Aug 22, 2008, 12:59 AM
Personal Sales Rating: ( 0)
Drives: EVO X GSR
Quote:
Originally Posted by schwartz1
you have any problems with your F900BT btw? can you PM me? I have some questions about it that you may be able to answer about it.
i having tons of problem with it. It's junk, waiting for the new firmware upgrade
Offline
Aug 24, 2008, 05:53 PM
Personal Sales Rating: ( 1)
Drives: X MR
Quote:
Originally Posted by untuned
The c103 connector is only if you have the factory navi. here is the copy and paste from the service manual
Can you clarify this? If I have factory navi, are you saying the wire is on the C103 connector? How many pins does it have and what is the color? Thanks.
Also, I found the brown/white wire at the ECU but that is not working
__________________
03 VIII sold and missed
Proud owner PB X MR
Offline
Aug 28, 2008, 12:19 AM
Drives: X MR
ummm bump
__________________
Proud owner PB X MR
Offline
Aug 28, 2008, 07:31 AM
Personal Sales Rating: ( 4)
Drives: 08 PB EvoX
No, the VSS wire is pin 31 on C107, which is the big connector that plugs into the stock radio. He was simply saying that C103 is the other, smaller connector that plugs in the radio.
Look at the wiring diagram a few posts up, and you'll see all the details outlined. (White with blue stripe)
Offline
Sep 6, 2008, 02:07 AM
Drives: X MR
Thanks! Indeed I found it. I had the MMCS unit which used several connectors. The vss is on the only 20 pin connector of the bunch and it is white w/ blue stripe. This is the same harness that connects to the Metra (or the like) aftermarket harness.
Also, my new nav unit disables all nav functions if the vss shows 4+ mph. I'm not sure if other nav's do this or not. I found this seriously annoying so I connected a rocker switch inside the top if the cubby hole, above the stock Ipod RCA input. When the switch is in on, the vss signal connects through to my nav. When it is off, the vss is not connected and my nav thinks the vehicle is stopped and allows me to change settings. Hope this helps people. I searched for 1+ months trying to find vss and details.
__________________
Proud owner PB X MR
Offline
Jan 20, 2009, 06:06 AM
Drives: 2009 Mitsubishi Lancer GTS
so it seems as if a couple people have used this white wire blue trace to get the vss signal. Am I correct.
Some of these posts are confusing.
If you have used that white wire blue tracer are you getting an accurate speed feed.
thanks
Offline
Mar 5, 2009, 06:16 PM
Personal Sales Rating: ( 2)
Drives: ww evo x
which is the vss on the ecu? i tried the brown with white tracer wire but that doesn't give me a signal.
Offline
Mar 5, 2009, 07:19 PM
Drives: X MR
Forget about the brown with white tracer. You want the white with blue tracer on the only 20 pin harness behind the head unit.
__________________
Proud owner PB X MR
Offline
Jun 8, 2009, 10:53 AM
Drives: EVO X GSR
Does every one here have the premium radio? I got the base radio and tried tapping to the white/blue wire on the larger connector at the back of the radio but got no signal. Any ideas?
Offline
Jun 8, 2009, 01:11 PM
Personal Sales Rating: ( 3)
Drives: 08 Evo GSR, 90 Talon, 01 929RR
thanks
Mine is very accurate
__________________
2008 WW Evolution GSR
1990 Eagle Talon Tsi AWD
2001 Honda CBR929RR
Offline
Jun 25, 2009, 01:45 AM
Drives: 2009 lancer
where the Speed sensor wire on a 09 lancer DE ?
I have a 09 lancer DE 4 spaeker sterio .installed a navi ,need vss wire, please help!
Offline
Oct 13, 2009, 02:14 PM
Drives: 08 EVO X WW GSR SSS Aero Navi
IN case anyone still has trouble here is the wire you need. Works great. I needed it for my AVCR install.
Offline
Oct 20, 2009, 08:12 AM
is this a picture for the connector for the basic non navigation deck?
Offline
Oct 22, 2009, 05:35 PM
this is nav but the harness at that point should be same as that plug goes into a subharness before going into radio
Offline
Oct 27, 2009, 02:29 AM
Drives: 2008 EVO X GSR
if someone can clarify, I am trying to get the magden in-dash gauges to work with a factory NAV unit,. Works awesome stationary, stops once car is in motion. It is plugged into the aux input video source. So if I remove the white/blue wire as indicated in the post will that allow the gauges stay on screen once the car is in motion? if you remove the wire are there any negative aspects? thanks for the help
__________________
Road Race Engineering/ Rotora |Anaheim Mitsubishi|Forced Performance RED Turbo|Rotora Big Brake Kit|Exedy Multiplate Clutch Kit|KW V3 Coilovers|AEM Intake|RRE Custom Exhaust|AGP Intercooler & Piping|Ultimate Racing DownPipe|VoltPhreaks Lightweight Race Battery|RobiSpec Setup|Nitto NT05 Tires|Enkei GTC-01 Wheels|TWM Short Shifter|DeatschWerks 800cc injectors|Mishimoto Radiator|HERTZ Audio System|MOMO Race Gear|Zeitronix Gauge|Cleaned by Mother’s Polishes|Halo HID Fog lights|
Offline
Tags
2003, 2009, connected, evo, evox, f900bt, gts, lancer, location, mitsubishi, pin, sensor, signal, speed, vss, wire  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
