Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 20, 2009, 08:47 AM   #556
ymr
Personal Sales Rating: (0)
Ecuflash Question. The 1.42 version works fine with Evo x 2009 ECU's??? Somebody told me Ecutek work only 2008 models. It this right? It's same with ecuflash?
Thanks
Offline
Old Aug 20, 2009, 01:39 PM   #557
Personal Sales Rating: (3)
2008 Mitsubishi Lancer Evolution
smanders's Avatar
Drives: 2008 Silver Evo X MR / 2008 Silver Odyssey Touring (wife)
Quote:
Originally Posted by DSP-S13 View Post
Quick ecuflash question.
I don't have a pc, only a macbook for my laptop. Does anyone know if I'll have any problems running parallells, (the mac software that allows you to run windows on it,) with xp to run ecuflash for my X?
Thanks,
-Ben
I ran one of the earlier 2.6 betas in a VMware Fusion XP VM on my Macbook Pro. The USB sample rates were very slow which is to be expected. To maximize EvoScan, I would install a native XP on a small partition on your macbook. I recommend setting aside 15GB-20GB.
__________________
Silver Evo X MR
Buschur Crossflow Catback | UR HFC Metal Substrate | AEM Intake | Nisei 1pc UICP | GrimmSpeed EBCS | Swift Springs | Cobb Rear Sway Bar
CarPC | OpenPort 2.0 | LC-1 Wideband | EvoScan 2.7 beta (Thanks EvoScan Team) | Tuned by smanders
AVIC-Z110BT | PAC SWI-PS
Need to install: Cobb Front Sway Bar
Offline
Old Aug 21, 2009, 09:35 PM   #558
Drives: 2008 Evolution X gsr
Quote:
Thanks for the input. I'm not sure I understand all of it, (ha!,) but I'll keep that in mind. Once I pick up the hardware/software, expect some pm's from me.
Thanks again,
-Ben
Offline
Old Aug 25, 2009, 10:32 AM   #559
SilverEvoX's Avatar
Drives: Silver Evo X
Quote:
Originally Posted by EvoX_SA View Post
so would adjust the latency by 5%. So change it from 532 to 558.
I am running the gunzo maps which should be about 11.8 afr in wot, but I am hitting 12.3. and I know it is unsafe I went back to the stock map when I saw this on my wideband.
What mods and what Gunzo map?
I had to modify my Gunzo 93 map a fair bit in the fuel department since I had an aftermarket FMIC because I was seeing low 12's for AFR's also at first. I've since dialed it back down to 11.5-11.6.
__________________
Buschur Racing Catback
Buschur Racing FMIC
AMS Intake
Nisei Polished 1pc UICP*
U-R Test Pipe
EcuFlash Tuned
Offline
Old Aug 25, 2009, 07:29 PM   #560
Drives: WW EvoX GSR
everyone is aware that the 3d boost tables are NOT correct in terms of the X axis - its not throttle %.
i am looking to find out exactly what it is, but yeah... something else to think about
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Old Aug 26, 2009, 06:57 PM   #561
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
I figured this a while ago, but I didn't have the time to figure it out. Looking forward to what you find.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old Oct 11, 2009, 05:56 PM   #562
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Yes, which is idle table is the correct one to set idle for the X? I want to know how to lower or raise the idle. Not sure which table it is.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Oct 14, 2009, 03:45 AM   #563
SilverEvoX's Avatar
If my fuel trims are way out of line aka +12.5 but I had tuned my AFR's accordingly via my wideband and it seems to be running the right AFR at the moment, should I even bother trying to dial my fuel trims back down to zero?
__________________
Buschur Racing FMIC
AMS Intake
U-R Test Pipe
EcuFlash Tuned
Offline
Old Oct 14, 2009, 05:17 AM   #564
Personal Sales Rating: (2)
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
Quote:
its the actual throttle plate position .. but they are close enough
I think renaming how we call things should make it easier ..
APP = Accelerator Pedal Position ( per FSM)
TPP = Throttle Plate Position (I made this up )
Offline
Old Oct 14, 2009, 06:29 AM   #565
Drives: WW EvoX GSR
i dont think its TPP either gunzo...
i can't remember why i thought that but i am pretty sure its not
__________________
Offline
Old Oct 23, 2009, 02:53 PM   #566
Personal Sales Rating: (1)
contagius's Avatar
Drives: 08 Evolution mr premium
This may be a stupid question but can I use the cable that came with my accessport to use with ecuflash. It would be awesome if I could.
__________________
AEM intake
Cobb accessport
AMS Intercooler
T1R uicp and licp
T1R B52 Coilovers
T1R downpipe
T1R testpipe
T1R 76s catback exhaust
Offline
Old Oct 23, 2009, 03:04 PM   #567
mrfred's Avatar
Drives: Evo IX MR
Quote:
Nope.
__________________
Offline
Old Nov 15, 2009, 01:14 PM   #568
White_EvoX_GSR's Avatar
Drives: 2010 Evolution X GSR
Ok guys i need a little help! Im getting an error message with my ecuflash when I try to connect to my ecu, I drive a 2010 evo x. Here is the error message and the options it gives me.
Unknown ROM Image
EcuFlash could not recognize this ROM image using any of the current definitions. You can choose one of the following options:
- Abort using this ROM image (with no chace of saving)
- Continue using this ROM image with no definition (no editiong or viewing, but saveable)
-Use wizard to create a new definition (NOT RECOMMENDED!!! -FOR DEVELOPERS ONLY)
Does anyone know why it is doing this?? How can I fix it?? Why doesn't it show me my maps??
thanks
Offline
Old Nov 15, 2009, 01:16 PM   #569
Unknown ROM Image
thanks
Offline
Old Nov 15, 2009, 02:18 PM   #570
Drives: E-X
you need a proper xml definition file for your rom. post up yr rom. also read up on how to enable mode23.
__________________
08 Evo X MR
99 Evo 6
Offline
Tags
10, 4g63, basemap, beta, download, ecu, ecuflash, evo, evolution, flash, forum, mr, rom, software, speed, stock, table, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
