Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Dyno Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 25, 2009, 02:46 PM   #1
Personal Sales Rating: (1)
evolvedx's Avatar
Drives: Evo X
E85 on Stock Turbo & Internals
It's official - I've joined the E85 army in my X. I acquired and installed the necessary items, drained and filled the tank, and scheduled an appointment with my tuner (Wingz Performance). This was done about 10 days ago, and I've probably burned through one tank since then.
I feel like I have a different car again. Fuel trims were dialed in, AFR was corrected, timing was advanced, and the boost is maxed out with the MBC (27 psi peak, tapers to 18psi @ redline - that's all we can get out of the stock turbo, seems the compressor is maxed out).
Here's my engine/power mod list for reference:
AP short ram intake
AGP hard pipes
AGP DBE exhaust
Hallman Pro MBC
AUS 1000cc injectors
Walbro 255lph HP FP
Prosport Boost Gauge
AEM Wideband
Stock WGA tightened all the way down
THE RESULTS:
The torque is a lot of fun, but I was hoping for a few more gains in HP up top. Mid range gain is great, but I'm still not too sure what to make of it. Anyone have any thoughts on that? It was 108*F when it was on the dyno mind you, but my only thoughts are heat soak or I'm limited by the stock DP.
And a quick pic of my car
Offline
Old Aug 25, 2009, 03:04 PM   #2
Personal Sales Rating: (2)
flyguycfi's Avatar
Drives: Evolution X GSR
I think you are probably just limited by the stock turbo, but I don't know.
Those Torques in Yamaha Black?
__________________
2008 Lancer Evolution X GSR
Baseline - 259whp @ 21PSI *stock turbo*
Tuned - 358whp @ 25PSI *stock turbo*
Tuned by TTP Engineering - Orlando, FL
Offline
Old Aug 25, 2009, 03:06 PM   #3
evolvedx's Avatar
Drives: Evo X
Gunmetallic actually, just the lighting in that pic makes them look a little darker.
Offline
Old Aug 25, 2009, 06:05 PM   #4
twinkiemobile's Avatar
Drives: GG EVO X
Send a message via AIM to twinkiemobile
Can you direct me towrads what things must be done in order to convert to E85?
Offline
Old Aug 25, 2009, 06:08 PM   #5
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
Quote:
Injectors
Fuel Pump
E85
Tune
OP: Welcome to the E85 Army
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Aug 25, 2009, 06:10 PM   #6
evolvedx's Avatar
Drives: Evo X
Quote:
Originally Posted by GST Motorsports View Post
Injectors
Fuel Pump
E85
Tune
Any thoughts on why I didn't see better gains up top? I was hoping you might chime in there...
Offline
Old Aug 25, 2009, 06:16 PM   #7
Silver Sponsor
Drives: EVO, STI
Quote:
Flow restriction, Boost control, heat, etc
Could be any of those
Have a boost plot?
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Aug 25, 2009, 06:32 PM   #8
Personal Sales Rating: (0)
Drives: EVO X GSR
Congrats on taking the leap to E85. The torque numbers are amazing. Hard to get the most out of a tune when it's over 100 degrees.
Keep us posted on how much your gas mileage drops compared to before your conversion.
Offline
Old Aug 25, 2009, 06:39 PM   #9
evolvedx's Avatar
Drives: Evo X
I don't unfortunately. It peaks at 27 psi and does a pretty steady taper to 18, like we've all seen many times over. Thanks though, we're on the same page.
Offline
Old Aug 26, 2009, 08:31 AM   #10
murlo26's Avatar
Drives: 08 RR X GSR
Send a message via AIM to murlo26
You should be able to get a higher boost spike out of the stocker. I am hitting 31 psi but like you tapering hard down to ~18 psi. I too tightened down the stock actuator but I am running a 3 port from Perrin. Maybe try going to a 3port to hold a little more boost. It more than likely won't help up top but you could probably get even more torque
I would say the power is limited by the heat partially and maybe you aren't throwing enough timing in there? We could not get my car to knock on E-85 but we stopped making power so we backed it down. E-85 loves timing thats for sure.
Ps. Welcome to the army
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Old Aug 26, 2009, 09:16 AM   #11
SilverEvoX's Avatar
Drives: Silver Evo X
I think your BOV is leaking and limiting your peak boost, also adding a 3 port boost solenoid would help control it better. You shouldn't need the WGA tightened out all the way if you are using Ecu controlled boost via the tune nor the MBC.
Now all that aside, I think you made really nice gains considering the weather was 40+ degrees hotter. It will make alot more power when it is back in the 60's outside and after you upgrade the FMIC because I'm sure it is heat soaking pretty bad at that psi. The torque gain is sick! Nice work.
__________________
Buschur Racing Catback
Buschur Racing FMIC
AMS Intake
Nisei Polished 1pc UICP*
U-R Test Pipe
EcuFlash Tuned
Offline
Old Aug 26, 2009, 09:28 AM   #12
Personal Sales Rating: (21)
VenomEVO8's Avatar
Drives: Nothing
Went from 61 degrees then to 108.. WOW!! Nice numbers n Great looking X
Offline
Old Aug 26, 2009, 09:34 AM   #13
Personal Sales Rating: (3)
Evo a Mula's Avatar
Drives: 2008 evo 10 gsr, 2000 chevy venture L0L ex cars 2006 evo Se
e85 looks like the way to live so much wtq
__________________
**DG Motors Sponsored**
Call DG Motors 631-957-8464 for all you Evo needs
Dyno Tunes
Installations
Full builds
Dyno time
Offline
Old Aug 26, 2009, 11:21 AM   #14
Silver Sponsor
Drives: EVO, STI
Quote:
Yup, E85 is a MBT capable fuel, which you have to treat with respect, unless you want to vent your block.
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Aug 26, 2009, 11:25 AM   #15
all4bspinnin's Avatar
Drives: 06 subaru sti
holy crap, thats a lot of torque for a 2.0... lots of timing?
Offline
Tags
afr, army, convert, e85, evo, needed, ranges, turbo, whats
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
