CT9A Chassis Weakpoints
Old Nov 5, 2012, 08:35 AM
  #196
kyoo's Avatar
bump
Old Feb 7, 2013, 03:13 PM
  #197
Johns_EVO_IX_SE's Avatar
One thing I noticed after installing the fender bracing, was that under heavy braking the back end wiggled a lot. It wasn't even noticable before. i have the rear trailing arm bushings as well. I was talking to Robert Fuller about this at the track, and he mentioned this is where the hard bearing kit would come in hand to keep the car more stable and keep the bushings from wiggling around.
Old Feb 7, 2013, 03:30 PM
  #198
arpad's Avatar
Good info, thanks for sharing that!
Which hard bearing kit are you referring to?
Old Feb 7, 2013, 03:51 PM
  #199
kyoo's Avatar
interesting, thanks for the info!
Old Feb 8, 2013, 06:03 AM
  #200
TommiM's Avatar
would adjusting the rear toe help any with that?
Old Feb 8, 2013, 07:38 AM
  #201
alleggerita's Avatar
I suspect that the hard bearing kit minimizes dynamic toe changes under braking. Yes you could probably tweak toe in one direction or the other direction but there would be other costs associated with it.
Old Feb 8, 2013, 12:23 PM
  #202
^ Right you are. It also helps with wheel hop for drag racing and getting on the gas on corner exit. My car doesn't have that much power compared to some, but I'm sure the hard bearing kit will allow one to exit a corner much smoother without wheel hop and that weird back and forth sensation Evo's have when getting on the gas real hard.
Will also help with the car being more precise when going 10th/10ths during cornering.
You can read about David Buschur's review on the hard bearing kit here: http://highboostforum.com/forum/show...-from-Robispec
I think Robispec will be doing a group buy on the hard bearing kit at one point. It's not cheap. My friend has it on his Evo, and the car feels very "precise". The ride is firm, but not liver killing or anything.
Old Mar 10, 2013, 10:53 AM
  #203
R/TErnie's Avatar
^ I'm in the process of getting the Robi hard bearing kit... going to do it a few bushings at a time! lol. Robi makes great stuff.
Old Apr 18, 2013, 04:55 AM
  #204
17pstockcar's Avatar
Is robispec still around? His website is down.
T/TErnie how did you get on with the hard berring kit?
Cheers
Shane
Old Apr 18, 2013, 11:44 AM
  #205
TommiM's Avatar
Is Robispecs kit similar to the Nagisa Auto hard bearing kit?
bh117
Oct 15, 2016 06:25 PM
Tanabe USA
Feb 20, 2014 09:52 AM
kyoo
331
Oct 31, 2012 06:44 AM
trinydex
23
Sep 17, 2009 12:44 PM
jbrennen
Jan 19, 2005 10:01 AM
Quick Reply: CT9A Chassis Weakpoints
