Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Dyno Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 26, 2009, 11:20 AM   #1
Personal Sales Rating: (1)
meat_EVO's Avatar
Drives: Evo X
fp red, 93oct, 25psi, stock motor... pre numbers
93 octane
25 psi
no knock
ecuflash/evo scan
only adjustment to the tune was a cut and past of HIBOOST mivec and air flow tables.
stock ignition timing
Wanted to get a base pull on just pump, and see what i could pull out of her on very mild adjustments.
mods..
Grimmspeed - manifold intake/exhaust, TB, ported fp red.
Custom donwpipe with Tial 38mm wastegate (no spike) just solid boost hold
AMS inatke (custom cold air extension), LICP, fuel rail, Intercooler, MBC
900cc injectors, walbro 255lb pump
exhaustdepot catback
UR test pipe, UICP
see attachment.
__________________
Sponsored by: Grimmspeed
Grimmspeed p&p and heat coated FP RED
Grimmspeed p&p and heat coated intake manifold and exhaust manifold
Grimmspeed EBCS
AMS FMIC-Rear lightweight bumper beam-aem water/meth-UR testpipe-Exedy 4 puck Clutch-D2 Coilovers-ams intake-ams fuelrail-ams motor mount-Functional Gauges-External dumped o2 DP-exhaust depot catback
ECUFlash/EVOScan
Offline
Old Aug 26, 2009, 01:16 PM   #2
meat_EVO's Avatar
Drives: Evo X
car stock on same dyno makes 240whp.
__________________
Grimmspeed EBCS
ECUFlash/EVOScan
Offline
Old Aug 26, 2009, 01:19 PM   #3
Personal Sales Rating: (2)
2003 Ford Mustang
zTargeTz's Avatar
Drives: 99 GSX, 08 RR GSR
so your starting to spool pretty hard at 3.5k rpms?
__________________
Rawr
Offline
Old Aug 26, 2009, 01:37 PM   #4
omni-star's Avatar
Drives: '08 EVO GSR
Damn Impressive Numbers Meat! That external set-up obviously makes big power. That **** is sick.
__________________
Phantom Black Pearl GSR
Defi White Racer Gauge
AMS Shifter Bushings
AMS FMM Insert
AMS Turbo Back
AMS Fuel Rail
AMS Intake
AMS FMIC
AMS UICP
FP RED
MBC
FP RED FOR SALE - PM ME
OEM Parts for Sale: SSS Spoiler - Cat-Back Exhaust - Catalytic Converter - Upper Intercooler Piping - Front Mount Intercooler - Ignition Coil/Engine Cover - Air Intake Assembly w/ MAF pipe PM for Details
Offline
Old Aug 26, 2009, 01:40 PM   #5
Personal Sales Rating: (0)
papa blue's Avatar
Drives: evo VIII
Congrats on the numbers
__________________
Emperor Motorsports
www.emperorevoclub.com
Offline
Old Aug 26, 2009, 01:43 PM   #6
Drives: 08 Evo GSR
how come so much more hp than tq?
Offline
Old Aug 26, 2009, 01:50 PM   #7
boostsaves's Avatar
Drives: 08 Evo MR
Quote:
That is the way the red works
__________________
Hello This is Boostsaves, I am here for the Raking.
X MR: Ssp-Ams-Iveytune-Xtremeboost-Speed Circuit-Swift-Rexpeed-Apr-Touge-Ray's Engineering-Yokohama-Deatschwerks-Walbro-Forced Performance-Kelford-Ralliart-Aem-Project kics-Rally Armor
Offline
Old Aug 26, 2009, 01:53 PM   #8
nonschlont's Avatar
Drives: AS 06 EVO IX
it looks like hes only running 20 psi @ peak and 24 up top. If he were to run more boost @ peak, his tq would increase quite a bit. Theres still a whole lot left in that turbo set up...
Looks good. You could easily run 24psi striaght across. I personally would shoot for 26 (2 peak) on 93...
edit: just read... The tunes not final! lol looking good! GL w/ the final results!
__________________
330whp / 340tq @ 26 psi (Dynojet)
320whp / 325tq @ 25 psi (D.L.L)
350whp / 335tq @ 25 psi (Evoscan)
335whp / 301tq @ 24 psi VDR 5.71 (EvoM Mode)
Self Tuned
GM BCS / JDM / EVO X Map Sensor / Ets 3 1/2" intercooler / Injen intake w/ UICP & LICP / Works DP (jetcoated) / JUN B.L. cat back / Mil.Spec 100 cell / Walbro 255 /
Advan RS 18 x 9 +29 in SBC wrapped in Falken RT-615's
245/40/18
Offline
Old Aug 26, 2009, 02:17 PM   #9
Drives: 2010 WW Evolution X
^^ hey meat...it appears that external wg setup of yours is holding up the boost well... good job...
Offline
Old Aug 26, 2009, 02:32 PM   #10
SilverEvoX's Avatar
Drives: Silver Evo X
Good looking numbers man, any reason you went with the 38mm Tial for your EWG setup instead of the 44 since you are on the Red instead of stock now
__________________
Buschur Racing Catback
Buschur Racing FMIC
AMS Intake
Nisei Polished 1pc UICP*
U-R Test Pipe
EcuFlash Tuned
Offline
Old Aug 26, 2009, 02:41 PM   #11
meat_EVO's Avatar
Drives: Evo X
Quote:
it starts climbing in boost hard once it hit 10-12psi... so yea, about 3.5k
Quote:
Yea, works f-in great
Quote:
Thanks!
Quote:
But i am nowhere near done
going to shoot some watermeth in on friday, and it will probably allow it to build some better boost down low, and then with the 110 + watermeth tune it will be insame, 30-34psi.
Quote:
Thanks, i do what i can.
Quote:
because i am still exiting out the stock wastegate port on the turbo which is like 28mm? so a 38mm wastegate its perfectly fine for my setup.
__________________
Grimmspeed EBCS
ECUFlash/EVOScan
Offline
Old Aug 26, 2009, 07:12 PM   #12
kimma's Avatar
Drives: 05 STi
30-34=boom
Offline
Old Aug 26, 2009, 07:36 PM   #13
meat_EVO's Avatar
Drives: Evo X
Quote:
Originally Posted by kimma View Post
30-34=boom
in a sti, yes!
__________________
Grimmspeed EBCS
ECUFlash/EVOScan
Offline
Old Aug 26, 2009, 08:17 PM   #14
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Nice baseline Meat! I bet once the boost is set higher the torque is going to shoot way up. If a an Evo X baselines around 240 whp on that dyno you are almost at 500 crank HP already at 25 psi. Can't wait to see the spray numbers at higher boost.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Aug 26, 2009, 11:14 PM   #15
Yo kim beat it lol sti lmao....good job meat!!!! I bet u loving the new setup now add that meth!
__________________
2008 Rally Red X
Mods
Forge wga
Megan racing TBE
Harmon motive UICP
K&N Cone filter
AEM tru boost/AEM wideband
Ecuflash tune by DG
Dyno graph
http://i9.photobucket.com/albums/a52...iiiiiiiimy.jpg
334hp 360tq @ 26psi holding 20psi
WWW.DGMotorsNY.COM
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
