Some Ideas to share
Some Ideas to share
These are not super ideas but maybe someone find it interesting to use
All my Cobb and Cusco upgrades. I decide to use a heat reflector cover on the nearest to the engine Cobb pipes to keep away the engine heat.
I got mine at Murray's auto parts but there are a lot of these products online
Another angle of the engine bay. You can also see my Boost gauge T connector.
Enjoy the passenger side of the engine bay. Since the cooling liquid reservoir tank has one of the hoses just open to create vacuum in the tank I decide to use a little low restrictor K&N Filter to avoid dust collection inside the tank.
Be aware you have to modify the filter to make it fit inside the hose. It is nothing hard to do it.
You can see also where the Heat reflector starts and ends. Also take a look at my Cusco strut bars. Isn't cool?
The Aluminum Mount that you see hanging from the Cusco bar is an old project that i did. the idea was to install an 8" fan to blow the heat produced by the turbo and engine. since the back of our engine setup is the hottest part under the hood i thought was a good idea to blow the heat constantly from there.
the project was a total catastrofe
No more coments......
i Notice some guys looking for gauges location solution.
Remember PERRIN performance has this really nice dual gauge mount. It fits perfect. you can buy it alone or with a Prosport Gauges combo. I'm installing the Boost gauge first.
a little tip:
PLEASE!!!!!!!!!! Disconnect the Battery before play around with power cables. this is a really sensitive electronic system. in other words: This is not a Ford or Dodge. I had to replace fuses 2 times; I’m so use to work in American cars
I found a really comfortable place to make all my electric connections. I’m 38 and muscles start giving some pain if I stay more than 10 minutes below the console.
Anyway, in this location I can connect and disconnect everything in 10 seconds. I hope somebody find this spot useful. I got the electric connector at Pep boys. Was like 10 bucks. It is a 4 cable connector, exactly what gauges need.
Last, I want to share my Spot for my RAZIN voltage stabilizer.
There is a Lot of different ideas and opinions about these products, but I like it. It fixes the dim lights issue
Enjoy it
That's it for now guys.
Sorry for my bad English. Enjoy the photos. And give me some comments
Thanks
a little tip:
Enjoy it
Thanks
per clipse3G request, a couple more of images
i have been soldering and preparing the cables to run the less amount as posible inside the console, is anoing the amount of cables that you have for just two simple gauges. lol
also i had a little problem when i conect all the cables the gauges doesn't turn off. i'm still working on it
i'm using PC power supply conectors to be able in the future to disconect everything easy. i will share some photos of the cables and gauges when i finish this weekend
The Cobb pipes i know look beatifull without the heat reflector, but i'm more for performance than beauty and beleive me that fire reflector keep my Cobb pipe cool.
and yes, it respond 100% better, that's what everybody say, even one service manager from mitsu.
FS[Northeast]: Lower control arm bushing
fugiwara
36
Apr 18, 2017 02:16 PM
01CBR929
Feb 23, 2017 07:28 AM
evotuner04
For Sale - Part Outs
13
Dec 2, 2016 10:09 AM
alex3dworld
Evo X How Tos / Installations
84
Apr 21, 2016 08:36 PM
Boomba Racing
Apr 14, 2010 10:08 PM
