Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 28, 2008, 08:18 PM   #1
Personal Sales Rating: (4)
razorlab's Avatar
Drives: a laptop connected to your ECU.
The definitive EcuFlash Evo 10 thread
I'm starting this thread now since I had some free time over the thanksgiving holiday to actually put some time into making this.
This first posting will be ever evolving with updates and new information
EcuFlash tables and what they do:
Timing:
Timing Map High Octane
This is the main Ignition timing map that the ECU uses at all times if there is no substantial knock or other problems. This is based off RPM and Load.
Timing Map Low Octane
This is the secondary Ignition timng map that the ECU interpolates with the High Octane Timing Map depending on knock activity.
Mivec Intake #1
This is the adjustable Intake Cam map #1
Mivec Intake #2
This is the adjustable Intake Cam map #2
Mivec Exhaust #1
This is the adjustable Exhaust Cam map #1
Mivec Exhaust #2
Ignition Warmup Retard
This table is used on warmup and also used on the MR SST model for shift ignition retard
EGR Timing Advance
This table is used at cruise loads when the EGR is active to advance ignition timing
Fueling:
Fuel High Octane
This is the main fueling map that the ECU uses at all times if there is no substantial knock or other problems. This is based off RPM and Load.
Fuel Low Octane
This is the secondary fueling map that the ECU interpolates with the High Octane Fueling Map depending on knock activity.
Fuel Injector scaling and Latency
Injector scaling table is used for scaling the injectors (changed when adding larger injectors). Injector Latency table is used in conjunction with the scaling table to set injector latencies based on voltage.
Boost Control:
Base Wastegate duty Maps
This table is used to set your base turbo boost level off the first solenoid in the boost control system. It is based off wastegate (solenoid) duty cycle, TPS % and RPM. As you can see it is maxed out at 100% duty cycle at WOT from the factory
Base Wastegate Secondary Solenoid duty Maps
This table is used to set your base turbo boost level off the secondary solenoid in the boost control system. It is based off wastegate (solenoid) duty cycle and RPM.
Boost Target Engine Load Maps
This table is used for the boost error correction system to keep your base boost levels in check. It is based off a target load at TPS % and RPM
Boost Control Load Offset
This table number + the Boost Target Engine Load number = Target Load
Turbo Boost Error Correction
If the engine load is above or below the "Target Load" (see Boost Control Load Offset + Boost Target Engine Load tables) by a certain percentage, then actual wastegate duty cycle is added or subtracted depending on this table.
Boost Control RPM Crossover (Gear based)
This table is used to see the RPM/MPH crossover for gear based boost. In stock form, the GSR model does not take advantage of this feature (but can be tuned to do so). The MR model uses this feature to keep boost lower at approx 3000-5000rpm in 1st gear.
Boost Limit
This table sets the boost limit (fuel cut), based on load.
Boost Cut Delay Timer
This table tells the ECU how long the ECU will let the car be above the "Boost Limit" before it cuts fuel. 1000ms = 1sec
Drive by wire throttle mapping
These are huge maps, click here for full size (2492x1761):
More to come....
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Nov 28, 2008, 08:19 PM   #2
razorlab's Avatar
You can get the latest/greatest EcuFlash version from here:
http://www.openecu.org/index.php?title=EcuFlash
Here is the approx path a 100% stock Evo 10 takes through the Ignition and Fuel maps at WOT: (based on data logs of 5 different stock Evo 10s)
__________________
E85 Army
Offline
Old Nov 28, 2008, 08:27 PM   #3
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
The new standard is here. Now you'll start seeing some fast X's. With the ability for the end user to log, tweak, log, and tweak. You can know that your car is tuned right and make the adjustments where needed.
PROPS ALL
__________________
4WS TUNING + ETS GOODIES = 1 FAST 100K MILE EVO
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Offline
Old Nov 28, 2008, 08:32 PM   #4
Personal Sales Rating: (22)
honki24's Avatar
Drives: the friggin' wheels off.
Looking worthwhile to pick up a X.
__________________
Flatline Motorsports
Praise God!
Friends don't let friends type "RPMs"
"Motorsports are dangerous. No warranty or representation is made as to product's ability to protect the user from any injury or death. The user assumes that risk." -The warning on my helmet... lol
Offline
Old Nov 29, 2008, 06:29 AM   #5
Personal Sales Rating: (6)
tkklemann's Avatar
Drives: 2005 Evolution VIII
Nice Job Bryan. I am getting eager to start playing with an X..
__________________
Thomas..
2005 EVO GSR Charleston, SC
Offline
Old Nov 29, 2008, 08:16 AM   #6
Personal Sales Rating: (0)
Drives: Evo X MR, Nissan 350z
Awesome, thanks razorlab.
Offline
Old Nov 29, 2008, 08:27 AM   #7
supersilverMR's Avatar
Drives: WW 2008 EVO X, 2003 Evo FY VIII, 2003 Nissan 350Z Track, 2008 Victory Red C6 ZO6, 1999 Ford F250, 2002 Ford F350, 1993 Honda Del Sol
Thank you Tom Cruise, baby Jesus, And razorlab!!!
Offline
Old Nov 29, 2008, 08:33 AM   #8
Silver Sponsor
Personal Sales Rating: (30)
Mellon Tuning's Avatar
Drives: 05 EVO & 91 Stealth TT
nice write up Bryan, I think it's interesting that the high/low octane fuel maps are very similar. Also I'd like to see the USDM vs JDM maps for comparison
__________________
- Chris
MellonTuning.com - Stock ECU custom tuning Flash ROMs for your EVO done via e-mail or local - NOW Tuning Evo 7, 8, 9, & 10's!
Stock ECU/MAS Full weight EVO records:
Quickest and fastest on 93 octane 10.41 @ 135
Fastest on e85 139.80
Highest WHP 703
*Video* 10.41 @ 135 on 93 octane with stock ecu and mas
*video* 703awhp 539tq on e85 with stock ecu & mas
Online
Old Nov 29, 2008, 08:55 AM   #9
Rguy's Avatar
Awesome, thanks for the write up.
Offline
Old Nov 29, 2008, 09:18 AM   #10
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
Great stuff!!
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Offline
Old Nov 29, 2008, 10:34 AM   #11
Drives: 08 PB EvoX
Thank you so much. Look forward to anything you add!
Offline
Old Nov 29, 2008, 11:03 AM   #12
razorlab's Avatar
oops, I spelled definitive wrong, can a Mod change the title for me? thanks
__________________
E85 Army
Offline
Old Nov 29, 2008, 11:12 AM   #13
G20
Drives: WW 03 Evo and GG MR
thank Bryant for taking your times to write this. Now I have a reason to get an X.
Offline
Old Nov 29, 2008, 12:03 PM   #14
Personal Sales Rating: (1)
Drives: 05 EVO
Interesting how the wastegate duty cycle table for the first solenoid is RPM vs TPS. It makes perfect sense to adjust boost based on throttle position; you want more power/boost, you use more gas right?
That's probably why all the cars with MBCs running lots of boost a part throttle were causing the car to go into limp mode.
__________________
05 Evo
05 CBR 600RR
96 SE-R, sold... (t25, cams, brakes, suspension, 260whp/260wtq, 111mph trap, lots of road course time, blah blah)
Offline
Old Nov 29, 2008, 12:23 PM   #15
Personal Sales Rating: (5)
2008 Mitsubishi Lancer Evolution
My Garage
aftershock141's Avatar
Drives: OB Evo X, Boosted RSX
Send a message via AIM to aftershock141
Wow man awesome!
I'm used to doing this with Hondata Kpro so I was wondering if I'd really ever be able to do it with the X. I guess here's the answer.
__________________
OB Evo X w/ SSS and Aero
300+ whp Base RSX Crew #1
Special Thanks to: Suja1 Motoring and Dave at Whipfactory
Offline
Tags
10, 4g63, basemap, beta, download, ecu, ecuflash, evo, evolution, flash, forum, mr, rom, software, speed, stock, table, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
