Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 29, 2009, 12:11 PM   #1
Personal Sales Rating: (0)
Hassan!'s Avatar
Drives: 2008 Evo X GSR
Question Upgraded Internal Wastegate Actuator: EVO X - Gain 40whp?
HKS Upgraded Internal Wastegate Actuator: EVO X
Product Description
Sick and Tired of boost falling off in your EVO X?
We have an easy solution!
The new HKS actuator will eliminate boost fading. The HKS wastegate utilizes larger internal diaphragms than the original equipment actuators allowing quicker turbocharger spool up and boost stability.
TECH TIP: This is by far the best bang for the buck on the new EVO X. Bolt on 40whp to the top end of the power band in 15 minutes. The car is 100% safe on the stock tune with this mod on a stock boost controller. Direct bolt on!
Fits: Mitsubishi Lancer Evolution X 2008+ (MR, GSR)
Price: $217.95
Forge Billet Turbo Wastegate Actuator Kit: EVO X
Product Description
The new Forge Motorsports EVO X billet actuator will eliminate boost fading.
This actuator will hold a solid 35psi to 8500rpm on a 50trim turbo.
Comes equipped with a 15psi spring and will accept stock or any aftermarket boost controller.
Fits:
Price: $194.95
Can someone please explain me what exactly is this and is it really worth it?!
Also is it hard to install ?
Who already installed it on EVO 10?
The difference?
Thanks.
Offline
Old Apr 29, 2009, 01:14 PM   #2
Drives: WW EvoX
it gives you 40whp apparantly... try using the search button buddy. goodluck
Offline
Old Apr 29, 2009, 01:22 PM   #3
Hassan!'s Avatar
Exclamation
Quote:
I want to know if anyone already install it here?
I want to know what is his experiences are..
I already used search , Gave me direction to here!
Offline
Old Apr 29, 2009, 01:56 PM   #4
Personal Sales Rating: (2)
2008 Mitsubishi Lancer Evolution
newcomer81's Avatar
Drives: GG X GSR
if you used search it would not have gave you direction to post a new topic..
i'll give you an example: I rana quick search for "forge wga" and in the top few results i found not only someone who installed it but also dyno tested it
Forge WGA testing
edited for typos
Offline
Old Apr 29, 2009, 03:02 PM   #5
Drives: 2008 Lancer Evo X GSR
So the forge one is a bit less price wise than the hks - which one do yall suggest? They both claim same results, and both companies make pretty good product.
__________________
Blue Evo X GSR
ETS Intake
5" K&N Cone Filter
GReddy Ti-C Exhaust
GReddy Downpipe
Nisei 1pc UIP
HKS SSQV VTA
AMS shifter bushings
Offline
Old Apr 29, 2009, 03:50 PM   #6
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Unless they are counting going from stock boost of 22 psi @ 5500 RPM's to 26 psi I don't see you gaining 40 whp. Basically it allows you to hold the boost until 5500 RPM's much better than stock so midrange power is quite a bit beter than just an MBC and stock actuator combo. 5500-7500 you will taper boost just like before due to the stock turbo running out of flow.
I still think the Forge WGA was a good upgrade and with my new turbo it will really shine, but don't expect peak HP numbers to change since the boost made at 6500 RPM's will be very similar.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Apr 29, 2009, 04:10 PM   #7
SilverEvoX's Avatar
Drives: Silver Evo X
Just get a tune and it will solve your problems with boost tapering off so bad at redline as well as improve your power through the whole power band through changing MIVEC settings and you'lle get better mpg!
Offline
Old Apr 29, 2009, 05:56 PM   #8
Personal Sales Rating: (3)
Narmy77215's Avatar
Drives: 2008 GG Evo X GSR(SSS),93 3000GT VR-4(Sold)
Send a message via Yahoo to Narmy77215
I have the Forge WGA and I love it. I spike 25psi and hold 24psi in 4th gear.
__________________
Mods:Injen CAI,ETS UICP,ETS LICP,ETS 4" FMIC,ETS V2 CB,ETS TP,ETS O2 DP,Forge MBC,Forge WGA,ExedyTwin HD,Autometer Boost Guage.Tuned By English Racing.
Offline
Old Apr 29, 2009, 08:00 PM   #9
Keepthechange's Avatar
Drives: PB Evo X w/ sss
Send a message via AIM to Keepthechange
is the install complicated ?
Offline
Old Apr 30, 2009, 09:10 PM   #10
Talon_66's Avatar
Drives: WW EVO X
Install is simple
__________________
WW EVO X #32
AMS Front Motor Mount & Underhood Shifter Bushings
TurboTrix Piping Kit
ETS Dual Exhaust
T1R o2/DP Combo, T1R Testpipe, Shift Boot, Stubby Antenna
Prosport Boost Gauge
AEM Uego
DTM Stg. 2 FMIC
Perrin EBCS
Eibach Springs
Whiteline RCK
TWM STS, Bushings
Ichiba Spacer
Seibon CW hood/OEM Trunk
Chargespeed FRP VG
ECUTek Tune (318whp/359 Torque @ 26psi)
First EVO X in Canada to Break 300whp
Offline
Old May 1, 2009, 03:13 AM   #11
Drives: WW EvoX GSR
just get a tune - boost wont taper, you will get proper AFR's and timing will be played with too
^ looks like a big advert IMHO
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Old May 1, 2009, 03:31 AM   #12
endGameXIII's Avatar
Drives: Evo X GSR
the point of getting an uprated wga is to reach peak boost sooner, is it not? minimizing taper is just another part of the tuning process. a tune won't help you reach peak boost sooner as much as an uprated wga.
Offline
Old May 1, 2009, 03:43 AM   #13
Drives: WW EvoX GSR
not if your boost control system is setup properly
__________________
Offline
Old May 1, 2009, 10:17 AM   #14
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
Quote:
It's more for holding boost up top as it is stronger and does a better job keeping the wastegate flapper from being blown open more than the stock one.
I should have data with uprated WGA *and* 3port boost solenoid upgrade here very very soon.
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old May 7, 2009, 02:18 AM   #15
Narmy77215's Avatar
It was really easy to install.The only thing that was difficult was setting the preload.I live on a island and it is hard to do any street tunning without getting a ticket.Just remove the two heat shields and you are good to go.Wear gloves or something because I cut my hand on one of them.
__________________
Offline
Tags
actuator, bad, boost, evo, install, internal, kit, mbc, mod, scsitool, tune, turbo, upgraded, waste, wastegate
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
