Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 10, 2009, 05:54 PM   #1
Personal Sales Rating: (0)
shomesomesho's Avatar
Convert Fastkey to Standard Key
I'm shopping for an aftermarket alarm and was wondering if anyone knew what all I would need to covert my Fastkey to a standard keyless entry system?(non-SSS Evos) I want to use the remote starter function but dont want to deal with having to keep the Fastkey on me also. Thanks in advance
Offline
Old Jul 11, 2009, 06:48 AM   #2
EvoM Moderator
Personal Sales Rating: (24)
atombomb33's Avatar
Drives: Evo X - GSR
No expert on this, but here's are some things you'll need:
1) two new standard keys
2) programming from the dealership to activate the keys
3) key hole for trunk
4) key hole for ignition (to replace the plastic black nubby thing)
Maybe some of the guys who have added an aftermarket alarm can chime in to tell you how their remote start (if they have it) is working with their stock fast key?
__________________
2008 Evolution X - GSR Apex Silver /// SSS - Aero - Navi
Forum rules & regulations
Offline
Old Jul 11, 2009, 08:09 AM   #3
Thanks, I completely forgot about the trunk. Do you think both keyless entry systems use the same receiver in the car?
Offline
Old Jul 11, 2009, 10:08 AM   #4
jamdread's Avatar
Drives: 2008 Evolution MR
Ignition already has a key hole. The plastic nubby thing just covers the existing key hole and can be clipped off
__________________
My Ride
Offline
Old Jul 11, 2009, 03:49 PM   #5
Quote:
Do you know if its the same style ignition as the base lancers?
Offline
Old Jul 11, 2009, 11:05 PM   #6
Quote:
it's a standard key ignition as far as I can tell. How else would you start your car if the battery in your fob died.
Offline
Old Jul 11, 2009, 11:11 PM   #7
I realize how its designed to work if your Fastkey dies, but what I was asking is if it was the same as the base evos. Maybe its different and the base keys require a different ignition cylinder to operate correctly?
Offline
Old Jul 12, 2009, 02:33 AM   #8
Personal Sales Rating: (1)
Drives: 2008 WW Evo X GSR
Standard key trunks don`t have keyholes. Fast key has the ugly circle thing on their trunks!
Offline
Old Jul 23, 2009, 10:01 AM   #9
evo4g63awd's Avatar
Drives: 08 PB X, 97 Civic, 06 R1
Send a message via AIM to evo4g63awd
why wouldnt you just remove the battery from the remote if you dont want it to cause a conflict, keep everything you have, and just use the key as a key if your fast key stops working.
saves time and money...
__________________
Plot... Plot... Plot......Plot..Plot............NO MORE!
......back to square 1......
Offline
Old Jul 23, 2009, 10:15 AM   #10
Drives: WW 2008 X MR
My key wouldnt work in the key hole on the ignition...
__________________
"For the Tenacious no road is impassable."
"Add Lightness" - Colin Chapman
2008 WW EVO MR
2006 SGM STI -(Sold)
1968 Ford Mustang
!!! BOILER UP !!!
Offline
Old Jul 30, 2009, 10:37 AM   #11
gizmotoy's Avatar
Drives: 2008 WW Evo X, 2006 Civic Si
Quote:
It should work just fine, that's the back-up procedure if the battery in the key dies. You have to take out the metal key, flip it around and insert it into the fob, then use that to start the car using the keyhole. There's even a little picture stamped into the key.
If that doesn't work, you need to have it checked out because it could strand you.
__________________
AMS Intake & Dual Exhaust, Buschur-tuned to 306whp: Dyno Results Thread
Offline
Old Jul 30, 2009, 11:24 AM   #12
Personal Sales Rating: (27)
rogue's Avatar
Drives: WW EVO X.... previously -EVO IX - Apex Silver
Send a message via AIM to rogue
Your key should work... Mine does.
Offline
Old Jul 30, 2009, 06:14 PM   #13
evo4g63awd's Avatar
yes it would, the immobilizer in the key does not need to be powered in order for it to work
__________________
Offline
Old Jul 31, 2009, 12:19 PM   #14
Drives: 08 GSR
Correct me if im wrong however my dealer told me the "key" can only be used twice before it shuts the car down and will need to be unlocked by a dealer.
Offline
Old Jul 31, 2009, 12:27 PM   #15
gizmotoy's Avatar
Quote:
Sounds like BS to me. Mitsubishi assumes that when your battery dies, the very first place you go is a dealership to get a replacement? Unlikely.
__________________
Offline
Tags
2008, aftermarket, civic, conversion, entry, evo, evolution, fast, fastkey, key, keyless, problem, programming, si, standard, system
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
