Aug 30, 2009, 10:05 PM
Personal Sales Rating: ( 2)
Drives: Evo X MR
GM 3-port, Forge WGA + an amazing tune from Chris @ EFI on my MR
Last time I went to EFI, Chris was trying out some things with my MR and couldn't get the ECU and stock boost control system to hold the boost. Thanks to hybridKOOP, we installed the GM 3-port and added a Forge WGA to support it. We were able to get tq as high as 350, but the transmission didn't like it  so we obviously scaled it back some. I will let the dyno sheet speak for itself.
Thanks again Chris for an awesome tune!  304whp/311tq on EFI's Mustang dyno. The car feels amazing! The power hits hard, throttle is smooth, and shifts are crisp!
Mods:
Greddy Ti-C
Cobb downpipe
Cobb high flow cat
ARC intake
ARC FMIC
GM 3-port boost solenoid
Forge WGA
Offline
Aug 31, 2009, 07:00 AM
Personal Sales Rating: ( 0)
Drives: 2010 WW Evolution X
^^ how much boost are you running? do you have a boost plot? TIA
Offline
Aug 31, 2009, 07:32 AM
Drives: Evo X MR
The GM 3-port boost solenoid replaces the stock 2-port system and all pills; there are no more pills. The ECU controls boost just like stock and the Forge WGA spring is set to 19psi. The dotted line is boost.
Offline
Aug 31, 2009, 11:43 AM
Drives: 2008 Hayabusa
Thanks for the compliments Andy.
Here is his run on our dyno database.. Select any variable on the dyno plot, then mouse over to track the boost anywhere on the plot: http://efilogics.com/dyno/index.php?...&torque=1&gb=0
Thanks,
Chris
Offline
Aug 31, 2009, 11:53 AM
Drives: 2010 PB Evo X MR Touring
Am i looking at the graph right? is there a loss on the low end?
Also how did the SST react to the 350 ft lbs? Details? did the ecu cut power, slip clutches, "slow down" warning, etc?
Offline
Aug 31, 2009, 12:03 PM
Personal Sales Rating: ( 3)
Drives: Evo X MR
nice gains overall, but looks like you lost quite a bit of spool up time.
you said you hit 350wtq at some point, but why backed off so much to 311wtq?
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Offline
Aug 31, 2009, 12:17 PM
Drives: Evo X MR
What do you mean by quite a bit? If you look at where the two boost graphs overlap, I lost maybe 100 RPM of spool time? I think that's pretty inconsequential. I hit almost 27psi at roughly 3,500 RPM...that's pretty impressive if u ask me.
At 350wtq the SST just gives up and lets go...It would not hold the power. I heard it, but Chris can elaborate on what it actually did.
Offline
Aug 31, 2009, 12:50 PM
Quote:
ahh my bad sorry...  anyway, did you have any pre-load in the forge wga? i was looking into this setup..TIA
Offline
Aug 31, 2009, 02:31 PM
Drives: Evo X MR
Quote:
Forge WGA spring comes preset with 19psi...the stock spring is 12 psi IIRC
Offline
Aug 31, 2009, 03:18 PM
When the car hit 28psi (350wtq), the transmission just let go, like you put it in neutral during the pull.. It did this twice, once at 28psi, and again at 27psi (335wtq).. This really discouraged me from pushing the car hard, so we backed it down at peak torque by manipulating the MIVEC / Target Boost / Fine and Coarse WGDC tables.. The drop in power before peak torque is the product of the tune being backed down for safety of the transmission.
Because we have a Mustang 500SE, the 350wtq may be a little more than the SST is really happy with
Thanks,
Chris
Offline
This is correct.
Offline
Aug 31, 2009, 03:45 PM
Drives: Evo X MR
Thanks for the info Chris. I think people should be well aware of what happens on the MR when the tq gets too high.
Offline
Sep 1, 2009, 04:18 PM
Drives: Evo X MR
Sounds like you were hitting the air flow limit and the torque tables are not adjusted properly. When SST doesn`t like the power it works the magic of holding off power, neutral pull is another issue...
Thanks,
Chris
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Sep 1, 2009, 04:59 PM
Quote:
Interesting you say that, because every X we have tuned, when we hit the Air flow limit, or the tables are not scaled properly, it would throw a CEL and go into Limp mode, Andy's car did not show these symptoms.
- Chris
Offline
Tags
3port, 617g, coarse, evo, evox, forge, gm, gruppe, port, solenoid, tune, wga, wgdc  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
