[ Info needed? Brakes, Pedal goes down too much ] -.-
Old Sep 2, 2012, 04:04 PM
EVOEvolved's Avatar
Exclamation [ Info needed? Brakes, Pedal goes down too much ] -.-
Alright, I replaced a brake line on my EVO , left rear passenger. FOr some reason I still have air after bleeding the entire brake system.
IT says to have the running, and bleed in this procedure. RR, LF LF, RF. I did that a few times and still it is about the same. WE also cracked open the lines no the master cylinder to get air out, any suggestions would be great.. : |
Old Sep 2, 2012, 04:16 PM
rburris28's Avatar
Are you experienced in bleeding brakes so that you're sure you're doing it correctly?
Did you bleed both bleeder screws (inner and outer) at each corner?
Old Sep 2, 2012, 05:07 PM
Solenoid's Avatar
This method is pretty sound. Please read & perform the re-bleed
Mike
http://www.joe250.com/cars/evo8/brak...ebleeding.html
Old Sep 2, 2012, 05:10 PM
deylag's Avatar
Should be Passenger Rear then Driver Front then Driver Rear then Passenger Front. This is the order specified by the Mitsu Full Service Manual.
Old Sep 3, 2012, 07:21 PM
EVOEvolved's Avatar
Well I figured out what I did incorrectly. I have yet to bleed a brake system like thus before, and I did not know (even though ti was quite strange because I felt there could be the bleeder on the inside of each caliper, I ignored my own institution) that it was the bleeders no the inside; which were never touched at all.
So, I will be bleeding those, thought I would update everyone, I am sure I am not the first, nor the last person to do this. You learn a lot each day.
Thanks for the help guys, I appreciate it.
g7igo7
Jun 15, 2017 09:13 PM
NewEvolutionIX
13
Aug 26, 2016 04:41 PM
vipevo9
Aug 25, 2016 12:36 PM
Endless AWD
May 19, 2011 07:16 PM
ev8sive
11
Feb 12, 2005 02:02 PM
Quick Reply: [ Info needed? Brakes, Pedal goes down too much ] -.-
