TQ solution rear toe arms question
Old Feb 28, 2024, 07:43 PM
BrunoBoy650's Avatar
I have replaced my rear toe arms with these and set them up per the photo they have on their website per the rep I spoke to at TQ solutions. After alignment the rear was not settling correctly and felt like it “skates”. I have now put the two spacers above the spherical bearing and it is now better but still “skates”. Any information on how to fix this? Current alignment specs on my 03:
front:
camber -2.5
toe 0
rear
camber -1.5
toe factory .24
The arms I have
picture from their website of how it was originally installed but had a “skating “ feel..
Old Feb 29, 2024, 02:38 AM
Ayoustin's Avatar
Gee what a surprise, TS doesn't know how to set up their own product, maybe because they don't actually engineer anything they make. Pathetic copy/paste company.
OP the best starting place is to try and make the toe arm parallel to the upper and lower control arms. Depending on ride height and any geometry corrections will determine which way you need to go from there to minimize bumpsteer.
BrunoBoy650 (Feb 29, 2024)
Old Feb 29, 2024, 07:49 AM
ViciousLSD's Avatar
hmm hard to imagine what could go wrong in this area. i got the megan one with OE balljoints/bushings
Old Feb 29, 2024, 08:38 AM
Dang ok. Thank you both for replying. I was going to go with a Megan or hardrace but thought TS was a reputable company. It’s really bad and not confident inspiring driving my evo. I will need to have it rechecked. It’s unfortunate as I would need to do another alignment. I’ll do my best to take a photo of it on the ground once it stops raining.
only other suspension bits done in the rear are
rear trailing arm bushing (whiteline)
Tein flex Z 10k rear
st 25mm sway bar with adjustable endlinks.
Old Feb 29, 2024, 09:00 AM
ViciousLSD's Avatar
just grease on them bushings
Old Feb 29, 2024, 04:51 PM
https://www.youtube.com/shorts/1c1-gt03oOk
grease on which bushings ?
Old Mar 1, 2024, 08:43 AM
ViciousLSD's Avatar
upper control arms
BrunoBoy650 (Mar 1, 2024)
Old Mar 1, 2024, 11:41 AM
upper control arms
Did you use any specific grease?
Old Mar 1, 2024, 02:11 PM
ViciousLSD's Avatar
I just like white lithium grease for general use. other grease like the ones that come with the bushings turn into soap
Old Mar 1, 2024, 08:08 PM
perfect, so grease all bushings essentially. Thank you.
Old Mar 1, 2024, 11:05 PM
deylag's Avatar
I wouldnt use the factory toe setting when you are much lower than factory ride height. Zero out the toe and then remove spring from the coilover. Compress the suspension and then let it fall and watch the arms/strut to see if they allow full suspension travel.
The following 2 users liked this post by deylag:
BrunoBoy650 (Mar 4, 2024), WRC-LVR (Mar 6, 2024)
Old Mar 2, 2024, 07:01 PM
ViciousLSD's Avatar
yeah even the bolt side of the bushing. if you have SSB trailing arms, put grease on the bracket side where the bushing rubs
Old Mar 3, 2024, 03:32 PM
pagosa dsm's Avatar
I didn't test for bump steer, but I wouldn't think factory would be off that much to use that many spacers.
Old Mar 4, 2024, 05:21 PM
I am using stock trailing arms with whiteline bushings.
Old Mar 4, 2024, 05:23 PM
I am only using the tapered part and the smaller spacers are above the arm.
eve-slow
24
Sep 29, 2011 04:34 PM
ChimpEvOX
Jul 10, 2011 08:36 AM
meat_EVO
Jun 27, 2008 02:52 PM
DSMEVOLUTION
Mar 29, 2008 08:16 AM
jid2
Jun 24, 2005 04:22 PM
Quick Reply: TQ solution rear toe arms question
