Tire / Wheel Fitment Questions
Old Jun 18, 2014, 01:48 PM
  #2731
RiCat's Avatar
Talking
I'm thinking about this same setup(18 x 9.5 +20) on my ix. i'm on swift spec-r/mr bilsteins and debating whether to get 245/40 or 255/40s. is this pushing it? what camber do I need to run after i get these on?
Old Jun 18, 2014, 02:42 PM
  #2732
Received 1,384 Likes on 1,317 Posts
Ran your no.s through the calc
+20 is one of the most extreme offsets that is doable providing the proper rear fender treatment is done (roll,pull & bumper bolt)
IMO, the 255 is not that much more difficult to fit than the 245
I dont recommend running out of spec camber to fit the W/T pkg, so this opinion is based on stockish camber
Old Jun 18, 2014, 03:22 PM
  #2733
RiCat's Avatar
Thanks!!!
Old Jun 23, 2014, 08:08 PM
  #2734
KJS
KJS's Avatar
Varrstoen es2's 17x9 +22 or +30.
Figured the +22 probably need ~10mm spacer in the fronts, +30 probably needs a 15mm spacer? anyone run these know what it takes to clear the brembos?
Old Jul 2, 2014, 02:54 PM
  #2735
2gsxtasy's Avatar
So I've already determined that my Advan RG-D in 18 x 9 +35 will clear calipers. Curious on recommendations for tires on an 03 evo 8. No fender roll or anything yet. 255/265? What would be needed? Also the beefer the tire the better. Have considered 255/265, 35/40 , 18 but curious on feedback. I have no intention of "slamming my car" by any means. A mild drop at most an inch or so when coilovers go on the car. Currently on factory suspension.
Thanks for the feedback in advance
Old Jul 2, 2014, 03:30 PM
  #2736
flippymcbean's Avatar
I got the 18x9 +35 265/35/18 I needed spacers in the front because my tire would rub on my spring for my coilovers. The rear is rolled, with the failed attempt at a pull(previous) owner.
Camber specs : -2.8 in the front -1.5 in the rear.
Old Jul 2, 2014, 03:43 PM
  #2737
2gsxtasy's Avatar
How big of a spacer in front? How much roll in the rear? Aggressive? Bolt relo?
Old Jul 2, 2014, 03:57 PM
  #2738
The +35 really helps the tire choice. Of course the no-brainer go-to would be the 255/35 which would fit well w/out a fender roll
Going bold would be the 255/40 or 265/40 which will likely need a roll. Because of the large circumference a rear bumper bolt re-locate may be needed as well
Stock rear camber setting !!
Old Jul 2, 2014, 06:26 PM
  #2739
It's a 10mm spacer. The rear is a flat roll. And no bolt relocate.. It might need it, but I've haven't seen much damage....come to think of it, I've seen no damage. I run semi stiff. What's helping is the camber really....
Old Jul 2, 2014, 08:39 PM
  #2740
Looks great. Like to see a few more shots please
Old Jul 3, 2014, 03:32 PM
  #2741
2gsxtasy's Avatar
I'm hoping I wont have to run the spacer but looking to get fenders rolled in the rear this weekend. I'll post up some pics once everything gets installed. I couldn't find ANYONE running the same wheels so I guess i'm shooting in the dark.
Old Jul 3, 2014, 07:55 PM
  #2742
Should have seen when i had the 285 Hoosiers on. I had very minimal clearance.
Old Jul 5, 2014, 05:06 PM
  #2743
BadassEvo8's Avatar
Were you running the fender mod in the front? 285's are ridiculous
Old Jul 6, 2014, 10:24 AM
  #2744
2gsxtasy's Avatar
Great info. Thanks man. Setup definitely looks great.
Old Jul 7, 2014, 10:18 AM
  #2745
Ryan.Kauz's Avatar
Enkei PF-01 Evo in SBK. 18x9.5 +22
Michelin Pilot Super Sport 255/35/18
Swift spec-R springs with custom valved Bilstein B7 shocks
No spacers
Rear fenders rolled flat, No rubbing noticed so far
Minor scrubbing of front right inner fender when at full right-hand turn
Quick Reply: Tire / Wheel Fitment Questions
