Oct 23, 2009, 06:03 PM
Personal Sales Rating: ( 1)
Drives: 08 evoX
Install Guru's! Noise problem with aftermarket amp
08 evo x gsr with rockford fosgate system.
The right channel has static that pulses at about 10 hz. System plays out of both channels and Volume control does not make static louder or quieter.
I pulled out the rockford amp to put a jl 300/2 to push focal k2p's in the front. I am using a Rockford Fosgate 3sixty processor to give me control of the stock head unit's output. I found the wiring diagram for the left/right channel head unit output and my fader works correctly.
If I pull the right channel input to the 3sixty, the problem stops. If I swap right/left, it swaps to left side.
I have installed this system before without this problem.
It seems to be on the head unit side of things, but all i did was cut wires and solder on rca pigtails.
My grounds are good. Used the oem fosgate amp power and ground for the 3sixty, Sanded around the amp bolt for a lug for the JL amp. Checked with a meter about 0.4 to 0.6 ohms.
Any ideas?
Moose
__________________
AEM Cold Air Intake
Buscher shifter bushings
Ultimate Racing catback
Ultimate Racing resonated test pipe
Ultimate Racing downpipe/o2 housing
mitsu bluetooth module/ awc switch relocation
Cobb AP w/ stage2.
Hks turbo timer
Cobb intercooler piping
Perrin intercooler,
Reason: edited for clarity
Offline
Oct 25, 2009, 12:11 PM
Drives: 08 evoX
Sorta fixed. Started playing around with input and output gains on the 3sixty, and input gain on the JL amp and got the noise quiet, but not gone. I believe the noise is actually interference from some processor in the car because when I crank the input gain up I can hear the once a second 'tick' from the tire pressure monitors as well as the pulsing static. With gains set lower the noises are pretty much absent. I just have to have the head unit at a higher volume than before to reach the same volume output.
__________________
AEM Cold Air Intake
Cobb AP w/ stage2.
Hks turbo timer
Perrin intercooler,
Offline
Oct 25, 2009, 05:12 PM
Drives: 350Z / EVO X MR
10hz?!
__________________
08' EVO MR
AMS Widemouth O2 Housing
MXP Exhaust
MXP Resonated Test Pipe
Nisei UICP
Cosworth Drop-in Filter
Eibach Pro-kit springs
Ichiba 20mm Wheel Spacers
COBB Access Port
Tuned by HBSpeed
Offline
Oct 25, 2009, 05:26 PM
Drives: 08 evoX
I'm approximating the frequency. its as if the static is getting louder and quieter about 10 times per second, only in the right channel output from the stock radio.
__________________
AEM Cold Air Intake
Cobb AP w/ stage2.
Hks turbo timer
Perrin intercooler,
Offline
Oct 28, 2009, 04:50 PM
Personal Sales Rating: ( 0)
2008 Mitsubishi Lancer Evolution My Garage
Drives: EVO X GSR, '74 VW Bug
Are there any uninsualated RCA's near any power wires?...either at the head unit or the RF360
Offline
Nov 7, 2009, 11:07 AM
Drives: 08 evoX
I don't know about the head unit, it's the stocker. There's a short (1") unshielded section where I soldered shielded rca's to the stock wiring. I shielded it with grounded foil just to see if it made a difference, it didn't. I can mitigate the noise with gain, but the problem is not solved yet.
__________________
AEM Cold Air Intake
Cobb AP w/ stage2.
Hks turbo timer
Perrin intercooler,
Offline
Nov 7, 2009, 07:25 PM
Drives: 08 evo x gsr sss, lancer gts 09 (traded)
try to put noise shields on the RCA (black lead core that snaps to the cable). It helps eliminate gain noise and distortion.
Offline
Tags
aftermarket, amp, amplifier, channel, distortion, evo, fix, head, installing, interference, noise, outputs, radio, rca, rockford, unit  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
