Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 22, 2004, 10:07 AM   #1
Personal Sales Rating: (0)
Tri-Bar's Avatar
Drives: 2003 Evo 8
Send a message via ICQ to Tri-Bar Send a message via AIM to Tri-Bar
Spring Rate Chart
Here is a list of the spring rate's for the Evo 8. If you know of any more, or if you have a corraction, let me know and I will change it.
Thanks.
Evo Spring Rates
Name
Lowering Springs:
...................................Front.......... ........Rear.............drop
Eibach Pro-Kit:**....165lbs(2.9k)....140lbs(2.5k)....1.2f / 1.2r
Espelir ASD:............263lbs(4.7k)....319lbs(5.7k)....79 f / .79r
Espelir GT:..............308lbs(5.5k)....330lbs(5.9k)....1 .7f/ .98r
Ralliart:...................280lbs(5.0k)....307lbs (5.5k)....0.5f / 0.5r
RSR:**....................224lbs(4.0k)....280lbs(5 .0k)....1.4f / 1.4r
RSR Ti2000..............280lbs(5.0k)....336lbs(6.0k).. ..1.4f / 0.8r
Stock(USDM):..........180lbs(3.2k)....225lbs(4.0k) ......STOCK
Tanabe GP210:.......256lbs(4.6k)....319lbs(5.7k)....1.5f / 1.0r
Tein High Tech:**...196lbs(3.5k)....268lbs(4.8k)....1.4f / 0.3r
Tein S Tech:**........212lbs(3.8k)... 291lbs(5.1k)....2.0f / 0.9r
Coilovers:
APEXI PRO:..............560lbs(10.K).....560lbs(10.K)... .Adjustable
CUSCO Zero 1:........392lbs(7.0K).....280lbs(5.0k)....Adjusta ble
CUSCO Zero 2:........392lbs(7.0K).....280lbs(5.0k)....Adjusta ble
CUSCO Zero 2R:......392lbs(7.0K).....280lbs(5.0k)....Adjustab le
HKS Hypermax II:....392lbs(7.0k).....336lbs(6.0K)....Adjustable
HKS Hypermax RS....336lbs(6.0K).....280lbs(5.0k)....Adjustable
HKS Kansai Tarmac:.448lbs(8.0K).....448lbs(8.0K)....Adjustabl e
HKS Kansai Track:....896lbs(16.K).....784lbs(14.K)....Adjusta ble
HKS Performer:........392lbs(7.0k).....336lbs(6.0k)... .Adjustable
HKS PRO:.................672lbs(12.K).....672lbs(12.K) ....Adjustable
JIC FLT A2:...............560lbs(10.K).....504lbs(9.0K)... Adjustable
OHLINS FLAG L:.............ANy ..............Any ...............Adjustable
OHLINS R/T:.............250lbs(4.4k).....310lbs(5.5k)....Ad justable
Ralliart:....................336lbs(6.0K).....336l bs(6.0K)....Adjustable
Tein Basic:...............392lbs(7.0k).....336lbs(6.0K) ....Adjustable
Tein Flex:.................672lbs(12.K).....560lbs(10.K ).....Adjustable (Corrected 6/6/06)
Tein SS:...................392lbs(7.0k).....336lbs(6.0k )....Adjustable
Tein RA:...................672lbs(12.K).....504lbs(9,0K )....Adjustable
Tein HA:...................504lbs(9.0K).....392lbs(7.0K )....Adjustable
Tein HT:...................896lbs(16.K).....672lbs(12.K )....Adjustable
ZEAL:.......................336lbs(6.0K).....280lb s(5.0k)....Adjustable
ZEAL Also:...............448lbs(8.0k).....392lbs(7.0k). ...Adjustable
** = progressive rate
Edit: Edited Tein Flex adjustable as per info from chmodlf
__________________
Brake, Blip, Shift, Turn, Gas. Repeat.
Offline
Old Feb 22, 2004, 11:53 AM   #2
Personal Sales Rating: (2)
sir lurks alot's Avatar
Drives: evo8
Great Post!
Anybody know what the drop on the RALLIART springs are?
Offline
Old Feb 22, 2004, 12:38 PM   #3
Personal Sales Rating: (19)
.5"
Offline
Old Feb 22, 2004, 01:33 PM   #4
Personal Sales Rating: (22)
Evo Ate's Avatar
Drives: NAKED
Is that the right spring rate for the stock springs? If so why are the Eibach springs so soft, I was looking into getting a set. I like the fact they only have a 1" drop all around.
__________________
"I want the truth"....."You Can't Handle The Truth"
Offline
Old Feb 22, 2004, 05:20 PM   #5
Personal Sales Rating: (4)
Hopefully you got the data from the manufacturers and not from message boards.
RS-R has different figures. http://www.rs-r.com/suspension_springs.htm
I'd also take rates for progressive spring with a grain of salt, since they're not static like linear springs.
Offline
Old Feb 22, 2004, 06:51 PM   #6
Tri-Bar's Avatar
Drives: 2003 Evo 8
nOOdle,
Thanks for the web site. I when looking for it and never found it. The chart has been updated.
Keep them coming!! From what I hear and found, The Eibach Pro-Kit are soft.
__________________
Offline
Old Feb 22, 2004, 09:00 PM   #7
Drives: 1997 Audi A4 1.8TFMS *modified*
Send a message via AIM to Audi Shep Send a message via Yahoo to Audi Shep
What are the Evo's stock spring rates?
Is there really that much to be desired with the suspension, that it needs to be modified significantly?
Is there any one company that shines at suspension systems for these cars?
My appologies for being a n00b.
Offline
Old Feb 22, 2004, 10:14 PM   #8
Personal Sales Rating: (1)
wojo's Avatar
Drives: 997 C2S, e46 330i, Range Rover Sport
Send a message via AIM to wojo
Your JIC FLT-A2 rates are reversed. The front is 10k and rear is 9k
Offline
Old Feb 23, 2004, 09:39 AM   #9
Tri-Bar's Avatar
Drives: 2003 Evo 8
Thanks wojo. list has been updated. Does any one know the rates for the Ohlins Road/Sport coilovers I have not been able to find it.
__________________
Offline
Old Feb 23, 2004, 09:52 AM   #10
Tri-Bar's Avatar
Drives: 2003 Evo 8
The stock spring rate are soft front 180lbs(3.2k) rear225lbs(4.0k). The struts and shock are highly valved for high speed damping,but lack the low speed we need for the street, will know more on them when I can get over on a shock dyno to test them out better. There are a few stand outs on the suspension system side. Cusco, JIC, Ohlins,DMS. I my self are looking into the Ohlins for a good over all system(street and track).
__________________
Offline
Old Feb 23, 2004, 06:32 PM   #11
Personal Sales Rating: (3)
Shahul X's Avatar
Drives: 2009 NISSAN GTR (white premium) ......07 CRV NAV, 08 Accord EX-L... formers: 06 Tsx-navi 6spd, 06 Ridgeline NAV, 01 Miata spec, 03 RED EVO VIII,02 RSX typeS, 2000 Eclipse GT, 1994 Supra, 1995 Prelude Vtec, 1991 Prelude Si
Send a message via AIM to Shahul X
ralliart is .5 all the way around.... ? I was hoping 1" .... what about the Espleirs?
-shahul
__________________
Shahul Usman
2009 nissan GTR Premium
Ivory Pearl
Cobb Stage 1, HKS filters
Offline
Old Feb 23, 2004, 10:21 PM   #12
Tri-Bar's Avatar
Drives: 2003 Evo 8
Shahul X, not sure about the Espleirs. I will try and look into it.
__________________
Offline
Old Feb 24, 2004, 07:38 AM   #13
Personal Sales Rating: (7)
instigator's Avatar
Drives: 03 Evo VIII (Sold)
Quote:
Because they are progressive rate. I think that information needs to be added.
Offline
Old Feb 24, 2004, 08:57 AM   #14
Shahul X's Avatar
thanks TRi
-shahul
__________________
Shahul Usman
Ivory Pearl
Offline
Old Feb 24, 2004, 09:20 AM   #15
Tri-Bar's Avatar
Drives: 2003 Evo 8
Instigator.
Which spring is progressive rate ? Stock or the Eibach's I will add this to the list. Thanks.
__________________
Offline
Tags
10k, chart, eibach, evo, gf210, mr2, progressive, range, rate, rates, rover, rsr, spring, stock, tanabe, viii
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
