May 17, 2009, 01:21 PM
Personal Sales Rating: ( 0)
Drives: EVO X RR
Metra MITO-02
Does anybody use this:
MITO-02
,and if I buy MITO-02 I need this too?
[url="http://www.autotoys.com/x/product.php?productid=1379#tabs"]http://www.autotoys.com/x/product.php?productid=1379#tabs[/URL
Offline
May 17, 2009, 02:48 PM
Personal Sales Rating: ( 1)
Drives: 2006 Evo MR, 2001 Integra Type R, 1995 Honda Passport, 2002 Honda CBR 954 RR
Nope, but I've always had good luck with metra stuff. Been using them for years. I have yet to do an actual install in an evo x, so i cannot comment.
EDIT: note your second link, no you do not need to buy the second harness. One or the other.
Offline
May 17, 2009, 02:49 PM
Personal Sales Rating: ( 2)
Drives: 2008 Mitsubishi lancer Evolution X MR (Fully Loaded)
Iy works in my GTS
Offline
May 17, 2009, 02:56 PM
Drives: EVO X RR
 Thanx
Offline
May 23, 2009, 06:23 AM
Drives: 2008 Evo X GSR SSS
I just installed one of these yesterday with an AVIC F700BT. It sounds great and was really easy to install. It does require that you plug in the front and rear preouts from the head unit in to it, so be sure whatever head unit you get has front and rear preouts (you won't use the sub outs unless you have an aftermarket amp with a different sub that's wired totally separate from the factory Fockford system).
Offline
May 26, 2009, 07:37 PM
Drives: EVO
Does this harness let you use any aftermarket radio with the factory rockford system?
Offline
May 26, 2009, 07:54 PM
Yes. As long as it has front and rear preamp outputs.
Offline
May 27, 2009, 04:44 AM
Drives: 08 Evo GSR, 07 Outlander XLS
Sweet, I just added this to my thead about hacking the stock system to work with aftermarket radios.
Thanks
Offline
May 28, 2009, 07:11 PM
Drives: EVO
Quote:
Interesting, so that sticky about hacking the factory head unit is not needed then?
Offline
May 28, 2009, 07:42 PM
Correct. That was only needed before they came out with the adapter. I don't know why it's still stickied.
Offline
May 29, 2009, 02:46 PM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
this.
is.
EPIC.
i'll be damned if i sold my D3...
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
May 29, 2009, 03:36 PM
Drives: 2009 Lancer GTS
i gonna install an aftermarket head unit ( AVIC Z2 ) to my 2009 GTS, can you help me step by step to do it?
Offline
May 29, 2009, 04:25 PM
No. The Scosche unit comes with instructions, and so does the MITO-O2. If you get both of those units, read the instructions, and still don't know what to do, you should probably pay a shop to do it to save yourself the headache of breaking things.
Offline
May 29, 2009, 05:57 PM
I got both of those but the Scosche doesn't have any manual that came with. I only have mito manual. I wonder does the vehicle have the jack to connect with the Mito or we need to wire ourself?
Offline
May 29, 2009, 06:09 PM
The MITO plugs in where the stock Rockford stereo plugged in. You don't have to cut any harnesses. Read the paper that comes with it, or just pull out the stock stereo and look at it. It takes about 2 seconds to figure out. The only thing abstract at all is the wire colors on the MITO for some of the special wires like speed sensor and parking break. The Scosche should have come with a small piece of paper in the box that explains installation. If it didn't come in a Scosche box with that piece of paper, then I'm not sure what to tell you. There are a bunch of "how to install a head unit" howtos on here, just search and you'll find one.
Offline
Tags
02, 2002, evo, evox, head, install, installation, lancer, metra, mito, mito01, mito02, mitsubishi, outputs, pill, preamp, problems, rockford, unit  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
