Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 30, 2009, 06:38 PM   #16
Personal Sales Rating: (0)
Drives: EVO
Quote:
Originally Posted by i64X View Post
The MITO plugs in where the stock Rockford stereo plugged in. You don't have to cut any harnesses. Read the paper that comes with it, or just pull out the stock stereo and look at it. It takes about 2 seconds to figure out. The only thing abstract at all is the wire colors on the MITO for some of the special wires like speed sensor and parking break. The Scosche should have come with a small piece of paper in the box that explains installation. If it didn't come in a Scosche box with that piece of paper, then I'm not sure what to tell you. There are a bunch of "how to install a head unit" howtos on here, just search and you'll find one.
Any opinions on which is better or easier?
Or just contact Scosche, Im sure they have a tech line for support or can get you instructions.
Offline
Old Jun 1, 2009, 02:20 AM   #17
Drives: 2009 Lancer GTS
i 've just installed the avic z2 today with the mito 02, but i wonder those speed signal, packing signal, reverse signal on the mito 02 work or not, because i want to install the back up camera also but i dont know how to run the wires from the camera to the front.
Offline
Old Jun 1, 2009, 02:24 AM   #18
Personal Sales Rating: (6)
endGameXIII's Avatar
Drives: Evo X GSR
Quote:
speed/parking/reverse signals all work in the same way for all cars (or most that i know of anyway), so it should work just fine.
i'm getting a kenwood dnx9140
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Old Jun 1, 2009, 02:39 AM   #19
so we dont need to wire those signal directly from the unit to the vehicle? just wire mito02 with the unit, is that enough to work?
Offline
Old Jun 1, 2009, 03:21 AM   #20
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Hmm, that's good to know too bad it costs over $100.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Online
Old Jun 2, 2009, 11:00 AM   #21
any1 knows about using the factory bluetooth and the factory sirius on the aftermarket head unit ( avic z2 ), is it possible?
Offline
Old Jun 3, 2009, 04:31 AM   #22
i64X's Avatar
Drives: 2008 Evo X GSR SSS
^^^ Not gonna happen. Get a head unit with Bluetooth built in. The F700 is $400 and has it. Most modern ones do. The Sirius module is behind the glove box and uses a proprietary connector for the stereo (although when I looked at it, you may be able to get the factory Sirius antenna to work). Pioneer uses IPBus for it's accessories (like XM, Sirius, HD Radio, etc.). The Mitsu unit is definitely something else.
Offline
Old Jun 3, 2009, 05:16 AM   #23
Personal Sales Rating: (1)
strife's Avatar
Drives: 08 Evo GSR, 07 Outlander XLS
The factory Bluetooth is seperate from the radio in our cars, so you can use it with another headunit. (its all voice controled anyway). satalite radio will not work with anything other than the stock radio.
Brian-
Offline
Old Jun 4, 2009, 10:48 AM   #24
factory bluetooth still work fine, the only thing is missing the display. Any idea for keeping the steering wheel control, bluetooth control for the Avic Z2? because i dont to leave the control on the wheel with nothing to do.
Offline
Old Jun 4, 2009, 10:49 AM   #25
i64X's Avatar
How are you going to edit or manage Bluetooth settings when the display is gone? What happens when you get a new phone, or want to dump some contacts?
Offline
Old Jun 4, 2009, 10:53 AM   #26
yea, that's why i ask for some idea, i can buy a new bluetooth kit for an after market use but i want to keep the bluetooth steering wheel control for the new kit, is it possible?
Offline
Old Jun 5, 2009, 05:31 AM   #27
strife's Avatar
You cannot do anything from the display exept dial numbers. All setup/pairing/name entry/etc, is done though voice prompts. The car has to be in park/neutral and then you press the talk button on the stering wheel. The car will ask you questions and tell you your options.
Brian-
P.S. The screen only shows the number that is calling you. There is no way to make it show a name.
Offline
Old Jun 7, 2009, 02:36 PM   #28
Drives: EVO
Quote:
Brian-
I assume you can shut off factory bluetooth right? so if you get an aftermarket system you do not want 2 units answering at the same time lol.
Offline
Old Jun 7, 2009, 07:40 PM   #29
strife's Avatar
Yes, you just don't pair the phone with the OEM bluetooth and avoid pushing the Speak button on the steering wheel.
Offline
Old Jun 8, 2009, 01:22 AM   #30
well, what i want to do is when i press the speak button on the steering wheel it will be turn the affter market's bluetooth on. I mean, i want to use the bluetooth steering wheel control for the after market unit instead of the factory bluetooth. What can i do?
Offline
Tags
02, 2002, evo, evox, head, install, installation, lancer, metra, mito, mito01, mito02, mitsubishi, outputs, pill, preamp, problems, rockford, unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
