Jan 27, 2009, 06:12 AM
#46
Personal Sales Rating: ( 0)
Drives: 2009 Mitsubishi Lancer GTS
and actually thats my fault there are 3 variations of the head unit, the normal, the 6 cd, and the nav. I forgot the single cd one was out there
Offline
Jan 27, 2009, 06:14 AM
#47
Personal Sales Rating: ( 1)
Drives: 08 Evo GSR, 07 Outlander XLS
No worrys, I didn't think you were being an ass.
If I'm wrong about something I want to know. I tend to way over explain stuff and for once tried to dumb it down but it back fired. Ya it sounds like we are saying the same thing.
Brian-
Offline
Feb 3, 2009, 04:00 PM
#48
Drives: Evo X GSR
what about an aftermarket amp, and head unit with RF sound system?
Offline
Feb 3, 2009, 04:20 PM
#49
an aftermarket amp will work as long as it as high level inputs (25 watts by 4) type. just like any other factory head unit.
Offline
Feb 16, 2009, 03:13 PM
#50
Drives: 08 WW Evo X
This sounds like ALOT of trouble...I just bought the digital factory amp turn on MITO-01. $80 harness but plugs right up.
Offline
Feb 16, 2009, 03:28 PM
#51
Quote:
Guess you didnt do much research then. That harness will not work on the lancer. It was for the eclipses.
The MITO-02 when it comes out will work for the lancer.
hopefully you can return your Mito-01 if you have a lancer because its goign to be useless
Offline
Feb 16, 2009, 03:59 PM
#52
Drives: 08 WW Evo X
No way really? it says specifically for evo x
Correction** I preordered version 2 haha
Reason: Correction
Offline
Feb 16, 2009, 04:23 PM
#53
Ok. Yeah 02 will work but I don't think you will see it for a long time though. It's been in this state for about 8 months now and no one at metra has clue if they are even close to releasing it. I perso ally don't think it is going to be out for a long while if at all because if the complexity of the new can bus system and the fact that mitsubishi is changing the can bus again in the 2010 model year cars
Offline
Feb 16, 2009, 04:28 PM
#54
Drives: 08 WW Evo X
That really blows, so theres no other harness out yet? meaning the only way to use the factory amp is the way in this post?
Offline
Feb 16, 2009, 04:47 PM
#55
Corect. Scosche is not making on period. Metra would be the only option but like I said I don't see it happening. This is the only way tto do it with the stock fosgate system right now. Itbis easy and doesn't take long at all. It wife loves her setup now
Offline
Feb 16, 2009, 05:07 PM
#56
Drives: 08 WW Evo X
ok lets say i replace the stock amp can i use the stock sub or do i have to replace that too?
and is it also possible to just replace my amp witht eh amp from and eclipse and jsut run the mito-01?
Reason: addition
Offline
Mar 12, 2009, 06:58 AM
#57
Personal Sales Rating: ( 27)
Drives: 06 SSL and now WW X
hoping that somebody will step up and make a cleaner solution
Offline
May 27, 2009, 04:41 AM
#58
Finaly they came out with a real solution!
Thanks Boy36, he started a thead about the new Metra MITO-02. This allows you to use the stock amp with out my mod.
Heres the link:
Metra MITO-02
Offline
Oct 22, 2009, 11:43 PM
#59
Drives: 2008 Evolution GSR
thanks for the heads up..I'm getting the pioneer double din in my GSR next week but keeping the RF sound system now
Offline
Tags
06, airbag, amp, g35, gts, harness, lancer, light, recaro, remote, scion, seat, stereo, stock, tc, turn, wire  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
