Jun 2, 2009, 12:47 AM
Silver Sponsor
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: 08 GG Evo X
good job!
Offline
Jun 2, 2009, 05:24 AM
Personal Sales Rating: ( 0)
Drives: Evo X
Jdm CT9A 3bar map sensor has the same s/n and the same calibration with the X.5v output equals with almost 340 kpa absolute.
Offline
Jun 2, 2009, 06:14 AM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
great - that means my scaling is correct...
what I might do tomorrow is do up the XML for 52680018 and include the app + config file and get some feedback from you lot
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Jun 2, 2009, 06:41 AM
Drives: Lancer Evo X GSR
Can you post the one for your AUSDM? Maybe I can use it to find the JDM address since both are similar.
Offline
Jun 2, 2009, 07:45 AM
Drives: WW EvoX GSR
See post #1 for information..
__________________
Offline
Jun 2, 2009, 09:42 AM
Drives: Evo X GSR
This should work for 52680015 -> 20:
First add this to your XML in EcuFlash, then make the changes as described in the name:
Code:
<table name="IFMode 0x05 -> 0x23" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
Wow, thanks Tephra!!  Could you elaborate a bit on what you mean by "make the changes as described in the name"? I've never modified my ROM before so I'm a bit confused - once I edit the XML, I assume that these three new options will show up under Misc. When I open each one up, should I see the X value, and change it to the Y value in your X->y notation above? I assume I will have to change all 3 values to 0x23, 0x23, and 0x52. Does that sound right? Thanks again!
Offline
Jun 2, 2009, 10:17 AM
Drives: EvoX, Cooper S
Edm evo SM5304
xml
<table name="IFMode 0x05 -> 0x23" category="Misc" type="1D" address="0x7F145" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23" category="Misc" type="1D" address="0x8AA59" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8AA5E" scaling="Hex16"/>
I use hex search to find similar code (30-50 bytes length) in edm rom.
How can I adjust config file?
Values are stored in MUT table?
RPM - MUT21
PSIG - MUT38+1 byte
TimingAdv - MUT06
KnockSum - MUT26
Load - MUT8B+1 byte
IPW - MUT29
Is it right?
Offline
Jun 2, 2009, 02:34 PM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
awesomeness!
Offline
Jun 2, 2009, 03:02 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Good work Dave.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Jun 2, 2009, 05:04 PM
Drives: WW EvoX GSR
Quote:
perfect - you got it in one
Quote:
Originally Posted by Bob_tm
Edm evo SM5304
xml
RPM - MUT21
PSIG - MUT38+1 byte
TimingAdv - MUT06
KnockSum - MUT26
Load - MUT8B+1 byte
IPW - MUT29
Is it right?
Hey Bob, what ROMID is that for? I prefer to deal in ROMID's rather than ECU model #'s
The config file is just a text file, you can edit it in notepad.
The address field needs updating for your ROMID. Most of those you got right - it's upto you/user what you want to log. That being said if you need help finding 2byte load or PSIG for instance let me know
__________________
Offline
Jun 2, 2009, 05:16 PM
Drives: WW EvoX GSR
Code:
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7F145" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8AA59" scaling="Hex8"/>
I can confirm this is correct for 53040007 and my ROMID 53040010
__________________
Offline
Jun 2, 2009, 05:21 PM
Drives: WW EvoX GSR
There seems to be a very minor problem with the "IFMode 0x05 -> 0x23" tables not showing up, just change the first one to "IFMode 0x05 -> 0x23 #1" and the 2nd one to "IFMode 0x05 -> 0x23 #2"
__________________
Offline
Jun 2, 2009, 05:23 PM
Drives: Evo X GSR
Thanks again Tephra! Any chance you can find the RAM address for TPS for 52680018? I will test this out tonight or tomorrow as soon as I can...
Offline
Jun 2, 2009, 05:55 PM
Thank you sir!
I've made the edits to my rom and will test soon on my 5260018 rom.
Offline
Jun 2, 2009, 05:59 PM
I'll see if the 53040007 will work with the JDM 52360018 & 52370024.
Offline
Tags
26, 52360018, beta14, evo, evolution, evoscan, logging, manifold, mode23, mut, romid, sm5237, table, temperatures, xml  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
