Nov 2, 2009, 08:25 AM
#46
Personal Sales Rating: ( 3)
Drives: Evo X MR
In order to be safe to run this turbo on stock fuel system, how much max power should be tuned to?
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Offline
Nov 2, 2009, 10:06 AM
#47
Personal Sales Rating: ( 2)
Drives: Evo X MR
Quote:
Hey LVSBB6,
I'm looking to add an FP Green = 54 LB/MIN or a Dom 2.5 = 47 LB/MIN (Stock Turbo = 40 LB/MIN) to my basically stock Evo X MR DD and from what I've read it looks like 375WHP and under would be safe on the stock fuel system but that all depends on your tuner. Hopefully the FP Green will provide streetable boost characteristics compared to the stock turbo because I like that FP uses a stock turbo to start with so it has the Mitsu Part#'s etc and appears stock on the outside. If you look at 2Fst4U's Dyno Sheet it looks like the 50WHP gain was at 7,000RPM other than that the gain over the stock turbo was minimal. Below is some good information:
1. 2Fst4U's Dyno Sheet - http://forums.evolutionm.net/attachm...pgreendyno.jpg
2. Meat-EVO's Review of the FP Red and turbo upgrade in general makes me think twice http://www.**********.com/forums/showthread.php?t=20342.
3. Also if you look at ETS they claim to have made 422WHP on a STOCK Fuel System - http://www.extremeturbosystems.com/
"Today we had one of our local customers bring up their Evolution X with the ETS 35R Turbo Kit. The car made amazing power on the stock fuel system! We made 422whp at 19psi (Lower Then Stock!?) The car should easily make 450whp on pump gas. The spool is amazing... Full boost around 4500rpm!!"
__________________
IVEY TUNED
HKS l COBB
312WHP l 292WTQ @ 25psi
Offline
Nov 2, 2009, 10:17 AM
#48
Drives: Evo X MR
^Thanks for the info 08MR. I`d take a fast spooling turbo with overall average gains over laggy turbo with just top end power any day, especially on a daily driver MR. The Green is probably the best streetable upgrade turbo option right now.
As 2Fst4U pointed out, his tune was rather conservative so I think with a bit more timing and boost, the gains will be even more impressive.
I also like the stock housing look of the Green. And sticking with stock fuel system you can always revert back to stock map if you ever need to go back for warranty purpose.
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Nov 2, 2009, 10:45 AM
#49
Drives: Evo X MR
I agree 100%. I want to use the stock fuel system etc. so in case I have to go back for another "recall" I can just uinstall my Cobb AP and have it run on the stock MAP.  Sounds like you're trying to do the same.
__________________
IVEY TUNED
HKS l COBB
Offline
Nov 2, 2009, 01:27 PM
#50
Drives: Evo X MR
Was there any issue to tune with stock pump/bigger injectors combination? any sign of leaning out in the top range?
Quote:
Originally Posted by JohnBradley
Stock pump, 24.5-25psi
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Nov 5, 2009, 06:53 AM
#51
Personal Sales Rating: ( 0)
Drives: 06 Sti
thats awesome numbers for an green. its amazing how much more power people are putting out on the newer motors. both sti's and evo's
Offline
Nov 17, 2009, 10:07 AM
#52
Drives: PB Evo X MR
No issues to my knowledge when tuning and not having any atm. I had talked with another owner who ran stock pump and bigger injectors on a red with no issues also.
__________________
2008 PB EVO X MR
FP Green, ETS Intake, ETS UICP, ETS V2 Exhaust, ETS Test Pipe, ETS O2 Downpipe, FIC 900cc injectors, AEM electronic boost controller, AEM Wideband
English Tuned @381.51awhp/311.98awtq
...and no transmission issues.
Offline
Nov 17, 2009, 10:22 AM
#53
Drives: Evo X MR
I`m tuned with 255 walboro with 800cc injectors, my IDC is at 80% at the top end.
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Tags
510, deatschwerk, evo, fp, gg, green, hp, jun, lip, mr, ngk, racing, red, tested, todd, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
