Everything you need to know about the stock RF system.
After spending the last 2 days searching, in my quest to upgrade my stereo, here is everything that you have wanted to know about the factory RF system. I am using this information so that I will be able to use the factory speakers with an aftermarket amp so they will at least last until I choose a replacement.
The information on the factory amp (2008 RF system) came from sparcomx. His thread can be found here: https://www.evolutionm.net/forums/ev...-amp-info.html
For future reference, next time just take a AA battery, and under the seat there just touch wires to each side. The corresponding speaker will buzz and you'll know which wire you've got
nothing. The OEM amp runs 8 channels, and each channel is individually crossed over. So if you hook an aftermarket amp up to those wires, wont have a crossover and it will just fizzle out. Also, each speaker is only 1ohm...so yeah you can't even hook them up. You have to replace the speakers too.
Hi
I'm in the process of replacing the speakers (front splits and coaxil rear) in the MY13 Evo. It came with the double din headunit but I have cables sticking under the seat and in the boot for the sub. Would you say the wires under the seat lead from the the front and rear speakers? I have a 4 channel amp I would like to stick in.?
I'll try the battery test anyway as mentioned by IKT but I thought someone might have installed an aftermarket system with the new headunit.
cheers
Chris
cheers
Chris
I have an 08 gsr without the rockford fosgate option and was wondering if i were to buy the factory nav headunit (rockford included am i right?), what speakers could i put in my 4 doors that would sound good? would i have to change the wiring? thanks
