Tire / Wheel Fitment Questions
Old Feb 22, 2010, 11:04 PM
  #991
FastLearner's Avatar
Volk CE28 18 X 9.5 +28 Fitment????
Hey all,
Yes I read through the forums and searched but have been left a little bit confused. Wanted to see if any of you out there are running this set-up and what you did to get fitment (ex. tire size, space front, camber, roll etc). Would like to run an aggressive set-up in a 265/35-18, but don't know if it would be better just to run a 245 or 255? Car is on '03 VIII lowered on Cusco Zero-2rs. Obviously will need to roll rear fenders, etc. but looking for some pointers from people who have been there. Thanks ahead of time.
Old Feb 23, 2010, 06:10 AM
  #992
boomn29's Avatar
Your in luck. I just mounted up some of these! I checked the fitment last night on the inside of both the f/r. There's a good finger's length (easy 1/2 - 3/4") of room in the front by the coilover - and a little less in the rear by the A-arm. I think the +34 option might work out better - it should have plenty of room in the insides (6mm = 1/4") and also help tuck up into the fender wells under compression assuming the car is lowered and all on coilovers.
18x9.5" +28 Volk LE28 with 275/35-18 Hoosier R6's. Note that Hoosiers run wider than any street tire.
....Wanted to post my new setup that I just test fitted this weekend. Not sure about the fitment yet or if the offset is the best way to go. I have the rear fenders rolled even (not lipped out or anything). I haven't checked compression yet either. And yeah...the car is dirty from being hauled on the trailor!
Front:
Front looking down:
Rear:
Rear looking down:
I'm also a little curious about he lugnuts. I'm not running spacers or anything, just put on what came with the rims which are an open-style lug - Muteki. Is this how they should look cone torqued down?
Old Feb 23, 2010, 10:47 AM
  #993
boostedwrx's Avatar
Basically you can get away with the 265 fitment in the rear but you may rub on one of the rear bumper bolts. If you run a 255 tire only minor rolling will be needed. Don't run a 245 or it will look stretched. I run 9.5 +28's on a 255 tire and I just shaved 1/8th" off my rear with zero issues.
Old Feb 23, 2010, 10:51 AM
  #994
NocturnalEVO's Avatar
If you run a 255/35/18 tire, you will be fine, even without rolled rear fenders (as long as you're not slammed).
For 265/35/18 you will need to roll rear fenders.
I've ran the wheels in a lot of diff. offsets, i'm very familiar with the fitments.
Old Feb 23, 2010, 10:53 AM
  #995
ElectricEvoIX's Avatar
I just threw these on over the weekend exact rim your looking for wrapped in 265/35/18. I'm dropped on megan track coilovers. The tire is exactly flush with the rear fender and will require rolling on a 265 tire. I would also recommend rolling on a 255 tire also just in case. The fronts didn't seem like they needed rolling but I just might roll then just in case.
Old Feb 23, 2010, 10:58 AM
  #996
boomn29's Avatar
Thx for the added pics everything!
Has anyone else felt the need to run extended wheel studs with these?
I counted the revolutions of about 9 as compared to 12.5 for the stock wheel/lug when I put these on the rear.
Old Feb 23, 2010, 11:18 AM
  #997
THANK YOU ALL!!!!! I think for my first go around I'm gonna go with RT-615s in a 255/40-18 to see where I'm at. When it comes time to replace them I see about upgrading to the 265s. Again, thanks for all the info, PMs, & pictures.
Old Feb 23, 2010, 11:27 AM
  #998
that's what i'm running in 265/35
Old Feb 23, 2010, 12:30 PM
  #999
AMF
AMF's Avatar
^^ I had 265's, rear rolled. The bolts that holds the rear quarter panel and the bumper rubs a bit, but not much. It's a major work to move that bolt back an inch or more according to the body shop that I went to not to mention $$. I switched to 255's, no rubbing whatsoever. Hope this helps.
Old Feb 23, 2010, 01:02 PM
  #1000
boostedwrx's Avatar
^ Exactly. 265 looks the best too, its the ultimate fitment for the 9.5" wheel.
On my 255's I still rubbed in the rear with -1.5 camber with two fat dudes in the back
Old Feb 23, 2010, 02:10 PM
  #1001
AMF,
Are you running 255/40s or 255/35s?
Old Feb 23, 2010, 04:34 PM
  #1002
AMF
AMF's Avatar
AMF,
255/35/18 Z1 star spec
Old Feb 23, 2010, 05:32 PM
  #1003
LOL, I was afraid you were gonna say that as the Z1s are more $$ than the 615s. Guess since the Z1s are barely over 25" OD & the 615s are almost 26" OD the extra $$ may save me some headaches later on. Thanks for the info
Old Feb 24, 2010, 06:24 AM
  #1004
boomn29's Avatar
I do want to add something about fitment on these 18x9.5" +28 Volks.
No spacers needed to mount these up. They absolutely clear the brembo's up front! I haven't drove the car on the street or track with this setup yet though. I did test the turning radius in the garage right-to-left and it looks like a 275 will rub the fender wells in both directions sadly...
I don't think the +34 option clears the brembo's up front w/o a small 5-6mm spacer. The rear would sit in a little better with the higher offset and not require as much rear fender work. So...pick your poison if you're wanting to run something like a 265 or larger.
Front closeup of 18x9.5" +28 Volks with 275/35-18 Hoosier R6:
Old Feb 24, 2010, 05:10 PM
  #1005
boostedwrx's Avatar
I own RE's but I will always have a place in my heart for some CE's
Quick Reply: Tire / Wheel Fitment Questions
