FP Green 08 GSR Results
I am posting this map from the other forum.
This is not my car. However, he is a member on the sister forum. I do not believe he posts here though.
Anyways I figured I would post the map here for comparison.
Note the smooth is different on the FP Green pulls than on the DOM II or FP RED pulls...
First thing I want to thank the guys at Surgeline tuning in Portland, just like the Cobb Plano shop these guys again show how much they appreciate their customers and bent over backwards to make everything we wanted happen. I know of other shops that just give you what they want but at Surgeline they work with you and try out your suggestions. Its a first rate shop with everything on hand to get the job done.
One of the first things you will notice is that I only have to run 24-25lbs boost to make power, Joeys car with the FP Red had the same results also. Once the Cosworth MX1 amas are in there is no need to run high boost. The cams open the airflow so perfectly that you no longer have to force it in so your also not creating higher air temps so more power. I looked at all the cam options for a long time and read all the data I could find, truly I think I found the winner with these.
My car now feels like an N/A car, the power is always there and just keeps pulling whenever you mash the throttle. Not a blip of knock anywhere to be seen and drives like a dream. When we first got to the shop you could tell they had some serious performance background. While we were there we saw 6 different GTR's (2 of the Hennesy's) and all bad ***. A ton of Subies and nearly all were still sporting their #'s from the race track. I hope to be posting tons of pics and some video soon
So it took some tweaking and various MIVEC settings to find the perfect spool and top end power. I think we managed to find a happy medium with the Cosworth MX1 cams. This turbo likes lean and low boost for making the most power effectively.
Dyno #1 is on 93 pump gas and #2 is 90% Meth
So mod list;
FP Green P&P
Cosworth MX1 cams, springs, and 1.3mm head gasket.
AGP IC, LICP, UICP, and CAI Intake.
Devils own Meth kit (#2 Dyno) 7 GPH nozzle
ATP downpipe & 3" cat back with test pipe
Forge WGA w/ Red spring
Perrin 3 port ECBS
Perrin BOV (Held like a Rockstar with no issues)
Cobb AP tuned with ATR
"Ignore the ugly boost curve its my fault we got focused on rough power vs being clean for now, also the smoothing is different between the dynos."
#1 93 pump 24-25psi
409WHP 352WTQ
#2 90% Meth 24-25psi w/ increased timing (Pressure didn't make power, with stock cams I'm sure it would be different.)
429WHP 366WTQ
93 Pump vs Dom 2.0 93 pump (Dom mods = Dom 2.0 Turbo, Stage 1 Kelford Cams, Perrin FMIC, AMS Downpipe, Speedcircuit Testpipe, Perrin Catback, Nisei, UICP/LICP/Tubo Inlet, DW 1000 Injectors.)
So mod list;
FP Green P&P
Perrin 3 port ECBS
#1 93 pump 24-25psi
409WHP 352WTQ
429WHP 366WTQ
This is it for the Green we pushed it to its limits, you may be able to grab more torque but as far as power up top it made more on less boost than it did with higher boost. My original tune was 28psi and we were able to match that power with more MIVEC and less boost. The tuner Tim Bailey that was doing this at Surgeline (Cobb facility in Portland) is a wizard at finding the sweet spot for power. We tried high boost, low boost, aggressive MIVEC and tame MIVEC, and various timing. We came to a happy medium after awhile playing with everything. The car was on the dyno all day and did 50 or more pulls.
This turbo like it lean, and if you heat it up by pulling through the gears it makes more power. At one point Tim pulled 1st through 4th and made about 15 more horse power just because the turbo was hot so when racing through the gears it will be putting down more power.
We also noticed whenever the fuel up top dipped into the 10's we got knock and lost power but when it was leaned back out into the 11's no knock and pretty good gains.
Also take into consideration that this is a Mustang dyno and our cars are about 240whp 240wtq stock on it. Also a stock GTR puts down 430whp and 430wtq on it as well. So when making comparisons look at the % in gains from stock.
__________________
__________________
i see its noted that the fp green pulls were in 4th gear...
can you confirm that the other pulls were in 4th also?
Id prefer to see the actual charts and not what is coming out of the dynodatabase, as its not the mustang chart...
good results though!
also, the last plot with the dom 2 and green looks like drastically different mods, different cams, in each of the overlays..
cb
cb
cb
cb
As far as drastically different mods, what exactly are you referring to? If you mean how much more I have listed compared to him you'll see just above the chart I listed his other mods. We are pretty comparable except for the Meth, hence the reason I compare him to my pump gas only.
So whats the verdict here the green is better then red if 400 whp is the goal? I thought the red was the more powerful turbo and doesn't seem worth it to go through all the installation with the weaker green turbo. also seems like each turbo had different mods, I'm not even sure there is a comparo here. I'm not bashing, just want to know the main differences between the 3 turbos. Anyone want to spend a week installing and dynoing all 3 on the same mods
So he sent me the Green and I started tweaking the tuning to find the sweet spot. With it on pump gas my car is never lacking for power in any gear. Its a lot like being in a vette or other powerful N/A car with power on hand all the time. No real power band to speak of its just there all the time. The Red like other bigger turbos just has that point where it snaps you back in the seat and all you can think is "Diff don't snap on me now".
I'm old now and don't need that huge power feeling anymore, 400whp is just what I was looking for and having it at 24psi of boost is a good feeling.
