To space or to roll?
Hello --
I'm looking at getting some new wheels for my Evolution IX. I've got my eye on the SSR Type Fs, and it looks like 18x9 or 18x9.5 are the sizes. Neither of these are a stock fit, so here are the options:
1) 18x9 requires a 5mm spacer up front to clear the brake calipers. No fender rolling is necessary.
2) 18x9.5 doesn't require spacers. However, some fender rolling is probably necessary.
Here are my questions:
#1 If i use a spacer, do I need to put on longer wheel studs for the lugnuts?
#2 If I'm going to change the wheel studs, will I need to use an "open" lugnut instead of closed (due to the length of the wheel stud not matching up with the lugnut)?
#3 I've looked at a bunch of pics on evolutionm.net, but can't tell the difference on cars with mildly rolled fenders. Does it only affect the inside part of the fender?
My overall thought is leaning more toward the 18x9.5 and fender rolling. I'm assuming that I can use the stock wheel studs and only have to deal with some mild fender rolling. I'd prefer not to mess with spacers, wheel studs, etc. because I will be keeping my stock rims for winter or race tires.
What do you guys suggest?
Thanks for your advice.
RedAustinIX
