Tire / Wheel Fitment Questions
#2762
Hi,
New at the wheel game. Looking at XXR 521's (18x8.5 +25 Offset) with BF G-Force 235/40/18 tires for my GT.
I know in previous posts there have been comments on rolling fenders with this offset, but is this only required with lowered cars or is it still true at stock height?
Thanks,
Thanks,
#2763
I've been lurking on the forum for a while but finally made an account haha. I'm new to the whole aftermarket wheel game as well. What would be the best offset to run for a 18 x 9.5 wheel given these offeset options.. 12, 22, or 30?
#2764
12, out of the question. 22, doable but very difficult to fit correctly & dependent on tire size. 30, much better offset but dependent on tire choice you are likely going to need rear fender work. 35, depending on tire size possible no rear fender work
#2765
volk racng
hey guys, can anyone tell me if 17 x 7.5 +43 CE28N would celar brembos ?
if not, what thickness of spacer will it need
thanks
thanks
#2767
my friend is letting go a set of oem EVO X enkei wheels.
any one have an idea how they may look like on an evo V or evo VI??
i currently am running on the stock evo V OZ wheels... I may paint those oem evo X wheels white to make it wrc style!
#2768
http://www.lancerregister.com/index.php
#2771
My friends gave me a set of wheels STR Gold its 17x9 offset is 20 , it fits good on the back but touches the caliper on the front. I wish they could fit as I have a wicked look I'm going for. Do you think if i use 20mm or 25 mm spacers it would fit, will the tire come out extra wide. I want a stretch tire look but not a very low profile i think stock evo tires are 235-45-17 so I'm thinking about getting 235-40-17 because i want the same height as stock (because i don't want to lower the car that low) but a bit narrower tyre (so it stretches).
#2772
If it were me, I would pass on this & move to a wheel where you can run a proper width tire, proper lowering spring, camber, etc
#2774
The only way is to run a front spacer of course. Every wheel spoke & hub design is different so there is no spacer recipe to follow. The area in question is known in the wheel world as the "X" factor (distance from the hub mounting surface to the back of
the wheel spokes. This cavity allows for brake caliper clearance)
I would mount the wheel & with a steel ruler attempt to determine how much spacer may be needed. If you need anything more than 20mm or so I would pass on that wheel
#2775
I am running a 18x10.5 work Kai emotion +15 with 285/35 tire. Body shop after installing my voltex front and rear saying they can't even get it off the lift without the wheels rubbing. That they would have to cut most of the rocker panel out on the front. Any help on why these can't fit? Running twin flex coil overs. Pretty sure I thought this was a standard setup for wide body kit evos.
