Aug 9, 2009, 11:13 PM
Personal Sales Rating: ( 3)
Drives: Evo X MR
LVSBB6's MR dyno
Got my MR tuned at a local dynapack facility, running stock turbo with bolt-ons listed in my sig, tuned via Cobb ATR on 94 oct. This dynapack reads relatively low compared to others, with around 50% drivetrain loss on AWD vehicles. As reference a 1.8T A4 makes 110whp and a V8 S4 makes 220whp on this dyno. While a stock STi only manages 190whp, I would imagine a stock Evo X would also make somewhere around this number.
The run-downs:
Baseline: bolt-ons with no tune: 231whp/258wtq
Green: bolt-ons with initial custom tune: 280whp/303wtq
Blue: MIVEC tuning added: 276whp/298wtq (40wtq+ @3000rpm/60wtq+ @3300rpm)
Pink: Okada plasma ignition installed: 279whp/301wtq (15whp+ @7000rpm)
Red: Final tuned: 294whp/311wtq
Boost:
23psi@3500rpm
26psi@4000-5500rpm
24.5psi@6000rpm
23psi@6500rpm
21psi@7000rpm
A/F:
12.5 @ spool, 11.3-11.5 thereafter.
Car is amusingly fast and pulls strong all the way, torque hits hard and and spool-up is insanely quick. SST is holding up well with the new founded power and shifts smoothly. I'm happy with the end result.
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Offline
Aug 9, 2009, 11:17 PM
Personal Sales Rating: ( 0)
Drives: 08 Evo MR
nice numbers man
__________________
Hello This is Boostsaves, I am here for the Raking.
X MR: Ssp-Ams-Iveytune-Xtremeboost-Speed Circuit-Swift-Rexpeed-Apr-Touge-Ray's Engineering-Yokohama-Deatschwerks-Walbro-Forced Performance-Kelford-Ralliart-Aem-Project kics-Rally Armor
Offline
Aug 9, 2009, 11:54 PM
Personal Sales Rating: ( 1)
Drives: Solar Yellow IS300 ---> Apex Silver EVO8 --->White G35coupe ---> Silver Fit S--->RR Evo X MR
well done as a fellow mr owner i am always interested in how your car is doing. glad to hear the sst is holding up
__________________
"yo man I'm just makin this sh*t up as I go..."
RR EVO X MR: Nisei intake pipe & UICP // Cosworth Drop in Filter// ARC FMIC // AMS downpipe // Blitz Nur Spec R exhaust // Swift Springs // Whiteline Roll Center Kit //
Offline
Aug 10, 2009, 04:58 AM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
you really should get it re-dynoed at a proper dynojet facility. i never trust dynapacks, after all the inaccurate numbers i see it gives.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Aug 10, 2009, 09:55 AM
Personal Sales Rating: ( 2)
Drives: Evo X MR
how are you hitting 26psi? what are you using to control boost?
Offline
Aug 10, 2009, 10:15 AM
Drives: Evo X MR
Compared to dynojet, the dynapacks reads low especially this one, but it is a very accurate tuning tool indeed. I was getting consistent numbers run after run so I`m not sure how you come up with that statement. There is bound to be difference in numbers between dynos, and even within the same type of dynos.
Without variables of wheel pressure, alignment, strap tension and a built in weather station, i would say Dynapack is the most repeatable and is the reason why most big tuners and motorsport sanctioning bodies use them, and also why they cost twice as much. No one races dynos, they are simply a tuning device.
Quote:
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Aug 10, 2009, 10:16 AM
Drives: Evo X MR
Cobb AP and Jun wga.
Quote:
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Aug 14, 2009, 09:56 AM
Drives: 2005 EVO RS
was boost and/or timing increased in the final tune (red) over the blue/pink pulls? you seem to have some pretty significant gains between these. car must be a fun drive. can i try?
Offline
Aug 14, 2009, 10:04 AM
Drives: 2008 Evo X MR
Quote:
A lot of members here are hitting 25-26 psi after getting tuned with stock ECU boost control. It's really no surprise and the WGA is not needed for running 26 psi.
Offline
Aug 14, 2009, 10:21 AM
Drives: 08 Lancer GTS CVT WW
nice numbers
__________________
-Chris
2008 Wicked White Lancer GTS CVT
| Tein S-Techs Springs | Injen Exhaust | 6k HIDs | ARC Knob | JDM Antenna | Flat Black Volk CE28N's 18x8.5 +30 | Injen CAI | RalliArt Taillights | Vinyled Matte black roof |
illest
Offline
Aug 14, 2009, 10:45 AM
Drives: Evo X MR
Boost is actually lower from 26.5psi to 26psi in the final run just to play safe, we made adjustments mainly on the timing and mivec tuning, A/F was tuned to be conservative in the low 11s. Its quite a blast to drive indeed
Quote:
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Aug 14, 2009, 01:17 PM
Drives: 2010 EVO X.....I dont need a wing!
must be fun. take care of that tranny
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
