May 7, 2009, 11:46 AM
Personal Sales Rating: ( 0)
hassan,
Personally, I'd just install a smaller restrictor pill or even better an aftermarket 3-port bcs. Both considerably inexpensive compared to that replacement actuator. They're all reasonable solutions to holding boost better.
Offline
May 7, 2009, 11:48 AM
Drives: 2006 GG Mitsubishi Lancer Evolution MR. Any Car on my Dealership.
Yeah this WGA isnt going to do what you think if you just simply only bolt it on. I did it with my car with a forge and FP 18psi WGA
__________________
AMS FMIC
ACT XTSS
AMS SS CLUTCH LINE
MEGAN O2
GREDDY Ti-C CATBACK
DC Sports DOWNPIPE
HKS R.S.I.
Hallman MBC @23 PSI
FORGE B.O.V.
WALBRO 255
Cosworth M2's
SuperTech Dual Springs/Ti-Retainers
ARP Headstuds
ETS 2.5" Upper/Lower I.C. Pipes
Kuniiizzzeee Dial-IN
11.9 @ 116mph (6-speed MR)
Next Mods: FP Black on VP Import
Sponsored by my own dealership! http://www.mainstreetmotors.org
Offline
May 7, 2009, 01:09 PM
Personal Sales Rating: ( 3)
Drives: 2008 evo 10 gsr, 2000 chevy venture L0L ex cars 2006 evo Se
i used the forged got a discount on mine so i got it and top end boost holds much better
Offline
May 7, 2009, 01:48 PM
2008 Mitsubishi Lancer Evolution
Drives: 08 evo x gsr, 00 galant es
Quote:
Did u just bolt it on, or did u get a tune afterwards?
Offline
May 7, 2009, 02:29 PM
Personal Sales Rating: ( 1)
Drives: Evo X
you dont gain any power with it.
someone i know put just a forge WGA on his car and dynod less then me on the same dyno. stock vs stock + WGA.
__________________
Sponsored by: Grimmspeed
Grimmspeed p&p and heat coated FP RED
Grimmspeed p&p and heat coated intake manifold and exhaust manifold
Grimmspeed EBCS
AMS FMIC-Rear lightweight bumper beam-aem water/meth-UR testpipe-Exedy 4 puck Clutch-D2 Coilovers-ams intake-ams fuelrail-ams motor mount-Functional Gauges-External dumped o2 DP-exhaust depot catback
ECUFlash/EVOScan
Offline
May 7, 2009, 02:48 PM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
wga at best only changes your power curve, it doesn't add hp.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
May 7, 2009, 06:45 PM
Drives: 2008 Evo X GSR
Quote:
Originally Posted by tmarcel
hassan,
The problem is how to get these stuff and where get it from?!
How to install it?
You see most people have no experience with turbos! My other cars was solid v6 or v8 engine!
What can i do to reduce turbo lag?!
I do a lot of drift and the lag bothering me so much!
HELP.
Offline
May 7, 2009, 07:04 PM
Yeah, then the peak boost level dropped and the WGA needed to be adjusted further. Most of these have a stronger spring and are more capable of keeping the wastegate flapper shut at higher RPM.
Quote:
No. If you're making peak power up top anyway, and the WGA enables your wastegate flapper to stay perfectly shut up top, allowing you to make more boost; then you're going to end up making more peak HP.
Offline
May 7, 2009, 07:28 PM
Drives: Evo X
Quote:
not the case, he hit 26psi vs my 23psi. he made 1 less whp. go figure
__________________
Grimmspeed EBCS
ECUFlash/EVOScan
Offline
May 7, 2009, 07:37 PM
Do you actually do any tuning yourself? There are so many factors involved, it's not even funny. Could have been substantially more knock after the wastegate upgrade, and the ECU loves to pull timing and dump fuel on these engines. Unless you know for sure, stop speculating because what you're saying is highly debatable.
Offline
May 7, 2009, 07:39 PM
Drives: 2008 Evolution X & 1996 Eclipse GSX
I've dynoed before and after, when using a Manual boost controller to keep boost levels the same it will hold more boost in the mid range where you might see 15-20 whp gains. I was already maxxed at low RPM's and above 5500 rpms the turbo begins to taper from 25 psi down to 19 psi at 7500 rpms regardless of the wastgate being held shut by a stronger actuator.
So due to this mod only helping midrange boost it really won't show up on peak HP numbers at 6000-6500 because you can't force the turbo to hold any more boost than it was before. That is easily why it might show up as making less peak HP but if you overlay the dyno graphs there would be more HP and torque from 4000-5500 for sure. Here are my dyno plots:
Forge WG Actuator vs Stock - More Boost!
Basically you will want to get a tune to adjust the boost levels or use a MBC if you get a Forge WGA. Like others have said the stock boost control is assuming a WGA spring opening pressure of 10-12 psi , not 19-24 psi so it will overboost if you don't plan ahead.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
May 7, 2009, 07:47 PM
On the stock turbo the boost tapers starting at 5500 rpm's. Assuming that best case scenario you are tapered down to 22 psi by 6500, it doesn't matter if you had 26 psi or 23 psi at lower RPM's the extra boost won't improve the peak HP numbers. In fact it may even hurt them if the hotter intake charge is heat soaking the intercooler enough through the run.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
May 7, 2009, 07:52 PM
Drives: 2008 Apex Silver Evo x
Hassan, look into the DIY w/g mod. Your boost wont taper down as far and helps hold boost in the top end. (if i understand correctly)
__________________
Dane
PSU'11
2008 Evolution X
Apex Silver
Speed Circuit Wicked edition exhaust
Speed Circuit Test Pipe
HKS Drop In
Offline
May 7, 2009, 08:08 PM
Drives: Evo X
all i was saying is that the wastegate alone dose not add 40whp as stated and i was talking about some results that i knew of that stated this as a fact. other then that, you sound like you know everything in the world.
Quote:
once again... i was simply aswereing the guys question when he asked if you gained 40whp from this mod.
answer is no.
__________________
Grimmspeed EBCS
ECUFlash/EVOScan
Offline
May 7, 2009, 08:11 PM
Drives: Evo X GSR
true, but what i'm saying is that a uprated wga doesn't add hp. higher boost does.
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Tags
actuator, bad, boost, evo, install, internal, kit, mbc, mod, scsitool, tune, turbo, upgraded, waste, wastegate  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
