Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 30, 2008, 03:53 PM   #31
Silver Sponsor
Personal Sales Rating: (30)
Mellon Tuning's Avatar
Drives: 05 EVO & 91 Stealth TT
true those numbers are arbitrary once you modify the car especially, but you probably will see 9's afr on the stock X, it's extremely rich from the factory.
__________________
- Chris
MellonTuning.com - Stock ECU custom tuning Flash ROMs for your EVO done via e-mail or local - NOW Tuning Evo 7, 8, 9, & 10's!
Stock ECU/MAS Full weight EVO records:
Quickest and fastest on 93 octane 10.41 @ 135
Fastest on e85 139.80
Highest WHP 703
*Video* 10.41 @ 135 on 93 octane with stock ecu and mas
*video* 703awhp 539tq on e85 with stock ecu & mas
Offline
Old Nov 30, 2008, 04:21 PM   #32
Personal Sales Rating: (4)
razorlab's Avatar
Drives: a laptop connected to your ECU.
Quote:
Yup low 9's 100% stock.
With a good drop-in filter (K&N, HKS, etc) it will lean out about .5-.7 or so.
I dyno tested a HKS drop-in filter last week and it gained 20whp/15wtq just dropping it in.
An AEM intake with the whole upgraded intake tube and MAF housing will lean the car out over 1 full AFR point.
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Nov 30, 2008, 04:25 PM   #33
Silver Sponsor
these X's are pretty damn amazing when you look at how well they respond to some basic bolt on, a good part of that is likely due to it leaning out a bit like you mentioned. The good news is that the stock ignition is likely pretty damn good considering it can cut through fuel in the 9's at 20psi + from the factory.
__________________
- Chris
Highest WHP 703
Offline
Old Nov 30, 2008, 04:28 PM   #34
razorlab's Avatar
I wouldn't say cut through. More like try and get through.
Every single evo 10 that has been on the dyno running low 9's have bucked and tugged pulling through the rev range choking on it's own fuel. All goes away once the car is leaned out.
__________________
E85 Army
Offline
Old Nov 30, 2008, 04:29 PM   #35
Silver Sponsor
ok so more like saw through then
__________________
- Chris
Highest WHP 703
Offline
Old Nov 30, 2008, 04:35 PM   #36
Personal Sales Rating: (54)
dustin03's Avatar
Drives: Evo X Evo VIII (SOLD) GSX-R 600 (SOLD)
So when will we be able to flash our cars and tune with this program?
__________________
Evo X Sponsored By ETS
Evo X All ETS bolt on's
367 AWHP 351AWTQ Tuned by Lucas English
www.extremeturbosystems.com
Northwest Evolutions President
SOLDAMS Power Club Evo VIII Tuned By Lucas English
19 psi 92 pump 403/320
28 psi 92/Meth 527/415
32 psi Race/Pump 606/464
Offline
Old Nov 30, 2008, 05:06 PM   #37
Personal Sales Rating: (0)
RogueValley's Avatar
Drives: 92 Stealth RT/TT| 08 EvoX RR GSR|Broke 06 GTO
I'd hate to ask this, but I figure i might aswell. Is the X running out of injector or pump on the high end. If the target AFR is say 9.2:1 at the cross section load (220) @ 7000rpm, and mods manage to lean it out to say, 11.3:1 at the same cross section, with the stock MAF housing does that mean the X is running out of fuel for the target AFR?
Also, I assume that you can higher the target AFR at lower RPMs if the above statement is true in order to try and attain an 11.3:1 AFR to try and smooth the powerband instead of just having ridiculous top end?
PS:Great work and diligance, razor!
__________________
Mods:
ETS 4" Intercooler Core, ETS UIC Pipe, ETS LIC Pipe, ETS Intake, Greddy Type R BOV, ATP Cat Delete, Custom 3" Borla Cat Back, Hallman Pro RX MBC, Autometer ES series Boost Guage
To Come:
ACT XT-SS, 1200cc Injectors, Twinscroll HTA GT3582R ETS kit (When money available).
Offline
Old Nov 30, 2008, 07:46 PM   #38
SiC
Personal Sales Rating: (1)
2008 Mitsubishi Lancer Evolution
SiC's Avatar
Drives: Lancer Evo X GSR
From what I have seen from my own testing, the AFRs lean out due to lower load values after changing the intake. When you change your intake, the MAF incorrectly senses the amount of air and your ECU will calculate the loads lower than it is suppose to be. This in turn will lean out your AFR and increase your IGN timing by hitting lower load cells.
Offline
Old Nov 30, 2008, 08:48 PM   #39
Drives: 08 PB EvoX
Quote:
This may seem like a silly question, I certainly hope not but here goes anyway:
With the tuning, you are basing your maps on "correct" load values, of which MAF readings are part of the equation. If you put an aftermarket intake, which skews the MAF reading, what should be done? Is there a mechanism to "correct" the MAF readings so that they are accurate again? Or is it simply enough to simply shift all your adjustments to the lower load levels?
I hope that made sense, I'm tired.
Offline
Old Nov 30, 2008, 08:54 PM   #40
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
That was a good question. There is a correction system that is typically called MAF scaling and is usually in the form of a 2D table of relative air flow vs MAF frequency. If the intake only skews the value a little bit, its usually ok to just shift all the table values.
__________________
Amsoil cone filter :: cardboard cold air box :: AMS LICP :: MIL.SPEC TB seals :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: GM BCS :: self-tuned :: 340wtq/380whp VDR 5.71 MD mode, 40°F
Donations always appreciated. Use "wassana at toloczko dot com".
Offline
Old Nov 30, 2008, 08:55 PM   #41
razorlab's Avatar
Yes there is a maf scaling table which the 10 has, I just haven't posted it yet.
__________________
E85 Army
Offline
Old Nov 30, 2008, 09:11 PM   #42
SilverEvoX's Avatar
Drives: Silver Evo X
Quote:
Originally Posted by Slo_crx1 View Post
You won't see sub-9's in the true AFR readings, it's only the way that EcuFlash shows the data to appear like an afr table. If you correlated a wideband to that table you'd see that what would appear to be in the 9's afr range would actually be closer to high 10's or so on a wideband. Keep that in mind when the program is released, you wouldn't want to set your tables to what you "think" they should sit at AFR-wise and end up with extremely lean conditions at high boost settings.
I don't understand why it displays it as the AFR then. Does the load just not get to a high enough percentage relative to that graph to hit the 8:1 AFRs? Also I realize it won't be anywhere near the 8000rpm range either. This is the graph I have. I will be tuning once I have a wideband installed to make sure that I'm not going too lean/rich but am just confused why it wouldn't be right on the map I have. Based on the knock maps they peak at 240% load so is that peak load in actuality on the fuel map? That shows 8.8:1 AFR according to the map, does anyone know what the cars actual AFR is then at 7k rpm per a wideband if it's not right around 9:1? Thanks and sorry for all the questions. ~Trent
Offline
Old Nov 30, 2008, 09:51 PM   #43
SiC
SiC's Avatar
Quote:
The highest loads I hit are around 260 at the highest boost range which is around 3800RPM. By 7000RPM it's usually in the 200-210 range.
One thing you have to remember about the fuel map is that it does not display real AFR values. If you see the map reading 11.1:1, it will not be 11.1:1 on a wideband most of the time. In my case, if my map reads 11.1:1, it'll usually read around 10.5:1 on a wideband, the actual values are richer for me than what is represented on the map. This may not always be the same for everyone, it can vary due to mods, climate, elevation, etc. The only way to see your actual values are to hook up a wideband.
Offline
Old Nov 30, 2008, 09:54 PM   #44
mrfred's Avatar
Drives: Evo IX MR
Based on whp figures, a stock 10 ought to be hitting about 220-240 load at around 3500 rpm and then tappering down to around 180 load at 7000 rpm.
At any rate, there are many factors (e.g., engine temp, air temp, barometric pressure, VE, etc) that must be accounted for by the ECU program when converting an AFR value in a table into a fuel pulse width. Its very difficult for the ECU programmers to to get the actual AFR to match the table AFR over the full range of RPM and load. There's always some difference. That's why its imperative to tune using a WB O2 sensor.
__________________
Offline
Old Nov 30, 2008, 10:00 PM   #45
Personal Sales Rating: (6)
Rguy's Avatar
I think a lot of you will find some nice gains with the JDM MIVEC maps. You can find them here.
http://filebox.vt.edu/users/brjones5...%20Exhaust.jpg
http://filebox.vt.edu/users/brjones5...t%20Intake.jpg
Offline
Tags
10, 4g63, basemap, beta, download, ecu, ecuflash, evo, evolution, flash, forum, mr, rom, software, speed, stock, table, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
