Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 3, 2009, 08:10 PM   #1
Personal Sales Rating: (0)
Silhouette's Avatar
Drives: PB X GSR
Rockford Navi volume too low?
I just got my Evo and was configuring it; it has the MMCS
. I'm playing all music on level 45 volume and it's loud, but not as loud as it should be. We have another GSR in the house and his volume at ~20-30 sounds what my car sounds like at 45. Is there a hidden setting or volume limit I should be toggling? I can't find it in the manual.
Offline
Old Aug 4, 2009, 11:17 AM   #2
Drives: 08 EVO X
i was going to ask the same question but i have a base gsr.........When i have the volume around 20 i can barely hear it
Offline
Old Aug 4, 2009, 11:18 AM   #3
Personal Sales Rating: (4)
mmartahus's Avatar
Drives: Traded 09 GTS for a RR 08 GSR w/ SSS & Aero
depends on the song
u could try turning SVC (speed volume compensation) on and off and see if u notice a difference
__________________
RR 08 Evo X GSR w/SSS, Aero, Interior Sport, K&N Drop In, Buschur Crossflow CBE, Goodyear Eagle GTs, Escort 8500, Perrin Shorty
Sold: GG 09 GTS w/ Sun, Sound, Navi
Offline
Old Aug 4, 2009, 01:40 PM   #4
EvoM Moderator
Personal Sales Rating: (24)
atombomb33's Avatar
Drives: Evo X - GSR
The Rockford system's amplifier is the culprit. It cuts power whenever it senses the signal is clipping. It's a good feature because it will save you from blowing the speakers. It's a bad feature because it limits the system's overall sound output. Only way to make it louder is to replace the Rockford amplifier under the driver's seat.
High-end Bose, Bang & Olufsen and Mark Levinson car stereos all have a similar function to save your speakers. Those systems will play louder than the Rockford system in the Evo because those systems have a stronger amplifier to begin with.
The Rockford amp is pretty weak. It's rated at 650 peak watts which is probably only around 300 total watts RMS. That's pretty weak considering it has to drive components up front, coaxials in the back and a 10" sub.
__________________
2008 Evolution X - GSR Apex Silver /// SSS - Aero - Navi
Forum rules & regulations
Offline
Old Aug 4, 2009, 02:06 PM   #5
mmartahus's Avatar
what would be a plug and play replacement for that rockford amp
__________________
Offline
Old Aug 4, 2009, 02:34 PM   #6
EvoM Moderator
atombomb33's Avatar
Drives: Evo X - GSR
Quote:
If you're keeping the stock head unit, there isn't a plug and play solution. There is a thread in here from a guy who was able to identify all of the wires on the stock amp's wire harness. So you could use that as a guide to keep your stock head unit and speakers while using the stock wiring for a new amp (except you'll likely need a new power wire from the battery and a new ground wire to the chassis).
EDIT: here's that thread Finally replaced the Oem Amp
__________________
Offline
Old Aug 4, 2009, 02:47 PM   #7
mmartahus's Avatar
crazy, i guess ill just be happy with what i have
__________________
Offline
Old Aug 5, 2009, 01:02 AM   #8
Silhouette's Avatar
Drives: PB X GSR
It just makes no sense that the other GSR is WAY louder than mine, we both have SSS!
Offline
Old Aug 5, 2009, 08:03 AM   #9
EvoM Moderator
atombomb33's Avatar
Drives: Evo X - GSR
Quote:
Weird. That doesn't make any sense since you both have SSS. I figured the other car had the base stock stereo.
Have you played the same CD in the cars back-to-back? It's even better if you can be playing the same CD in both cars at the same time and then quickly jump from car to car. It's really hard to tell if one stereo is truly louder than the other without a db meter.
__________________
Offline
Old Aug 5, 2009, 08:21 AM   #10
mmartahus's Avatar
try turning the volume all way to zero then power off the stereo and then try turing the power and volume back on
__________________
Offline
Old Aug 5, 2009, 10:47 AM   #11
Spoonie's Avatar
Drives: EVO X MR
I have the same issues with my Rockford setup. The output of the radio and satellite is very weak(all songs). You just can't crank it! Some songs on CD are ok but for the most part I'm highly dissappointed with the so called "650 watt" stereo. I'm replacing the amp this winter with the 5-channel pioneer this winter.
Offline
Old Aug 6, 2009, 01:26 AM   #12
TheBlueBlur's Avatar
Drives: GG Evo X GSR, CB E46 M3(gone), EB Evo IX(gone)
Send a message via MSN to TheBlueBlur
Does having Nav make a difference? I have both SSS and nav, and I rarely turn my system above 27 because it gets way too loud.
I turned off the speed sensitive volume, have treble and midrange knocked up 2 or 3 bars, and bass 1 bar.
__________________
:VentureShield Clear Bra: :Works Drop In Filter: :Buschur Polished UICP: T1R 76S Exhaust: UR Resonated Test Pipe: Strictly Modified ECU Tune: T1R Suede Shift Boot: MOMO CF Shift Knob.
Offline
Old Aug 6, 2009, 07:14 AM   #13
Personal Sales Rating: (2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
Send a message via AIM to lancer0220
Quote:
its not the amp that sucks its the headunit
change the headunit and use a metra mito02 to retain the stock amp and subwoofer.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Old Aug 6, 2009, 07:56 AM   #14
EvoM Moderator
atombomb33's Avatar
Drives: Evo X - GSR
From what has been posted on this forum, the amp is the culprit and has the sound processing that lowers output so you don't blow your speakers. The head unit is fine.
__________________
Offline
Old Aug 6, 2009, 11:31 AM   #15
Personal Sales Rating: (14)
2008 Mitsubishi Lancer Evolution
My Garage
beetle_orange's Avatar
Drives: PB Evo X ; 1973 VW Super Beetle
Send a message via Yahoo to beetle_orange
RF nav sounds fine to me, easy fix is if you dont like it sell it.
__________________
2008 PB Evo X GSR, SSS, OEM AW Mats, OEM Navigation, OEM MR Recaro Leather Seats, OEM Splash Guards, OEM Rear Wing Extension, OEM Door Visors, OEM UK F&R Scuff Plates, OEM UK CF Vortex, 2010 Cupholders, OEM BT and Volume Control.
BlackTop CF V-Style Lip, K&N Air Filter, Nisei Red UICP, Rxpd Rear Bumper Extension, Work Emotion XC8 19x10 +35; Kumho Ecsta 265/30
http://www.cardomain.com/ride/3059755
_The Lord will Provide_
Offline
Tags
8500, anymore, control, dropped, escort, evo, hear, lancer, limiter, low, music, passport, satellite, speed, stereo, svc, too, volume
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
