Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Audio & Security
Evo X Audio & Security Discuss new audio system upgrades or alarm configurations.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 9, 2009, 09:21 PM   #31
Personal Sales Rating: (3)
REDEVO08's Avatar
Drives: 2008 Evo
yea 2.0
__________________
315whp/350wtq on Dyno Dynamics Dyno
K&N Cone Filter
Custom 3inch Catback
Passport Boost Gauge
Eibach Springs
Spec Stage 3 Clutch
ACT Lightweight Flywheel
Hawk Brakes
Pioneer Indash Navi
Suede Shift Boot W/Red Stitching
Forge Motorsport Wastegate Actuator
Works Shortshifter W/AMS bushings
Agency Motor Mount
ETS Intercooler W/Intercooler piping
T1R 3inch o2 Housing W/Downpipe
T1R 3inch HFC
To Do:
20% Tint, Ralliart TailLamps, HIDs
Offline
Old May 9, 2009, 09:34 PM   #32
Personal Sales Rating: (1)
wiretap's Avatar
Drives: Evo X GSR
Quote:
Originally Posted by REDEVO08 View Post
mine is sorta the same..i am tryin to find a way to get rid of it
To get rid of it, you'll have to have a better ground with less noise coming through it.
Quote:
Originally Posted by Tonic25 View Post
Did you upgrade the map on it?
I'm doing the patched ezrider.exe + 2008.4 maps + 2008.10 POI's tomorrow.
Today I made some custom sound schemes (button click noises, etc), updated my XM logos, added the branded POI logos, and messed with the navigation UI/ini settings.
Offline
Old May 9, 2009, 11:29 PM   #33
REDEVO08's Avatar
Drives: 2008 Evo
its grounded right behind the radio to the bolt on that cross beam
__________________
K&N Cone Filter
Eibach Springs
Spec Stage 3 Clutch
Hawk Brakes
Pioneer Indash Navi
Agency Motor Mount
T1R 3inch HFC
To Do:
Offline
Old May 10, 2009, 11:30 AM   #34
Personal Sales Rating: (0)
Greedy_son's Avatar
Drives: 09 Lancer GT
Quote:
Can you put up some pictures of you custom setup?
I placed my mic in the same location you did. Works great A+, i would recommend this location for anyone with a bluetooth mic.
Offline
Old May 10, 2009, 11:40 AM   #35
wiretap's Avatar
Drives: Evo X GSR
You can find all the hacks and pictures on AVIC411.com.
Offline
Old May 11, 2009, 05:21 AM   #36
Personal Sales Rating: (14)
reggiesd's Avatar
Drives: ob evo x
nice set up!
Offline
Old May 11, 2009, 06:50 PM   #37
wiretap's Avatar
Drives: Evo X GSR
Thanks. =D
Offline
Old Jun 3, 2009, 01:51 AM   #38
Personal Sales Rating: (2)
Drives: EVO X MR
reverse and parking wires???
I'm installing an Eclipse AVN726E and hoping you can help...
I got everything except where to wire the reverse and parking brake wires. I have a MR and it has a "extra connector" for the OEM nav so I imagine I can tap into those wires if I can figure out what they are.
Any idea which wires are for parking and reverse?
Offline
Old Jun 3, 2009, 02:24 AM   #39
wiretap's Avatar
Drives: Evo X GSR
The parking brake is easy to find.. it's connected right to the parking brake under the center console if you take the cupholders out. As far as reverse, I don't know. Just run a wire to the trunk and connect to the +12v reverse bulb wire.. it's white I believe.
Offline
Old Jun 3, 2009, 02:40 AM   #40
Personal Sales Rating: (55)
Domolution's Avatar
Drives: RC Cars!
Send a message via AIM to Domolution
Wow...that looks REAL clean! I like it alott.....i am just gonna say i am jealous!
Everything you did was legit, just admiring your work, car, and Balling Pioneer F-Serious, haha!
Offline
Old Jun 3, 2009, 03:36 AM   #41
Drives: EVO X MR
hey, thanks for the quick response!
Yeah, I was hoping to avoid running wires anywhere so I was really hoping that parking and reverse would be on that extra plug. You would think that since this is the only extra plug that is used by the OEM nav unit, that it would have the necessary nav wires which are usually parking brake, reverse and VSS. The good news is that the Eclipse unit does not need the speed sensor wires. So I just need to figure out the reverse and parking.
thanks again
Offline
Old Jun 3, 2009, 03:41 AM   #42
i64X's Avatar
Drives: 2008 Evo X GSR SSS
The F700 didn't need the speed sensor wires either. My old AVIC-D1 did. The AVIC-D1, because of this, was more accurate as far as nav goes than the F700. I wish the F700 had a speed sensor wire, as well as a built in compass. In tight spots, it doesn't know which direction the car is facing.
Offline
Old Jun 3, 2009, 01:35 PM   #43
wiretap's Avatar
Drives: Evo X GSR
@i64X.. The F700 has a wire for VSS. I didn't hook it up though.
@jump23.. I don't have the pinout of that nav harness. I'm sure all the wires are on there.
Offline
Old Jun 3, 2009, 03:05 PM   #44
i64X's Avatar
Mine didn't. It says in the manual that the F700 doesn't require this wire and it wasn't in my harness. I've got the MITO-02 so that supplied a VSS wire and a reverse lead. Oh well, it still works. :-)
Offline
Old Jun 23, 2009, 10:00 AM   #45
ice1874193's Avatar
Drives: 2008 Evo X - SSS w/ Aero
my x has the factory xm - just unplug the xm connection and plug into the pioneer and i'm all set?
**edit - sirius radio
Offline
Tags
avic, avicf700bt, card, doftware, fseries, hacks, install, mod, mode, mods, pioneer, putting, sd, series, test, testmode, usb, videos
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
