Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Dyno Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 25, 2009, 07:04 PM   #16
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
Quote:
Originally Posted by kozmic27 View Post
Did your tuner intentionally keep the torque down because of the SST?
Yes we did. No sense in deliberately trying to find the edge of slippage without having the tools to combat it. As soon as we get a trans temp gauge and a cooler on it we'll push it a little further. The boost and timing are both still low on this particular setup so we have plenty of room to go before its tapped out.
thanks Stoked
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
Old numbers- 574whp@29psi stock block, 92 octane, ETS/FP3586...New Build.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds, $1000 with ETS Magnus pipe, dual rail available also.
We choose GSC cams
FIC Master Distributor
OmniPower Dealer
Offline
Old Oct 25, 2009, 07:04 PM   #17
Personal Sales Rating: (2)
08MR's Avatar
Drives: Evo X MR
Quote:
Originally Posted by 2Fst4U View Post
So I got my FP Green installed this week along with new injectors, boost controller and DP. As you can see on the chart we got 381awhp(+50hp...ish). I attached my old numbers from prior(minus FP Green, inj, DP, AEM electronic boost controller) There is a comprison on the new chart to one of my old runs, but was not the best run I made back in July.This is still running the STOCK intercooler and ECU on pump gas. The turbo has the 18psi WG and is NOT ported. You may also want to take into account the difference in the weather conditions between the two.
So you may ask how or why do you have a FP Green. Well this is one of the first ones(if not the first one) on an X(Robert at FP can confirm or deny that). Nonetheless, I had heard a rumor that this was going to be offered and asked really nicely if they would let me get one and be a sort of beta or test car. Being that I have the MR I was a bit concerned about the transmission and my car is a DD so I didn't think the red would be quite as user friendly for me nor do I want to run 700hp...at least not yet.
I have not driven it much, but from just the drive home I can tell you...WOW! What a huge difference over the stocker. I have to admit after my first set of mods and tune I was quite underwhelmed with how the car drove. Although I had gained 90+whp it didn't seem to be as "peppy" as when it was all stock, for whatever reason. After having added the green it made a huge difference at least by the butt dyno. The car gets going quick and smooth and for whatever reason it seems to shift better as well.
This tune is pretty conservative from talking with Lucas because we were not sure what it was going to do or how it was going to respond. I believe there is more in the car if we were just trying to push higher numbers. Because I don't have my FMIC installed yet and have not added/modifed the transmission cooler yet he felt it best to not push too hard. In addition, the weather is much cooler and didn't want to potentially run into problems when driving in warmer weather. Hopefully Lucas can chime in and give better or more specific technical feedback for anyone interested because I will not be much help with that.
So this could be another option to consider for your DD or MR if you are not looking to put down ridiculous numbers just to get back and forth to the grocery store. If I missed anything ask away and I will do my best to answer.
I'm looking to go a similar route with my Evo X MR (Daily Driver).
  • FP Green
  • Fuel Pump
  • 800cc Deatschwerks Drop-In Injectors
I would like to make 350-360WHP and was wondering:
- Did you upgrade your fuel pump, If so which one?
- How much boost are your currently running with this tune?
__________________
IVEY TUNED
HKS l COBB
312WHP l 292WTQ @ 25psi
Offline
Old Oct 25, 2009, 07:06 PM   #18
Silver Sponsor
Stock pump, 24.5-25psi
__________________
We choose GSC cams
OmniPower Dealer
Offline
Old Oct 25, 2009, 07:13 PM   #19
08MR's Avatar
Drives: Evo X MR
Quote:
Very Nice! In your opinion would I be asking too much of the stock injectors and the stock fuel pump trying make 40WHP by just installing an FP Green if my target is around 350WHP? The reason I ask it with my current setup I can uninstall the Cobb AP and go to the dealer without issue and if I install the FP Green alone I will still be able to do that since from what I understand FP uses a stock Mitsubishi Turbo.
__________________
IVEY TUNED
HKS l COBB
Offline
Old Oct 25, 2009, 07:21 PM   #20
Plat Vendor
Personal Sales Rating: (40)
ETS Michael's Avatar
Drives: Operation Damaged Goods - 03 Yellow Evo
Send a message via AIM to ETS Michael
We just finish designing a tranny/oil cooler core for this vehicle. It won't be long tell we have a unit released and ready to roll!
__________________
Michael
Site: Extreme Turbo Systems
Pho: 360-263-3748
AIM: ETS MichaelR
Evo X Stock Block/Stock Head - World Record - 681whp (ETS 3586 Turbo Kit)
Evo X ETS Built Motor - 2.0L World Record - 718whp (ETS 3586 Turbo Kit)
1117whp Evolution 8 (ETS 42R Turbo Kit)
ETS 6.0" Intercooler - ETS 45R Turbo Kit - ETS Exhaust - English Racing Motor - English Racing Tune
ETS Holiday Specials On Our Website!! 20% Off ETS Products!!
Offline
Old Oct 25, 2009, 07:39 PM   #21
08MR's Avatar
Drives: Evo X MR
Quote:
Congrats on the Evo X ETS Built Motor - World Record - 718whp (ETS 3586 Turbo Kit) I saw the video (10.8 @ 133) and it sounded like tip off at an NBA game when that thing took off.......... Poor tires
__________________
IVEY TUNED
HKS l COBB
Offline
Old Oct 25, 2009, 07:59 PM   #22
08MR's Avatar
Drives: Evo X MR
ETS,
If you made 422WHP on the stock Evo X fuel system, Do you think I would be able to safely make 340-360WHP on the stock Evo X fuel system by installing only an FP Green?
"The car made amazing power on the stock fuel system! We made 422whp at 19psi (Lower Then Stock!?)"
__________________
IVEY TUNED
HKS l COBB
Offline
Old Oct 25, 2009, 10:04 PM   #23
Silver Sponsor
We have done 375 on the stock fuel system. Todd's car got FIC900s since we need a big high impedance injector in there sooner or later and because our goals were far higher than the 422 we knew we might as well get them out of the way now.
If you wanted to do a Green and only make 360 you should be fine.
__________________
We choose GSC cams
OmniPower Dealer
Offline
Old Oct 25, 2009, 10:30 PM   #24
Personal Sales Rating: (0)
Adept's Avatar
nice numbers man
Offline
Old Oct 25, 2009, 11:29 PM   #25
Silver Sponsor
Personal Sales Rating: (8)
Lucas English's Avatar
Drives: '04 EVO SSL
Yes I keeping the timing down some to save the trans over time.
Also remember the Dyno Jet TQ are real and its real Easy for a Mustang operator to have the RPMs off by just a few 100rpm which will change TQ # ton.
Also the way the MR stays in its peak hp all the time you dont really get a feel for hp gains over the Curve like you would in a manual trans ware you will roll on it from low RPM sometimes. Since the Green gave us the big gains above 6k you can really feel it. Since the MR keep you at peak HP almost all the time.
__________________
ETS powered 766whp '04 EVO GSC S2 cams , AEM,E85,Magnus Cast
Mods for 2008 (Still pushing the stock turbo)
http://forums.evolutionm.net/drag-racing/365817-getting-closer-10-882-125-stock-ix-turbo.html
www.EnglishRacing.net sales@englishracing.net
www.Extremeturbosystems.com for all your Turbo and IC needs.
English Racing 360-210-7484
MAGNUS Motorsport Cast Manifolds in stock (PM for sales), special pricing on dual rail manifolds.
Offline
Old Oct 26, 2009, 12:56 AM   #26
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
Quote:
Indeed. We had a GTR on the dyno the other day that synch'd at 4k. We usually synch at 3k and I synch'd at 3k out of habit on Saturday with it still set at 4k.
The car (evo 9 turbo) didn't spool till 4500 rpm and peak torque #'s where 190 @ 5000 rpm. I resynch'd at 3k and "magic" torque jumped 60wtq (with basemap) at 3750rpm.
Really easy to do evil with the mustangs.
- Bryan
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Oct 26, 2009, 08:02 AM   #27
08MR's Avatar
Drives: Evo X MR
Thanks for the information, It's a daily driver so 340-360WHP is plenty.
__________________
IVEY TUNED
HKS l COBB
Offline
Old Oct 27, 2009, 08:37 PM   #28
EvoM Moderator
Personal Sales Rating: (24)
atombomb33's Avatar
Drives: Evo X - GSR
You guys got some cajones to put that turbo on the MR
Good luck to you. Will be interesting to see how the TC-SST holds up. Could be a nice case study for the community
__________________
2008 Evolution X - GSR Apex Silver /// SSS - Aero - Navi
Forum rules & regulations
Offline
Old Oct 27, 2009, 08:46 PM   #29
Personal Sales Rating: (29)
gfng's Avatar
Drives: evo VII evo VII
green looks promissing on the evo X
Offline
Old Oct 28, 2009, 12:23 PM   #30
08MR's Avatar
Drives: Evo X MR
I was thinking of going with the FP Green on my Evo X MR as well. 381WHP/311WTQ with the FP Green seems like a reasonable setup for an Evo X MR daily driver. Especially when Chris@Cobb made 362HP and 407TQ on the stock turbo on his daily driver Evo X MR with the following:
MOD List:
COBB AccessPort
COBB Catted turbo-back exhaust
COBB Hardpipe kit
COBB Silicone inlet
COBB Tubular swaybars
COBB Lowering springs
K&N Panel filter
HOA 3-Port solenoid
Walbro fuel pump
DW 1000cc/min injectors
Lots of E85
MR 362hp, 407tq stock turbo &E85
__________________
IVEY TUNED
HKS l COBB
Offline
Tags
510, deatschwerk, evo, fp, gg, green, hp, jun, lip, mr, ngk, racing, red, tested, todd, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
