fuse for dimmer
Old Oct 13, 2010, 02:05 PM
sohcpunk's Avatar
fuse for dimmer
Does anyone know a good fuse I can tap into that is used for dimming? (When the headlight turn on) A diagram would help greatly. Thanks!
Old Oct 13, 2010, 09:53 PM
sohcpunk's Avatar
Ok, I found the solution from reading the other forum. This worked like a charm.
Originally Posted by AMI CUSTOMS View Post
There is a 20 pin white connector pluged into the fuse box pin 10 or 13 is gray that is the wire you want for dimming your gauges.
