Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 13, 2004, 01:26 PM   #31
Personal Sales Rating: (2)
GotBoost25psi's Avatar
Drives: 06 Evo IX MR RR, Drift S14.5 240SX, 91 CRX, and 00 Z71 Lifted
Quote:
Originally Posted by jwtodd60
Volk CE28N-L in 17x8, +33mm fit...
JW
i would love to get some of those in 18's they look really tight! they look great on a yellow evo!
__________________
Evo IX MR: Buschur Racing 3" Turbo back with high flow cat/ Apexi intake/ GReddy Profec B Spec II EBC/ Ebay Manifold/ Dynoflash (mail in)/ Walbro 255 Fuel Pump/ HKS SSQV/ Mirror Dice.....Ok I made that last one up.
Offline
Old May 19, 2004, 12:12 PM   #32
Personal Sales Rating: (0)
Drives: EVO VIII, S2000
@ Neil:
Which is now the correct offset for the 18" SSR competition to fit
Thanks,
Yves
Offline
Old May 19, 2004, 12:24 PM   #33
EvoM Moderator
Personal Sales Rating: (18)
Neal@tirerack.'s Avatar
Drives: 2006 Audi A4 Quattro 2007 Mazda CX-9
We currently sell that wheel in an 18x9 with a 44mm offset, supplied with a 5mm spacer. This gives it a 39mm when its all said and done.
__________________
Neal, Sales Representative
1-877-522-8473 ext 624
www.tirerack.com
Offline
Old May 19, 2004, 12:47 PM   #34
@ Neal:
Thanks for the quick answer but you are stating on the previous page that you now offer the SSR comp without spacers! ?
Offline
Old May 19, 2004, 12:53 PM   #35
EvoM Moderator
I'm sorry, my mistake. I was looking at the GT-3. Whew, need more Dr. Pepper
The non-spacer Comp we carry has a 32mm offset
__________________
www.tirerack.com
Offline
Old May 22, 2004, 05:51 AM   #36
Pesto360's Avatar
Drives: Tarmac EVO
Send a message via AIM to Pesto360
[quote=Neal@tirerack.]
OZ Superleggera III
**Requires a 3mm spacer for proper fitment**
[quote]
Neil...
OZ Superleggeras actually do not need a spacer I had the first set for the evo and they fit perfect....no spacer needed.
__________________
John
Offline
Old May 22, 2004, 05:56 AM   #37
Pesto360's Avatar
Drives: Tarmac EVO
Superleggeras NO spacer
Here are pics of it
My evo is done OZ wheels some nice pics
__________________
John
Offline
Old May 22, 2004, 06:27 AM   #38
Drives: 2004 Evo VIII
Send a message via AIM to Shaitiger
I have a buddy that wants to go 265/30/19 with 19x9 RacingHart Pro J5 wheels. The offset of the wheels are +35mm. The height of the tires are identical or less then the stock 17" tire overall diameter and the 265 is one inch wider than the stock 235/45/17s. Will these fit with a minimal drop or on stock suspension?
Offline
Old May 29, 2004, 06:13 PM   #39
Evo8DownUnder's Avatar
Drives: Apex Silver 2004 Evo 8 MR Jap-spec
Quote:
Originally Posted by AWD 20T
What size tire must I run on an 18x9" wheel? Is fender rolling required?
And again?
Is there a CONCISE thread on this board that gives advice (ACCURATE advice) about what tyre sizes suit what rims?
For example, if you run 18 x 8, the correct tyre to give the same rolling diameter as stock is???
If you run 18 x 9, 19 x 9 etc etc
I'm looking for a set of Volk GT-7s for my new Evo, possibly 18 x 9s (is that size available in GT-7s), what tyre size do I use to get the same rolling diameter as stock and not rub the fender linings? I also want to give it that 'fat' look, so what offset should I use to get that look but remain under the fenders?
Simmons Wheels in Australia do sweet rims, btw.
Offline
Old May 29, 2004, 07:45 PM   #40
Go to Tirerack.com and see the specs for each tire. That will let you compare the stock 235/45/17 tire overall diameter with others. The stock tire overall diameter is 25.3". Go from there.
I still haven't got an answer regarding my question and my question has been up here for a whole week.
Offline
Old May 30, 2004, 12:55 PM   #41
Personal Sales Rating: (19)
Mach V Dan's Avatar
Drives: White '03 Lancer Evo
Quote:
Regardless of lowering, a 265 is a huge width, and I doubt it'll fit without rubbing the fenders (or even the strut). Most cars I have seen with 255 width had rubbing issues.
--Dan
Mach V
MachEVO.com
Offline
Old May 30, 2004, 02:26 PM   #42
What exact tire size did those folks who were having rubbing issues go with?
I didn't know an inch added onto the stock width was a "huge" width.
Offline
Old Jun 15, 2004, 08:21 PM   #43
Personal Sales Rating: (1)
Just Ordered ALT Racing AT-298 X-factor rims, 18X8 with a 42mm offset will i have any problems with these fitting my EVO? Also what tire should i use, size and brand. Thanxs for your help everyone!
Offline
Old Jun 19, 2004, 10:59 AM   #44
Drives: 2003 Lancer Evolution (Midnight)
19" is the only diameter that will let Racing Harts (any model) clear the calipers. 18" is several mm too small.
Currently waiting on a set of 4 Enkei OR52 rims. They will be 18x8, 5x114.3/120 bolt pattern with a 35mm offset. Will not know till I get the fronts on to see if only the front will require a small (<3mm) spacer. Backs fit without adjustment.
This is with being fitted with 4x BF Goodrich T/A KD 225/40/18 tires.
Eva01
Offline
Old Aug 4, 2004, 01:50 PM   #45
Personal Sales Rating: (7)
gldenchld's Avatar
Drives: Evo8 , Lexus SC300(soarer)R1 Raven
Send a message via AIM to gldenchld
Privats work well
Fahrens and Profils 17x8 , 18x8 , 18x9
either silver or gloss black
__________________
gldenchld@hotmail.com AIM=Zkonig AEM & Autronic Certified Tuner
www.privatwheels.com
www.konigwheels.com
New UR Piping Kits
Offline
Tags
17, 18x8, 18x9.5, 19x85, 31, 40mm, 5x100, 5x45, bolt, ce30, fit, mazda, offset, pattern, rgii, volk, x85
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
