Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 17, 2008, 07:50 AM   #16
Personal Sales Rating: (3)
REDEVO08's Avatar
Drives: 2008 Evo
THANK GOD..THANK YOU FOR THE POST..I have been going nuts for the color code of the speaker wires..
Offline
Old Nov 21, 2008, 09:53 AM   #17
Personal Sales Rating: (0)
Mikebus7's Avatar
Drives: Phantom X- MR
Never mind-
Offline
Old Jan 15, 2009, 02:56 PM   #18
Drives: 2009 Mitsubishi Lancer GTS
so just curious, how is this system holding up sound wise. Compareable to stock. Also what wire in the harness did you tap for the VSS wire for the navigation. Im about to do this and it would be a huge help
also it looks like you went yellow from the new harness to the red white of the stock harness. Is that what you meant to say. Are the wire colors in the car flopped compared to the aftermarket radio.
thansk
Offline
Old Jan 15, 2009, 08:35 PM   #19
Personal Sales Rating: (1)
strife's Avatar
Drives: 08 Evo GSR, 07 Outlander XLS
It sounds just like the factory with the sound field turned off. The Alpine Nav doesn't use the VSS. It gets its speed from the GPS module, its right on, give or take a MPH.
Brian-
Offline
Old Jan 16, 2009, 03:57 AM   #20
k, what do you mean by the cound field? Do you mean on the stock stereo the pop, rock, dance selection? Also i know you left the bass and trebel; and mid at 0 on the stock but did you turn the punch setting up at all on the stock or leave that 0 too.
Are you still able to get the same bass out of the system now.
Just want to make sure this is the right decision for us, for now
Offline
Old Jan 16, 2009, 03:58 AM   #21
Quote:
Brian-
yeah but we have a bunch of tunnels here, the gps module wont track it then. I found out which one it is now.
Tahnsk though
Offline
Old Jan 19, 2009, 04:03 PM   #22
by the way did you have to up any of your fuses to handle running both stereos
Offline
Old Jan 19, 2009, 04:16 PM   #23
could you confirm which soundfield needs to be turned off, stock radio or pioneer. Also are the wires opposite in the car, i think i red someonewhere that in the car the red is the ignition and yellow is constant, I just want to confirm because you have yours stated as the opposite of that.
please help.
Trying to install tomorrow and my volt mete is not working.
Offline
Old Jan 20, 2009, 05:27 AM   #24
strife's Avatar
By soundfield I mean the "rock", "jass", "classical", etc and the settings for "hall", "stadium" and "stage".
That’s good that you found the VSS wire, please post that info some were for others that may not know.
Its been awhile now since I installed that radio but I remember my post being correct about the wire colors and no one has corrected me yet.
The fuse for the radio is far bigger than needed and will be more than enough for the old radio and the new radio. The new radio will draw much less than 1amp @12VDC without using the on board 50x4 amp. The factory old radio will only draw 250mA @12VDC or so (0.25amps) The radio wires are 18awg and can handle 10amps but my rule of thumb is to keep it less than 6amps on 18awg wire or it can get warm.
Offline
Old Jan 20, 2009, 05:30 AM   #25
strife's Avatar
Also,
hook up the new radio and get it working. Then plug the old dash into the HVAC and play with the controls for the factory radio. change the volume, soundfields, bass, etc until it sounds the way you like. Then unhook it and finish the install.
Offline
Old Jan 20, 2009, 05:48 AM   #26
awesome thanks.
as for the vss, yeah ill post it here and then see if i can get a post stickied but it is the white wire blue tracer on the 20 pin connector that goes into the stock radio
Offline
Old Jan 24, 2009, 01:58 AM   #27
Personal Sales Rating: (6)
endGameXIII's Avatar
Drives: Evo X GSR
hm...is there a more elegant way to approach this? it just screams ghetto to require the original HU sitting inside the dash...
Offline
Old Jan 24, 2009, 06:54 AM   #28
nope the harness doesnt exsist yet.
Did it last night and it took me 35 min. Just have to go put the trim piece on this morning.
Offline
Old Jan 24, 2009, 08:22 AM   #29
strife's Avatar
PGH,
how does it work for you?
Did you find a treble/mid/base and soundfield setting that sounds good for you?
Offline
Old Jan 24, 2009, 11:16 PM   #30
Drives: Evo X GSR
oh i know the harness doesn't exist yet...but i can't shake the thought that there has to be a better way to do this. whether it be splicing, soldering, etc...i dunno. my curious self is running loose, so maybe i'll experiment as well.
Offline
Tags
06, airbag, amp, g35, gts, harness, lancer, light, recaro, remote, scion, seat, stereo, stock, tc, turn, wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
