Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 1, 2009, 08:52 AM   #1
Personal Sales Rating: (0)
EVOXTIMES's Avatar
Drives: APEX SILVER BULLIT GSR
iPod jack
has anyone installed a i pod jack on a non sss evo gsr?
Offline
Old Aug 1, 2009, 10:13 AM   #2
Drives: lncer
Nope :d
Offline
Old Aug 1, 2009, 10:18 AM   #3
Drives: 944S
there isnt an aux port somewhere on a non-sss / non-nav gsr? really? i thought there was somewhere under the radio...
Offline
Old Aug 1, 2009, 10:21 AM   #4
Drives: lncer
I thought Mitsu would be smart about this. Buncha cheap bastards!
Offline
Old Aug 1, 2009, 12:25 PM   #5
Drives: 08 EVO X
i just bought mine yesterday and was so pissed to find out their was no port
Offline
Old Aug 1, 2009, 01:48 PM   #6
Drives: AS Evo X GSR
I called the dealership on this issue and apparently there is a different iPod cable that they can wire up to the back of the factory headunit but it costs twice as much. I haven't really verified this because once I heard twice as much I was out on that.
Offline
Old Aug 1, 2009, 02:30 PM   #7
Personal Sales Rating: (2)
fuzzydoodle's Avatar
Drives: 95 TSi
What was it? Out of curiosity.
__________________
OG Mudbones #1 Fan
Offline
Old Aug 1, 2009, 04:12 PM   #8
zarl's Avatar
Drives: 08 WW Evo X GSR
Quote:
Yes -- I got the factory Mitsu kit for the car. It was involved and I probably wouldn't have done if it wasn't a feebie, courtesy of Mitsu for another issue. Dealer had to order a few parts that tap into the back of the non-SSS head unit. It was a harness plus another converter box. It gets you a standard 1/8" stereo cable to plug in an external source.
Offline
Old Aug 1, 2009, 04:36 PM   #9
Drives: 95 TSi
Without it factory, what do you do to set it to the external playback?
You know like, AUX on an aftermarket deck.
__________________
OG Mudbones #1 Fan
Offline
Old Aug 2, 2009, 12:01 AM   #10
zarl's Avatar
On the base GSR stereo if you have the factory kit, you hold down the "CD/MP3" button for 2 seconds, and it switches to the AUX input.
Offline
Old Aug 2, 2009, 09:24 AM   #11
EVOXTIMES's Avatar
Quote:
If it isnt too much trouble.....can u find out what those part numbers were? The Parts guys at my Mitsu are idiots.....and if i ask them will probably just say no.
Offline
Old Aug 2, 2009, 10:08 AM   #12
EVOXTIMES's Avatar
yeah i found that AUX channel quite easily......
Did you do the job yourself? If so.....am I wrong to believe the 18 pin molex cable isn't already part of the existing harness?
According to the wiring diagram that I have, from directwire, the aux channel input left is a black and white wire pins number 13 and14 and the aux channel right are pins 4 and 14.
I believe the wire harness is already there...taped back with blue tape. The reason I believe this is because when reading through another thread on how to install navigation on non nav they mention just plugging the nav in using a existing molex cable. and according to the diagram i have the AUX and NAV use the same 18 pin molex cable........ i think after i just have to find the wires and splice into them and install the jack.
Any thoughts?
Offline
Old Aug 2, 2009, 02:09 PM   #13
zarl's Avatar
I didn't do the install myself -- the dealer did it all. And, I think you're right on the harness --- tap into the existing harness, not necessarily replace it. I don't have the part number since I didn't do it the install. The dealer had to actually install the thing twice, because the first time they used the wrong part, then had to order the part that had that converter box. Trim, glovebox, and other bits had to be removed and a hole drilled in lower storage bin to route the cable. Not too complex, I guess, but I would be bummed if I broke some overpriced trim piece and have to replace it. Good luck with the install.
Offline
Tags
10, 18, aux, auxiliary, button, evo, gsr, hold, ipod, jack, kit, nonsss, port, splice, sss
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
