Jan 13, 2004, 01:16 PM
#31
Personal Sales Rating: ( 3)
The best way to get Mitsu's attention on this might be for us all to file NHTSA reports. A large number of us WRX owners did this with various issues encountered on that platform. If enough reports are filed, the NHTSA will investigate and Mitsu will be required to take action.
If we go that route, we should coordinate so that we all file under the same vehicle component section, etc. etc.
-Pace
Offline
Jan 15, 2004, 10:13 PM
#32
Personal Sales Rating: ( 8)
Drives: Boxer Cup
Well I got my car back from the dealer all fixed. They just went under the car and tightened everything in the front end. No more clunking.
Offline
Jan 15, 2004, 11:32 PM
#33
Personal Sales Rating: ( 0)
Drives: Evo 7 GT-A
Experienced the same clunking noise that most of you described and the cause is the suspension top mount (the round rubber pads under the bonnet above each wheel). Replaced those and the noise was gone for good. Alternatively, for something more resilient, you may wish to consider Aluminium Pillow Ball Mounts.
Offline
Jan 15, 2004, 11:47 PM
#34
Drives: 05 WW - 03 RR traded
You beat me to it newsboy. Had the same problem in my WRX. Went to pillow ball mounts and problem solved. Need some for the EVO now.
Offline
Jan 18, 2004, 09:24 PM
#35
Drives: Evo VIII Silver, PT Cruiser, Jeep Grand Larado
Clunk here too
I hadn't heard "the clunk" until I rotated my tires (6K miles). It almost sounds like the wheels didn't get tightend correctly. I agree that it can also sound like a strut problem.
Offline
Jan 18, 2004, 09:39 PM
#36
Personal Sales Rating: ( 1)
Drives: 2003 EVO 8, 2005 Lexus GX470, 2000 RX300
definitely a srtut top mount that getting abnormally worn out due to the stiff suspension. gets worse as miles are put on the car. warantee? should be.
__________________
12.32 @ 114 on 93 oct. 23 psi
Kuniiizzzeee Dial-IN
20g-9
HKS 264
TB
K/N drop-in
255 walbro fp
AMS fm
Forge DV
Ecuflash
Offline
Jan 18, 2004, 09:49 PM
#37
Drives: 1997 Ducati 916 Monoposto
I'm going to take mine into the dealer to have replaced under warantee problem. And the above posts are right. It is the upper strut mounts that are making the clunking noise. I wonder if anyone makes some nice aftermarket ones?
__________________
Offline
Jan 19, 2004, 01:43 AM
#38
Drives: 2003 Rally Red EVO
rear and front
OK before I was experiencing this clunking noise in the back. Now it's both front and back. I have a total of 1,500 miles on my car now. I have an appointment at the dealership For Saturday 1/24/04. I'll post anything they find & any fixes. I'll probably get the old "that's a normal noise" runaround, but I don't want to be pessimistic before I actually go in.
Offline
Jan 19, 2004, 01:57 AM
#39
Drives: 2003 Mitsubishi Lancer Evolution VIII
I started getting the strut/spring noise after I rotated my tires at 5k mile. Glad I'm not the only one.
__________________
2003 Tarmac Black EVO VIII
Buschur 3" turboback (catless)
SAFCII
Turboxs HPmbc (21psi)
Injen intake kit
HKS 264/272
Walbro pump
Fighters Garage LICP
JDM MR diverter valve
"358awhp/354awtq" 91 octane.
Offline
Jan 19, 2004, 02:20 AM
#40
Drives: 03 Evo 8
i was cornering really hard on a back road tonight (test drives for headlight height settings) so I went back and forth a couple of times on the same stretch.
one of the turns, a very fast one, has a big bump in it and every time i hit it, i heard a really loud clunk.
unless mitsu is replacing this part with some sort of updated part or method to install it, the warranty solution will put you right back where you started, nevermind the risk of getting a hack mechanic (they make big commission $ for being fast).
the only real solution (unless mitsu does a recall) is to make a case as a body of owners, like that other guy said above.
Offline
Jan 22, 2004, 09:06 PM
#41
Drives: Whatever is on the lot
Time for me to pay a visit to the dealer..
Clunk was noticed right after install of winter tread..(?)
Front left side..
This should be a warranty item..
__________________
Geez, I havn't been on here in like forever!!
Offline
Jan 26, 2004, 05:00 AM
#42
Re: rear and front
Quote:
OK I took the mechanic for a joyride in my car (Really great guy, owns a 10 second DSM, really knowledgeable, helps his girlfriend mod HER EVO). He agreed that there was unusual suspension noises. He found the end links of something to be loose, and said probably the upper mount of the front left shock is bad too. He ordered those parts and is going to install them as soon as they come in. I'll give an update when parts are installed. It sure is nice to get some cooporation from the service department.
Offline
Jan 26, 2004, 07:21 AM
#43
Shock mounts, etc.
Thanks..
Time to head to the dealer!
__________________
Offline
Jan 26, 2004, 07:38 AM
#44
Personal Sales Rating: ( 7)
Drives: 03 SRT-4(traded in),03 BBY EVO(SOLD), now 94 TT Supra BPU+
yeah i have this clunk too, but mine is on the passenger side...sounds like the strut is loose, but its a really faint noise. Maybe i will print this post off, like i did with the paint chip thread, and see what i can do about the clunking...I still have not taken anything action with the paint chips though, really im not that worried about them...hehe....My suspension has given me a couple weird noises lately, at almost 10k....my suspension is not altered in any way,shape, and or form. For those with different suspension setups.....how is it holding up??
__________________
WhO's SaYiNg HaIm?
Offline
Jan 27, 2004, 04:40 AM
#45
I post the same question on "Evo General"...
Anyone found the source of front suspension clunk?
Someone suggested that it's the sway bar bushings... so..
is it the front upper mount??
If indeed it's the upper mount... which part is it?
strut insulators?
__________________
FS: Amsoil Fluids for Evo engine, transaxle or diffs here
Offline
Tags
2003, 325i, anti, bar, bmw, bump, bushing, car, clunked, e36, front, m3, noise, started, sway, whiteline  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
