Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Dyno Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 27, 2009, 11:44 PM   #1
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
TTP HIAG 2400cc injectors tested E85 TS 3586 Stock Motor!
So our new test HIAG 2400cc high impedance injectors were received today and we wasted no time getting them in one of our project Evo X's.
Due to the reverse location of the intake manifold and fuel rail on the Evo X versus the Evo 8-9, injector installs are cake. This car was no exception.
With the removal of two 12mm bolts from the rail and carefully removing the insulating spacers the fuel rail can be pulled back. In this case our project Evo X was already equipped with 900cc injectors with adapter harnesses. We swapped them out for our TTP HIAG 2400cc units and they went in as anticipated. Our new injectors do NOT require the adapter harness that the lower flow injectors needed to adapt the Evo X injector harness to the injectors. The OEM Evo X harness clips directly into the HIAG 2400cc units just like stock.
The decision was made to upgrade to larger injectors was in order to move to a fuel with a higher BSFC such as E85. After making the swap and spending a few moments experimenting with gasoline, insuring that the car would idle, run and drive without hiccup on 93 octane, scaling the latencies and sizing, we were able to use the previously tuned pump gas map without any issues. We were soon out of fuel in perfect timing to fill the tank with E85.
After scaling down the injectors for the new fuel with less energy, we were able to turn up the boost to 28-30psi only to run out of fuel on single walbro 255lph HP pump.
Here are the dyno power results:
We also tested the 1320' results to insure fueling, timing and knock was all in check. One of the awesome features of the dyno is its ability to record and document quarter mile WHP breakdowns which will illustrate how the power comes on in each gear as well as what power is made at what speed and RPM when rowing through the gears.
This Evo X as it stands at 3780lbs in the dyno computer ran low to mid 11's and here is how the power looked on that pass:
Our next step naturally is to add a 2nd fuel pump and hit the dyno again with the fuel pressure to support the customer's goals. We have not made a final decision on whether to swap the rod bolts yet as there is no way to measure bolt stretch with an in chassis swap of the bolts.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Oct 28, 2009, 01:31 AM   #2
Silver Sponsor +1
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Oct 28, 2009, 01:03 PM   #3
Personal Sales Rating: (0)
Drives: 08 RR Evo X
Pretty sweet setup he's running, curious to see the numbers with enough fuel running...
Offline
Old Oct 28, 2009, 01:29 PM   #4
Personal Sales Rating: (86)
I guess these are the injectors your working on for the 8/9 ?
how much will a set be?
__________________
early evo nut rockin
evo1 and evo 4
Online
Old Oct 28, 2009, 01:54 PM   #5
Silver Sponsor +1
They are not the cheapest, however they are less expensive than the nearest competiton.
According to the rules, we cannot disclose pricing in technical threads. I believe the pricing is listed in the Vendor Announcement section though.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Oct 28, 2009, 01:55 PM   #6
Personal Sales Rating: (3)
Evo a Mula's Avatar
Drives: 2008 evo 10 gsr, 2000 chevy venture L0L ex cars 2006 evo Se
Looks good I might run these
__________________
**DG Motors Sponsored**
Call DG Motors 631-957-8464 for all you Evo needs
Dyno Tunes
Installations
Full builds
Dyno time
Offline
Old Oct 28, 2009, 07:23 PM   #7
Personal Sales Rating: (2)
flyguycfi's Avatar
Drives: Evolution X GSR
Gona keep the redline at or near stock for reliablity? Just thought it might help in 4th in the 1/4, but idk if you just stopped the graph/pull early.
__________________
2008 Lancer Evolution X GSR
Baseline - 259whp @ 21PSI *stock turbo*
Tuned - 358whp @ 25PSI *stock turbo*
Tuned by TTP Engineering - Orlando, FL
Offline
Old Oct 28, 2009, 07:34 PM   #8
Silver Sponsor +1
Quote:
Power still climbing at 7600+.
We are deciding whether to install rod bolts or not despite not being able to fit the bolt stretch gauge in there from a bottom up in car install.
Next up is the addition of a 2nd fuel pump boost activated and turning up the boost.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Oct 28, 2009, 09:41 PM   #9
JuniorAWD's Avatar
Drives: mkiv TT 6spd
Send a message via AIM to JuniorAWD
Whats the difference between these and ID2000s from t1
__________________
Junior
World Record Most EZ-PASS Tickets
World Record Silver Subaru with Silver Rotas Tuned by a Dell D420
9.7@144 3500+lbs
World Record HP Subaru 1296whp @ 1.80 Correction
World Record Highest Correction Factor Used
World Record For Most Useless "World Records" held
Offline
Old Oct 28, 2009, 09:47 PM   #10
Silver Sponsor +1
Quote:
Eighty one dollars
Now back on the topic of the TS 3586 technical thread.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Oct 28, 2009, 11:31 PM   #11
flyguycfi's Avatar
Any idea of the difference in spool between this and the single scroll?
I suppose you haven't done a single scroll yet, but maybe an estimate?
__________________
Offline
Old Oct 29, 2009, 08:24 AM   #12
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
It would be nice if someone released a fuel pump upgrade that still fits in the stock location but delivers 40-50% more than the 255 LPH Walbro. It could even cost $300-$500 and people would still favor that over trying to run a double pumper setup. Something in the 360-380 LPH would just rock! I suspect the FPR would need to be replaced though since that is quite a bit more fuel, maybe Aeromotive has something we can adapt? What about the Nissan GTR R35, are they using twin pumps or a larger upgraded pump?
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Oct 29, 2009, 11:28 AM   #13
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
Quote:
blaqOps
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Oct 29, 2009, 12:55 PM   #14
murlo26's Avatar
Drives: 08 RR X GSR
Send a message via AIM to murlo26
Quote:
Originally Posted by GST Motorsports View Post
blaqOps
Still waiting on info with this myself Did you guys retune that DOm2 with this yet GST?
Sorry for the offtopic TTP.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Old Oct 29, 2009, 02:19 PM   #15
Plat Vendor
Personal Sales Rating: (40)
ETS Michael's Avatar
Drives: Operation Damaged Goods - 03 Yellow Evo
Send a message via AIM to ETS Michael
Scott -
Great Job! I had a chance to check out a set of injectors last night. Impressive to say the least. E-85 / 2400cc / High Impedance - What more could you ask for?
Thanks,
Michael
__________________
Michael
Site: Extreme Turbo Systems
Pho: 360-263-3748
AIM: ETS MichaelR
Evo X Stock Block/Stock Head - World Record - 681whp (ETS 3586 Turbo Kit)
Evo X ETS Built Motor - 2.0L World Record - 718whp (ETS 3586 Turbo Kit)
1117whp Evolution 8 (ETS 42R Turbo Kit)
ETS 6.0" Intercooler - ETS 45R Turbo Kit - ETS Exhaust - English Racing Motor - English Racing Tune
ETS Holiday Specials On Our Website!! 20% Off ETS Products!!
Offline
Tags
2400cc, injector, injectors
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
