ECUFLash speedcut on JDM
Old Feb 14, 2009, 02:24 PM
burnings's Avatar
Hi,
I am on EVO X GSR and the speed cut function on the ecuflash seems to have no effects at all.
The current setting is at 510 but speed cut still activated at 180km/h
Did anyone else have the same problem?
Old Feb 16, 2009, 11:06 PM
AlGontsov's Avatar
This value is on the most if the Lancers, maybe it's require for some scaling?
Maybe x/2.83
Old Feb 17, 2009, 02:40 AM
burnings's Avatar
Maybe x/2.83
510 is the max it can go
Old Feb 17, 2009, 03:40 AM
kenx's Avatar
According to the magazine in Japan,speedcut has three maps.
You may examine the value of an address below.
But, I do not yet try it.
address="53062"
address="53fb2"
address="533d2"
good luck!
Old Feb 17, 2009, 04:40 AM
burnings's Avatar
address="53062"
address="53fb2"
address="533d2"
good luck!
Hmmm... 533d2 has a stock value of 42 which 53fb2 consists of 3 digits which I cant see as it only shows 1..
Old Feb 17, 2009, 07:10 AM
yokohama_evox's Avatar
Hi,
Perhaps three addresses are right. In ECU finished with tuning of the GSR SST of the model for my 2008 years in three addresses a constant value (Limiter on:380km, Limiter off:378km) is set.
Because I made a xml file for trial, please use it if good.
File Type: zip
Old Feb 17, 2009, 01:39 PM
burnings's Avatar
Originally Posted by yokohama_evox
Hi,
Hi Yokohama, I cant seems to open your attachment.
Old Feb 18, 2009, 08:50 AM
test
Old Feb 18, 2009, 09:04 AM
Please replace this line following with a description of speed limiter of contents of evo10base.xml.
<table name="Speed Limiter #1" category="Limits" type="2D" scaling="VehicleSpeed">
<table name="X" type="Static Y Axis" elements="2">
<data>Limiter ON</data>
<data>Limiter OFF</data>
</table>
</table>
<table name="Speed Limiter #2" category="Limits" type="2D" scaling="VehicleSpeed">
</table>
</table>
<table name="Speed Limiter #3" category="Limits" type="2D" scaling="VehicleSpeed">
</table>
</table>
and replace this line following with a description of speed limiter of contents of 52360016.xml.
<table name="Speed Limiter #1" address="53062">
</table>
<table name="Speed Limiter #2" address="53fb2">
</table>
<table name="Speed Limiter #3" address="533d2">
</table>
Old Feb 18, 2009, 02:42 PM
burnings's Avatar
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
kekeke I already did that and I have some interesting find. 53fb2 have a default value of 1392 and 533d2 has 46.
Anyone already tried these settings?
Old Feb 19, 2009, 02:27 PM
Deepseadiver's Avatar
any results?
Old Feb 21, 2009, 05:44 PM
EvoHarumi's Avatar
Perhaps, speed limit map is
53FC2
53062
533DA
This value is a guess from the magazine of Japan.
Old Feb 25, 2009, 12:54 AM
EvoHarumi's Avatar
It will test in this Address next week.
Old Mar 1, 2009, 08:30 PM
EvoHarumi's Avatar
There was no trouble though the test run was done.
However, truth is not understood.
Because it did't verify the address that other people showed.
Old Mar 2, 2009, 01:50 PM
burnings's Avatar
53FC2
53062
533DA
Yes these works!
Quick Reply: ECUFLash speedcut on JDM
