Depo oem style headlights
#317
Wow these headlights look great. I wanted to do some hid but did not want to put them in the reflective housings. I would just put a thin layer sealant around the headlight to make sure it doesn't leak. With an HID kit these look great. Very impressed that I may order some of the future
#322
#326
So I recently did the HID retrofit on the Depo headlights and it turned out pretty well. Even though it was my first time working on headlights, I would give it a 4/10 for difficulty and it was pretty fun. Definitely things I could do better.
I'm not sure if this is fairly common, but the fitment was definitely about a 8/10. There is a noticeable gap on the lower edge under the projector and no amount of adjusting the bumper or headlight can get rid of.
#329
The physical headlight housings are the same size and mounting locations. May be some different wiring harness with the SSS package drls
#330
i recently had these retrofitted and got 55w 6k hids. However, for some reason the parking lights/license plate lights & ccfl halos (wired to parking lights) dont work now. mine is a 2010 non sss so i need the jrox kit for the DRL flickering issue. I was wondering if that would remedy the parking light problem. I've checked all fuses and wiring seems to be fine. When i take the HIDs out and put the halogen back in everything works fine. I'm just hoping the Jrox kit would fix the issue.
