Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack Discuss everything that helps make your car start and stop to the best of it's abilities.
Sponsored by: Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Apr 2, 2011, 06:56 AM   #1
Personal Sales Rating: (11)
Garage is empty, add now
Drives: evo8 sold , 911 turbo :), audi A3 APR tuned, Mitsubishi Endeavor XLS AWD
Rear end wobble?
Does worned bushings would cause a slight wobble at low send on bumps and at high speed?
Just got my car aligned and the rear trailing arms toe bushings are worned.
The car wobble from side to side even with increase tire pressure. It is not felt in the steering but a feeling that the chassis moves wiggling.
The problem started on uneven pavement and when hitting potholes at speed and ice the car would shift fast from one side to another.
Let me know what you think.
Would blown shocks cause this also? No leaks, on straight clean pavement no problem even with a few bumps, the same int the city.
Offline
Old Apr 2, 2011, 07:24 AM   #2
Personal Sales Rating: (1)
nelale2's Avatar
Drives: 03 evo VIII, 240sx
Send a message via AIM to nelale2 Send a message via Yahoo to nelale2
I had horrible rear end wobble on my 240 when the rear camber was way off (effecting toe) at low speed the rear end would move side to side unpredictably and lessen a bit at higher speed. fixed camber and adjusted toe to proper settings and the issue went away.
Offline
Old Apr 2, 2011, 09:21 AM   #3
The problem is that I aligned the car yesterday and it still wobbles. The bushings are worn for sure soo I will try it but toe is at 0 front and rear. Camber within specs. I guess it shakes and affect toe immediately because the bushings moves.
Would a tall crappy tire create some wobble too?
Offline
Old Apr 2, 2011, 10:27 AM   #4
Personal Sales Rating: (0)
dastallion951's Avatar
Drives: 03 evo 8 bby
DASTALLION951
worn bushings can cause a wobble due to suspension back there movin at higher speeds, try havin the tires balanced and right pressure put in first. how many miles on vehicle? have struts been changed? those can cause it too...recommend replacin parts first
Offline
Old Apr 2, 2011, 01:41 PM   #5
I'll replace all bushings and report back.
Just changed my struts for a used MR bilsteins.
But the problem was there before thoses so...
Offline
Old Apr 2, 2011, 01:42 PM   #6
112k miles
Offline
Old Apr 3, 2011, 09:26 AM   #7
DASTALLION951
another thing it could possibly be other then bushings, shake the rear tires up and down at 12 and 6 o clock position, with that kinda mileage, you could also have a wheel hub bearing issue back there....two man job, one shakes it other look at the back of where the axle goes through the hub, see if you can see movement. Also look around the suspension, if you have worn parts, your car wouldnt have been aligned right in the first place, if the shop aligned it with worn parts sounds like they possibly wanted your money, or you wanted it aligned anyways. So check it yourself, or have a professional inspect your suspension to have the problem remedied once and for all.
Good luck
Offline
Old Apr 3, 2011, 06:27 PM   #8
Thanks for your great help. Thats very good advice.
I'll check everything tomorrow and report back. I think I have also bent rims but I don't know if that cause the wobble at low AND high speed because it's intermittent and the feeling is that ONLY the chassis move form side to side not a vibration just the boat feeling.
Offline
Old Apr 4, 2011, 09:48 AM   #9
DASTALLION951
a bent wheel can cause it, to the eye kinda tough to tell if a wheel is bent other then seein if the lip on each side is bent, But best way to check if wheel is bent is having it spin on a balancer, if its bent itll hop like a basketball. So best bet, take each tire and wheel off go to an auto repair shop have them "road force balance" ask them if they have that, if they do itll be more expensive but youll get a better balance on the wheel. If not a normal balancer will work, but road force balancing puts a load wheel on the tire for a better balance, to get rid of the heavy spot on the tire. good luck pm me if you have any more questions.
Offline
Old Apr 4, 2011, 03:19 PM   #10
Personal Sales Rating: (20)
fantrman's Avatar
Drives: Evo IX SE, TR6, G35, E36 M3 (sold)
Quote:
Good luck
Good advice, but another way to check for wheel bearing play is to shake the wheel while the car is on the ground. Grab the top of the tire at 12:00 with both hands and pull back and forth with some decent effort. Try to get the car to shaking side to side. If there is any excessive end play, you will feel it. We use this method while doing tech inspection at autocrosses.
__________________
BR 2.3, Unported head, FP Black, GSC S2s, Supertech springs, Toxic Fab EM, MAP 3" recirc dump, 4" SD Intake Pipe, K&N Filter, BR 65mm TB, BR Ported IM, Tial Q BOV, Forge MBC/Grimmspeed 3-Port, FIC 2150cc Injectors, BR Twin Walbro, BR Mini Battery kit (relocated to trunk), Spoolin Up COP, ETS 3.8" Garrett core FMIC, ETS 2.5" Upper & Lower Piping, BR 3" TBE w/ two Magnaflows and a resonator (no cat), ARP Headstuds, Kiggly HLA, Saikou Michi DC3 catch tank, 719whp/585wtq E85, 523whp/453wtq 93 pump: (DJ - std corr). Bilstein HDs custom valved, Swift Spec R springs, Tanabe FSB, Hotchkis RSB, CiroDesign camber/caster plates, TRE 12-plate MaxLock, Rear bumpsteer correction, AWD aluminum driveshaft, ACD-Tuning Autocross map.
Thanks to the expertise of AWD Motorsports, TScomptuned and ACD-Tuning.
TSComptuned 700whp+ FP Black dynojet #s inside
Offline
Old Apr 4, 2011, 07:55 PM   #11
Thanks guy's good advice for sure...
Two bent rims in the back, put my winter tires and a lot better but not perfect, why?
Offline
Old Apr 7, 2011, 10:46 AM   #12
UPDATE
Aligned before this: WOBBLES
Try something else as I thought is was the suspension?
RE-Swap winter wheels with good tires: WOBBLES
Re-swap stock suspension in perfect condition: WOBBLES
3 bent rims repaired and tires perfectly balanced: WOBBLES
The only thing left is toe bushings as I have play but wondering why THAT MUCH wobbling with bushings?
I'm desperate right now, soo much time, trouble, money .....AARRRRRRRRRRRRGRRRRRRRRRRRRRRRRRRRR
Offline
Old Apr 7, 2011, 10:53 AM   #13
fantrman's Avatar
Quote:
Originally Posted by PoloTurbo View Post
UPDATE
Yes, you must be frustrated, but those items should be fixed anyway so you haven't lost anything yet. Question: when you say you re-swapped the stock suspension in perfect condition, exactly which components did you swap?
__________________
Offline
Old Apr 7, 2011, 11:47 AM   #14
I put back the whole shocks with spring assembly.
Even with the slight bump the car wobble side to side and doesnt want too stay straight
Not very confidence inspiring handling.
Chech every component as trainlings arms with a big metal bar and bearings
Nothing there just very little inner toe bushing play.
Offline
Old Apr 7, 2011, 12:00 PM   #15
fantrman's Avatar
Its not the strut assembly - that does not control side to side movement. It's got to be in the suspension or wheel bearings somewhere, you're just not finding it. I count 9 bushing/balljoint locations in the rear suspension each side that could cause this. Are you sure you checked each one? Does the car rock side to side while you are pushing on it while stationary or while driving? And did you check the bushings and balljoints when the suspension is unloaded?
__________________
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
240sx, 4wd, car, driving, end, ending, high, low, nissan, problem, rear, shakes, speed, speeds, terrain, uneven, wobble, wobbling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
