Oct 21, 2009, 06:07 PM
Personal Sales Rating: ( 0)
Drives: 03 RSX Type S, 08 Evo X
EvoX - New Results On FPRed w/Cosworth Drop In Filter + other graphs
just thought i post up more results i got recently out of my EvoX
next to be posted up is what i can get on VP MS109, then its cams and ic piping (dont know which order ima do these in or if at the same time)
these things remain constant for all graphs
stock motor, stock intercooler and piping, stock air box, 91 octane, tuned by me via ECU Flash, Logged with Evoscan
as noted in the first graph, my EvoX baselined at 259hp 295tq on this dyno
currently im making 159hp, and 97tq more over stock
1st graph is bone stock vs stock turbo/FullRace Manifold/UR downpipe/UR dual ex/UR race cat/tactrix 3port boost solenoid
2nd graph is 1st mods vs new additional mods(FPRed/UR divorced o2 housing/UR testpipe w/integrated mini muffler/Injector Dynamics 1000cc)
3rd graph is 2nd mods vs new additional mods(Cosworth Drop In Filter)
1st set
2nd set
3rd set
__________________
03 RSX Type S_T 2069cc_9.5:1_GT3582R
08 Evo X_FullRace_FPRed
K20A>4B11
Offline
Oct 21, 2009, 06:11 PM
Gold Sponsor
Personal Sales Rating: ( 9)
Drives: 570whp stock block IX, 66Chevelle, EK hatch DD.
great results
__________________
Force-Fed Performance/ A Division of EPIC MOTORSPORTS
http://www.myspace.com/forcefedperformance
834 Stanley Street Fayetteville NC 28306 910-920-1140 Force-Fed (919)300-9673 Kelford Cams ACT Clutches Mishimoto Radiators/Thermostats Aeromotive Products Full-Race ETS Amsoil Authorized Dealer
Offline
Oct 27, 2009, 11:57 AM
Silver Sponsor
Personal Sales Rating: ( 6)
Drives: E39, R14, S14, EG coupe, F350
thats really a fantastic powerband -- 200 wtq @ 3000rpm! must be a blast to drive
Offline
Oct 27, 2009, 01:22 PM
Personal Sales Rating: ( 2)
Drives: '06 WW IX MR
Very nice numbers, Daniel!
-Jalal
__________________
TeamXXXRacing|Northeast Motorsports Club|Online Store
TriStateEvo|http://forums.tristateevo.com/index.php
XBOX Live Gamer Tag: MJ23FE
THE WANT LIST
POWER
Full Re-Tune
BRAKES
SmikeEvo Pad Combo
Performance Friction 2-piece Front Rotors
SUSPENSION/CHASSIS
Whiteline Sway Bar Set - 26mm Fixed Front/24mm Adjustable Rear
Perrin Stout Mounts
Perrin Positive Steering Response System
Offline
Oct 27, 2009, 02:53 PM
Drives: 2010 GG Evo X
just a question about your first graph, if I am reading it right your hitting 2X.XX boost which seems odd since stock boost is alot less then that, is your base line, stock mod wise w/ a tune/increased boost?
Offline
Oct 28, 2009, 09:18 PM
Quote:
the baseline was the car bone stock with 600 miles on the car nothing done at all...
this is what the car boost stock, but seems correct, comes in at 23.5 psi and falls to liek 13 psi by redline
where did u get ur stock boost level info from?
__________________
K20A>4B11
Offline
Oct 28, 2009, 09:19 PM
Quote:
-Jalal
thanks
Quote:
yep, feels decent, not too much given up from switching to the Red, now i need about 100 ft lbs more torque to equal the same feeling as my rsx
__________________
K20A>4B11
Offline
Oct 28, 2009, 11:23 PM
Drives: TB Evo IX
Kind of off topic but,
How does your car start after it's been sitting for about 1-2 hours after a drive?
__________________
11.1@129mph - 521whp via Dynojet
Offline
Oct 28, 2009, 11:31 PM
Personal Sales Rating: ( 3)
Drives: Evo X MR
Excellent comparsions! thats a very high reading dyno btw
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Offline
Oct 29, 2009, 07:56 AM
I thought the Evo X's stock bosot was 20 PSI?
I know the rule of thumb is 5 HP for every PSI, so your higher then normal base like, I thought was from extra boost. 24 PSI - 4 = 20 HP, 260 HP = 20 = 240, which is in the average for an evo of 220-240.
Offline
Oct 29, 2009, 10:16 AM
starts right up, no issues
__________________
K20A>4B11
Offline
Oct 29, 2009, 10:28 AM
the ultimate test is to use the big asfault dyno, the 1/4 mile...i may go thtis weekend to see what i can pull
Quote:
thanks....
thats why i listed the baseline...goal here is to show the before and after results (the gains over stock), not have a dyno chart shoot out with other tuners/shops
also this dyno in awd config reads almost the same as other local socal shops,
also if you want to compare it with another dynos just take out the difference in baseline numbers....
i.e. GST Motorsports dyno baselines an EvoX at approx. 22X hp; my Evo baselined at 259 here, so 259-220 = 39hp higher than a mustang...
If you want to do a rough comparison on another dyno you can guestimate my car is making 379 hp on GST's dyno... i went to their shop once to pick up boost pills, maybe next time im up there ill baseline on that dyno to see how much i actually put out againt my bench guess if they have time
i dont know what other people were getting but htis is what mine did...
with these small turbos there isnt a constant hp gain with boost, the more air u push the hotter it may get thus lowering the gain unless you hae adequate cooling
the power numbers may be higher/different than than others but the boost is spot on, same as logged
also see reply above
__________________
K20A>4B11
Offline
Oct 29, 2009, 10:51 AM
Drives: 2010 WW Evolution X
yep not all turbos give out same amount of flow/air...and not all turbos can breathe at high rpms..
anyways, very nice info for the comparisons...thanks!  btw, i noticed that the boost between the 1st set mods and 2nd set of mods...i'm not sure what made your boost hold much longer but i like it...did you have your red wgspring changed? i mean i know the red can breathe better in high rpms compared to the stock turbo...just wondering and wanted to know..
Offline
Oct 29, 2009, 12:08 PM
i switched out the stock setup for a tactrix 3 port solenoid on all pulls showing higher boost
when i switched to the fpred the boost held better up top by itself
im still on the stock actuator (no springs have been changed) i verified this by doing pulls with the boost controller turned all the way down on the stock turbo and fpred and they made the same boost, approx 13-14 psi
with the new setup the boost is still falling a bit, i have more room for adjustment on the controller but decided to leave it that way for now...
things that will help the taper involuntarily will be hardpipes and a different acutator...these are probably next on my mod list after a preliminary race gas tune
__________________
K20A>4B11
Offline
Oct 29, 2009, 12:37 PM
^^ thanks
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
