Oct 31, 2009, 08:20 PM
Personal Sales Rating: ( 1)
Drives: Evo IX MR
High speed braking vibration
Help me diagnose. I have high speed braking vibration. Only occurs at 45+ speeds and vibrations can be felt in steering wheel and brake pedal. When I brake at slower than 45 I do not get any vibration
Offline
Oct 31, 2009, 08:24 PM
Personal Sales Rating: ( 2)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
Sounds like warped rotors to me. I would have them resurfaced or get a new pair. Do you notice any noise from any specific wheel when stopping?
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Nov 1, 2009, 10:02 AM
Drives: Evo IX GSR & 06 ZX10 R Nassert Beet'd
Quote:
Originally Posted by buchnerj
sounds like warped rotors to me. I would have them resurfaced or get a new pair. Do you notice any noise from any specific wheel when stopping?
+1
__________________
Evo IX GSR - Int, homemade TBE, Borla Tub Mani(test mule), home tune, JL audio's
06 ZX10RR Kawi Green 163.8 whp stock w/ gutted cat, now rockin Nassert Beet and Barnes clutch/springs
Offline
Nov 1, 2009, 11:24 AM
Drives: 2006 Mitsubishi Evo SE
I have the same exact problem, so I just got new front rotors and pads. I'll let you know if that fixes it as soon as then go in. It'll be a couple of weeks though.
Offline
Nov 2, 2009, 03:18 PM
Drives: Evo IX MR
Bump, rotors are new and seem even. Bedded brakes twice
Offline
Nov 2, 2009, 09:22 PM
Did you check all the caliper bolts and make sure the rotor is sitting flat? Really sounds like warped rotors. Could dial indicate the rotors while on the car if it comes to that.
Offline
Nov 3, 2009, 03:15 AM
Drives: evo 9 gsr,2008 vw jetta gli
rotors, and check your brake pads if you have the stock ones
Offline
Nov 3, 2009, 05:03 AM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Quote:
Key word here - seem. Its pad material transfer.
You can try to take 120 grit sand paper to the rotor surfaces and then re-bed the pads. But if that does not work, you will have to get them turned.
Offline
Nov 3, 2009, 10:19 AM
Drives: Evo IX MR
So deposits of the pad on the rotor? I will try sand paper. Also the rotor is free moving right? Just held on by the lug nuts and pad? I noticed that I can pull on the rotor to get it to wobble
Offline
Nov 3, 2009, 11:19 AM
Drives: 2006 Evo IX, 2000 Impreza RST
^^^ what he said
Offline
Nov 3, 2009, 07:07 PM
Personal Sales Rating: ( 4)
Drives: '03 Lancer Evolution 8
It stops wobbling when you torque the wheel and lugs on.
__________________
CarDomain pics
Mods: GSC S1 cams, QTP 3" electric cutout downpipe, Hallman Pro MBC @22psi, Walbro 255 fuel pump, Vibrant cone air filter, Nisei LICP, custom self-tune, RobiSpec KW Club Sports, 18x9½+40 Enkei NTO3-M, 285/30/18 Yokohama Neova AD08
Offline
Nov 5, 2009, 09:54 AM
Personal Sales Rating: ( 0)
Drives: EVO8
warped rotors , i heard this usually happens after going on wet surface when rotors are hot
__________________
HKS full exhaust
Borla header
Racing radiator
Blitz BOV
MBC at 20psi
Offline
Nov 5, 2009, 10:16 AM
2002 Ford Focus
No. "Warped" is the feeling you are getting in the wheel/brake pedal. They are not warped at the rotor surface level. It is pad transfer.
Offline
Nov 5, 2009, 06:04 PM
Drives: N/A
Doesn't matter how many times you bedd them. It's matter that if you did it right or not.
Vibration, did you notice it right after replaced the brakes?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
