Oct 12, 2009, 12:00 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Quote:
Originally Posted by GST Motorsports
Yes, with room to spare @ 60% WGDC
Holy fok. I can't wait for the final tune!
Offline
Oct 12, 2009, 12:02 PM
Personal Sales Rating: ( 0)
Drives: 08 RR X GSR
Quote:
I know right. Well Scheides I may have found a replacement turbo
Once I see these final numbers I might be sold.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Oct 12, 2009, 12:08 PM
Drives: 05 Evo8 SSL
WFIW Bryan helped sell me on the BBK when he had a few E85 examples with numbers I could shoot for (mustang reads similar to our local dyno dynamics) I was sold!
Offline
Oct 12, 2009, 12:35 PM
Drives: 08 RR X GSR
The only thing I am fighting with his logic I guess.
In theory the red should be able to make more power at the sacrifice of spool.
But from what I have seen I think its pretty much the same numbers as the DOM2 if not lower. The red's have been showing decent numbers, but nothing like the ones from the 8/9's.
So this is why I am torn, I guess I am waiting to see if a red makes 450ish on a dyno dynamics or 500 on a dynojet. But the Dom2 looks like it should be able to do that too.
So I stand in the middle waiting I guess. But the Dom2 seems to be making some killer numbers on pump, so with E85 or Meth I think it should really shine.
__________________
UR Testpipe
AMS UICP
Perrin 3-port
Cosworth MX1 Cams
Offline
Oct 13, 2009, 12:28 PM
Drives: ****baru STi
I haven't tuned a Evo 10 on a FPred with E85 yet. From what I have seen so far though, the Dom 2 seems to spool much better than the red, which makes sense as the wheels are supposed to be smaller.
I'll post a boost plot when the tune is finished.
what makes it spool better then?
Offline
Oct 14, 2009, 11:49 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Well looks like we finally figured out the issue.
Simple as it ran out of single pump. The owner put in a spare walbro, with the pressure relief valve punched in (just for testing) and the AFR's went from 13 up top to low 11's.
This is interesting as this is MUCH lower than when the 8/9's run out of single pump on E85 on our dyno. Currently we have a 9 running 480whp with a single, and a bunch at 450-460 with stock fuel rails.
The new BlaqOps progressive double pumper for the Evo 10 is going in and we'll see what she makes!
Offline
Oct 14, 2009, 12:01 PM
Drives: 08 RR X GSR
Linky for the double pumper?
You still are using the DW1000's right?
__________________
UR Testpipe
AMS UICP
Perrin 3-port
Cosworth MX1 Cams
Offline
Oct 14, 2009, 12:03 PM
Silver Sponsor
Drives: EVO, STI
No link for progressive double pumper yet. Expect announcement soon. It's already out for the 8/9.
Yes, DW1000's and AFPR.
Offline
Oct 14, 2009, 12:22 PM
IDC's for the DW1000's so far?
Offline
Oct 14, 2009, 12:23 PM
Silver Sponsor
Drives: EVO, STI
Quote:
I'll let you know once the car comes back in with the fueling issue fixed.
Was at 120% IDC with the fueling issue.
Offline
Oct 15, 2009, 10:39 AM
Any idea why the HB Speed tuned car with similar mods didn't run out of fuel? It seems to have the same set-up.
Fp Red, E85, 1000CC, zooom
Offline
Oct 15, 2009, 10:47 AM
Drives: 08 RR X GSR
^ Probably because these cars aren't making the same power.
I think HB Speed has a dynojet which reads quite a bit higher.
__________________
UR Testpipe
AMS UICP
Perrin 3-port
Cosworth MX1 Cams
Offline
Oct 15, 2009, 10:58 AM
Yea, and I missed the part where he states he was at 100% IDCs @8000. So it looks like he has similar issues.
I believe the GST tuned car has a pressure gauge plumbed in. Otherwise I'm not sure how you can tell whether it's injectors or supply.
That 5/16 line seems awfully small to be running all this fuel through. My background is in V8 land pumping through -8, -10 and -12 hose.
Offline
Oct 15, 2009, 12:06 PM
Drives: 05 EB Evo SSL, 98 TSi AWD
Great numbers! I'm excited to see the final tune.
Offline
Oct 18, 2009, 07:14 PM
Drives: Fast
impressive
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
