...
The XML changes allow the program to execute Mode23 commands.
The config file tells the program which memory addresses to retrieve.
__________________
Offline
Jun 2, 2009, 10:54 PM
#45
Drives: WW EvoX GSR
updated post #1 with some details.
still need to test the new version of the app on my car b4 posting (you can still use the zip off page#2 if you want)
new version just has some minor enhancements.. (like waiting for you to plug the OP2.0 cable in etc etc)
__________________
Offline
Tags
26, 52360018, beta14, evo, evolution, evoscan, logging, manifold, mode23, mut, romid, sm5237, table, temperatures, xml  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
