Aug 14, 2009, 09:42 PM
#496
Personal Sales Rating: ( 1)
Can I use the AP on my X to read SES codes (OBD II Service Engine Soon codes)without installing or marrying the unit to the car with the codes? If no, how do I install/marry the unit without installing a new tune?
Offline
Aug 14, 2009, 10:14 PM
#497
Drives: GG Evo X
just marry it, it wont install a new tune nub
__________________
GG Evo X SSS
Greddy Ti-C- Harmon motive intake- Speed circuit 3" test pipe- Nisei 1 piece UICP- AMS fan shield-Cobb AP
Offline
Aug 15, 2009, 10:24 PM
#498
Just an update. The AP will not "install" to the car without also selecting a tune (map).
However it has a Troubleshooting menu item that will read and clear codes without being installed (married).
Offline
Aug 17, 2009, 02:28 PM
#499
Personal Sales Rating: ( 0)
Drives: 2008 Evo X - SSS w/ Aero
Quote:
Originally Posted by elihanselman
Just Ordered an AP, Any Word on K&N Panel Map yet?
Anyone here used the KN Filter with any existing maps? Results?
Update After Looking on the other EvoX forums, Courtesy of User hollywood_X
"So I took the logs you sent me and went throught them.
(For the rest of you reading this he was using the K&N filter with an HKS map.)
The K&N panel filer is within 1-2% on calibrations all the way down the line and pretty much a perfect match. so I would say your more than good to go on using these on that map."
any confirmation from cobb?
Offline
Aug 18, 2009, 04:57 PM
#500
Drives: 2000 Supercharged Dodge ViperGTS, 2008 Evo X MR
Quote:
Originally Posted by imdrew12
Does anybody know if the Cobb estimates wheel or crank hp using the dyno feature?
It is wheel hp, but it is for reference only and might not compare to a proper dyno number, especially because vehicle weight can be a big variable.
Offline
Aug 19, 2009, 02:05 PM
#501
Drives: 2008 EVO X
can i run cobb stg 2 93 oct. with a perrin drop in filter and a hks hi power catback with the boost pill removed?
Offline
Aug 19, 2009, 05:13 PM
#502
Personal Sales Rating: ( 5)
Drives: Wicked White Evo X
When is the Injen intake or HKS Suction intake maps going to come out?
Offline
Aug 25, 2009, 01:08 PM
#503
2008 Mitsubishi Lancer Evolution
Drives: '08 EVO X GSR, '07 Lotus Exige S
I already have a MBC installed and running a few extra psi - would the AP have issues with that? Would I need to revert back to the stock boost control system?
__________________
Mitsubishi Lancer Evolution X GSR - SSS, Aero, Black
Martial Arts
Cars
Offline
Aug 28, 2009, 07:22 AM
#504
do you guys know who can create Stage II maps for EDM evo's ?
Offline
Oct 19, 2009, 05:55 PM
#505
Drives: x
bumping this topic up: anyone else try running the K&N drop in filter on the HKS drop in map?
Offline
Oct 23, 2009, 02:22 AM
#506
Drives: 2003 BMW M3
Hey guys,
With a Cobb AP stage 2 tune (91 CA gas here), the website states the factory intake and filter must remain intact but a turbo back exhaust is required as well as the removal of the factory boost pill.
Sorry for the noob question but would the tune work properly if say a AMS intercooler and intercooler piping were installed?
Thank you in advance for your replies.
Offline
Nov 1, 2009, 07:17 AM
#507
2008 Mitsubishi Lancer Evolution My Garage
Drives: 2008 Evo MR
Quote:
You can use an AP to read codes and reset codes without marrying it. I've done it.
Quote:
Yes. The AP uses the ecu to control boost. A stage 2 is around 25 psi.
Quote:
Originally Posted by flightz71
Hey guys,
Yes. The intercooler is between the mas and the intake, so its air is already measured.
__________________
1/4 12.599@ 106.99 60' 1.715
HKS drop in; Cobb Inlet tube; Ultimate Racing TB; Cobb AP stage 2; Rally Armor; AMS uicp; Xmr catch can; AEM afr guage;
ETS 4" fmic; Mishimoto radiator & hoses; SSP frontmount cooler; Boomba engine mounts
Dry carbon hood (body color), Aero Catch latches
Offline
Nov 2, 2009, 10:11 PM
#508
Personal Sales Rating: ( 11)
Drives: AS EVO X MR
Quote:
No. Stage II requires a turbo back, not cat-back, exhaust. If you are running the factory downpipe and cat, leave the pill in and run Stage I.
Quote:
Works like a champ. You can try the normal Stage I map and log for timing- if you're not getting knock, don't bother with changing; if you do, go with the HKS map and relog.
__________________
Are you in the North Texas area? Check out NTEC!
Online
Nov 4, 2009, 06:42 PM
#509
Drives: 2003 BMW M3
Ok so even more of a noob question... now i'm confused to how a intercooler works:
I thought the purpose of the intercooler is to cool down the temperature of the air flowing through the intercooler and therefore increasing the density of the air. If the air density is increased... the additional air needs to come from somehwere... so I'm guessing more air has to be drawn in from the intake? If more air is being drawn in... than the MAS will get that reading... regardless if it's after the intercooler or before.
Therefore... the installing a intercooler would be no difference versus installing a new drop in filter to increase air flow right? And from this thread... I've concluded that anything which messes with the factory MAS reading will not work correctly with these Cobb tunes.
Someone please correct my confusion somewhere? Or does my logic deduce that intercoolers cannot be used?
-Calvin
Offline
Nov 7, 2009, 03:17 PM
#510
Drives: 2008 Evo MR
Correct.
A brief intake flow chart:
Filter->Intake-> MAS->Turbo Inlet->Turbo->UICP-> Intercooler->LICP->Throttle body->Int Manifold->Head
No. Installing an intercooler is only going to effect measured air, and therefore it will not have an effect on the mas reading. This is very different from changing a filter or intake. Power gains from an intercooler are due to denser air at the cylinder intake. The ecu is able to deal with this because even though the air is denser, it is air that the ecu has accounted for by weight (g/sec).
It is not just Cobb tunes, it is any tune. Anything you do forward of the mas, like intakes, has the potential to effect the tune, by changing the airflow over the mas, and effecting its measurement of air. This then in turn effects how much fuel the ecu meters, possibly effecting your afr. Any gains from an intake are gonig to be due to increased air flow, not a change in air density. Some intakes actually change the mas housing, making it more likely to effect the tune than intakes wich leave the factory mas housing in place. This explanation does not take into account that the car is pig rich from the factory, and to a point leaning it out makes power. So please don't read anything into this.
You may be over thinking it, and confusing yourself, since you seem to understand this, but are still confused. So short version is intercoolers are fine on an off the shelf tune, intakes not so much.
__________________
Offline
Tags
accessport, accesstuner, airbag, ap, cobb, data, dealer, detect, drop, evo, fail, filter, installed, intake, intakes, kn, logging, maf, make, map, mapp, meaning, mega fail thread, perrin, race, review, springs, stage, stock, u0184, undetectable, upgrade, vs  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
