Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Dyno Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 10, 2009, 06:31 AM   #46
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Quote:
Originally Posted by 90GSXDan View Post
Congrats Louis! Very impressive numbers indeed!
My friend is torn between getting a fp red or doing cams. Its still up in the air seeing as the gains between both separate, are phenominal gains!
As for a dyno, I prefer a dyno dynamics. But I don't use the dyno for these irrelevant numbers, as every dyno reads different and a dyno is merely a tuning tool, not give you an exact number of what your car is making. I use a dyno dynamics because it has a great load bearing dyno that can replicate a real load on your car like the street, giving you a better chance of tuning your car safely and more precise for the track or street. Numbers is nothing but that, a meaningless bragging right and just a number, (not trying to poke at you or dog you Louis), but the real bragging right is in the trap speed and et!
Congrats on the new found power and big props to EFI on a great, safe, reliable tune for a fellow car enthusiast!
Dan
As I found out recently, unless you are willing to set your rev limiter to 8500 and risk valve float, mesuring trap speeds is tricky at best since you need to shift to 5th just as you reach the finish line. 4th gear is just too short on these cars and while it might be just enough for a stock turbo to rev out at the traps, an upgraded turbo puts you right in that dead zone where you are coasting at 8000 rpm across the line.
Should be interesting to see the different numbers and gains on the dynos.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Jul 10, 2009, 07:33 AM   #47
Personal Sales Rating: (0)
Yes Dan im torn between cams or fp red. I put down 309hp on a dyno dynamics with just full tbe exhaust and a cone filter no other mods @ 23psi. I should make 400 with a fp red and remaining bolt ons! The fp is only 1400 and no one will know you upgraded the turbo but the cams do sound sick! Excellent numbers and good luck with your setup!
__________________
2008 Rally Red X
Mods
Forge wga
Megan racing TBE
Harmon motive UICP
K&N Cone filter
AEM tru boost/AEM wideband
Ecuflash tune by DG
Dyno graph
http://i9.photobucket.com/albums/a52...iiiiiiiimy.jpg
334hp 360tq @ 26psi holding 20psi
WWW.DGMotorsNY.COM
Online
Old Jul 10, 2009, 03:47 PM   #48
Silver Sponsor
DG Motors's Avatar
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Quote:
We average 400whp on our dyno(1.0 correction) with 93 octane/25ish psi with an FP Red and supporting mods:
Full TBE
IC
IC Piping
Intake
800cc Injectors
FP Red
Cams
and you can't forget about the DG Tune....
P.S: The cams can be tuned to idle like stock...
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Old Jul 10, 2009, 10:47 PM   #49
90GSXDan's Avatar
Drives: 06 Evo IX (RIP), 90 Eclipse GSX (SOLD), 97 GSX Black Beast
Not necessarily. For example, if you have a good set of valve springs (I had gsc beehives with stock retainers and cosworth m2's) and a evo 8 4th gear, you should have zero problems. Just ask the buschur guys or anyone trapping low 130mph. They never touch 5th gear, nor have issues with valve float. Not to mention, on my setup with a stock turbo, I revved my car consistantly to 8700rpm with just those gsc beehives and stock retainers, valves, and guides, just had cams.
Jimmy, as we talked about it before, I would do the cams first, and you are in great hands with DG with anything you need done.
To the OP, I LOL'd out loud when you made the comment about making ridiculous numbers on some vendors dyno!
Dan
__________________
RIP Evo IX
ETS/TTR/DGMotors
Offline
Old Jul 11, 2009, 08:11 AM   #50
Hiboost's Avatar
Dan
I could have misread but I thought Buschur was turning 8500 without the valve springs, which is why I'm limiting myself to 8000 rpm until I get them to stay on the safe side.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Old Jul 12, 2009, 01:09 PM   #51
nj1266's Avatar
Drives: 2006 EVO IX
To the OP, intake temps consistently above 100* F will make the Evo pull timing no matter what you put in the timing map. There is a temp vs. timing table that makes the Evo pull timing whenever the intake temps are always above 100* F. So it is a very good idea to invest in a good quality aftermarket IC to keep intake temps at bay.
To others, this debate over dynos is so lame. This dyno reads low vs. that dyno reads high is a bunch of BS. IMO, only ricers make that argument. If you are really prefromance oriented, you will use the same dyno for ALL your testing and look at the gains regardless of peak numbers. That is exactly what the OP did. He reported the gains and still some posted how they got 370 hp on a dynojet with a stock turbo. BFD. Different dyno, different results, different Evo, different mods. It means absolutely nothing. I hate these lame ass arguments. They spoil good threads like this one.
If I was king of the world, I will make dynos that will only report GAINS and not maximum numbers. I do not give a rat's ass if a car makes 500 hp on a dyno w/o knowing the baseline that the car started with.
__________________
2006 EVO IX, Stock
2002 Toyota Tundra, 207 hp, 271 ft-lbs torque
1998 SE-R Race Car, 2008 SCCA ITA SoPac Champion
Offline
Old Jul 12, 2009, 04:45 PM   #52
Personal Sales Rating: (1)
EvoNiner1986's Avatar
Drives: EVO IX
To the OP, very nice progress...It's cool to see how you dyno and after adding a group of mods, dyno again. Really helps to see what different parts net you
__________________
IloveTHednUD
Offline
Old Jul 14, 2009, 08:03 AM   #53
Drives: '08 EVO X, '06 WRX STi
Quote:
Thanks for the compliments, guys. I really wanted to know just how much each part was helping me, if at all, as I installed them in "stages". On EVO X's, the biggest gain right off the bat is a new flash as the stock tune was God awful. My car missed, sputtered, and even detonated, bone stock.
158awhp later, the car is a whole new animal. I haven't been beat, yet! (On closed course environments of course).
- Louis
__________________
2008 AS EVO X GSR
AMS Powered
1320 for life!
370/341 Mustang Dyno
2006 WRX STi
Wife's toy... 411/404 Mustang Dyno
All tuning done by Chris @ EFI Logics - Bethel, CT
Offline
Old Jul 17, 2009, 07:51 AM   #54
meat_EVO's Avatar
Drives: Evo X
So you car ran 40whp less then mine did stock and i was on a dynojet. So that put you at 400whp on my dyno. This makes me very happy because i was 400whp on 23psi with my red, in p&p'd, externally gated, mbc, + water/meth, and a ams fmic. So i deffinatly see 400whp on 23-24psi happening for me.
__________________
Sponsored by: Grimmspeed
Grimmspeed p&p and heat coated FP RED
Grimmspeed p&p and heat coated intake manifold and exhaust manifold
Grimmspeed EBCS
AMS FMIC-Rear lightweight bumper beam-aem water/meth-UR testpipe-Exedy 4 puck Clutch-D2 Coilovers-ams intake-ams fuelrail-ams motor mount-Functional Gauges-External dumped o2 DP-exhaust depot catback
ECUFlash/EVOScan
Offline
Old Jul 19, 2009, 12:19 PM   #55
Personal Sales Rating: (13)
UpstateEVOVIII's Avatar
Drives: JDM AWD Turbocharged Madness
Send a message via AIM to UpstateEVOVIII Send a message via Yahoo to UpstateEVOVIII
Lou,
Seth and Tony say hi Glad you are enjoying the X!
__________________
It's not about how fast you get there. It's about how much fun you have along the way.
Offline
Old Jul 25, 2009, 08:22 AM   #56
Excalibur's Avatar
Drives: 2008 WW Evo X GSR
Send a message via Skype™ to Excalibur
Question
Quote:
Full TBE
IC
IC Piping
Intake
800cc Injectors
FP Red
Cams
That's it? Why are the blouch turbos with cams making around 440?
__________________
Ecuflash (evolution dynamics)
ETS HTA GT3582R Twin Scroll
ETS Turbo Intake
ETS 4" Intercooler & Piping
Twin 38mm Mini Wastegates
Deatschwerks 1000cc Injectors
Walbro 255lph Fuel Pump (UR Install Kit)
ACT TTP Clutch w/ AMS MC Upgrade
Buschur Racing Catback
AMS Testpipe
Forge Front Lower Motor Mount
Perrin EBCS
AMI Dual Gauge A-Pillar
AEM UEGO and Boost Gauge
Perrin 2" Shorty Antenna
Offline
Old Jul 25, 2009, 09:04 AM   #57
Personal Sales Rating: (10)
Evo-IX-MOMO248's Avatar
Drives: 06 Evo IX (totaled) l 08 G37S 6MT (sold) l 08 WW Evo X GSR
Quote:
They don't have a high reading dyno....and the blouch didn't hit 440 whp on there dyno. They did a blouch with a similair set-up as the red and made very similair numbers...I think a couple HP less.
On other dynos though these would be over 440whp though.
__________________
12.61 @ 111mph (345whp 362wtq)
IVEY TUNED
AMS l FP l Exedy l Aquamist l AEM l Artisan l Defi l TWM l Works l Eibach l Hallman l Walbro l DW l Rota l JNZ
29psi 431whp l 369wtq
33psi 462whp l 399wtq
Offline
Old Aug 5, 2009, 08:50 AM   #58
Just wanted to report in that I got beat last night, and it was a solid loss, too. Like 3-4 cars and losing ground over 100.
EVO IX, FP Green, 26psi, cams, FMIC, twin disc and supporting mods. He ran 11.8/11.9 at 119mph.
Back to the drawring board!
- Louis
__________________
2008 AS EVO X GSR
AMS Powered
1320 for life!
2006 WRX STi
Offline
Old Aug 5, 2009, 09:23 AM   #59
Drives: 05 EVO
- Louis
Based on your power output, I'd guess you would trap around 115mph. So he's definitely pulling on the top end.
__________________
05 Evo
05 CBR 600RR
96 SE-R, sold... (t25, cams, brakes, suspension, 260whp/260wtq, 111mph trap, lots of road course time, blah blah)
Offline
Old Aug 5, 2009, 10:10 AM   #60
JuniorAWD's Avatar
Drives: mkiv TT 6spd
Send a message via AIM to JuniorAWD
- Louis
Who's car?? Maybe it was a Red on 26psi you raced.. a green @ 26psi would be around 400-420whp on a dynojet.. The 119 mph trap will also indicate that its making around that power. 400-420whp on a dynojet would only be around 340 on a uncorrected mustang. Your are making 365whp which would be around 440-450whp on a dynojet.. Factor in weight and you should have at least been even.. not loosing by 3.
Sounds like someone tried to hustle you!
__________________
Junior
World Record Most EZ-PASS Tickets
World Record Silver Subaru with Silver Rotas Tuned by a Dell D420
9.7@144 3500+lbs
World Record HP Subaru 1296whp @ 1.80 Correction
World Record Highest Correction Factor Used
World Record For Most Useless "World Records" held
Offline
Tags
ams, boost, dyno, efilogicscom, evo, fp, gas, kit, mr, power, pump, red, stage, tuned, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
